Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Old September 11th, 2003, 03:06   #1
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
This page has grown quite large in the last few years. It's main purpose was to put all the helpfull "how to" posts in one section for easy reference. It is becoming more difficult to find things, even in this one thread. So I have edited the thread & divided the "How to's" into categories to make things a little easier to find. I will add more subsections, like Engine maintenance, Performance, ETC. As well as maybe divide the links into models (A4, A3/B4, etc.). But I want to clean it all up first, then get into the little details. I just don't have a lot of spare time this week.
Please, if you have any suggestions for where I placed any of the items, feel free to contact me and I will make the appropriate changes. But please do so through IM's. And to keep this thread user friendly & easy to navigate, please only post links to how to's that you may have done or seen. Please do not post questions or feedback in this thread.
NOTE: This is a work in progress as it takes a long time to do the editing & fixing the links. I hope to have it all done in a few days.
Enjoy
First & foremost, don't forget to look at the ARTICLES link at the top of this page. It has great writeups on such things as timing belt procedures and nozzle swaps.
There is also a section of FREQUENTLY ASKED QUESTIONS that should be looked at.
Now here are some of the How to's compiled by our members:
ENGINE related How To's:
Mechanical:
How to change your injection pump - without changing the timing belt. By Rocketeer928
How to re & re the starter motor for those who have the starter grind or hot start problem. (A4). By Wingnut
Intake Manifold Cleaning 101 - Common therapy for sluggish performance. By Snowball
Another intake manifold cleaning .pdf by DeafBug
My SRP (Stealth Race Pipe) 'How to': How I gutted an EGR to make a stealth race pipe. (A4) - By Wingnut
Front main oil seal re & re by HermTDI
Broken Engine Mount repair: How I fixed my broken engine mount (A4). By Wingnut
How to stiffen your dogbone mount for cheap By Wingnut
How to fix your anti shudder valve rod: In case you broke yours while cleaning your EGR. By Wingnut
How to fix your anti shudder valve nipple. In case you broke yours while cleaning your EGR. By mgwerks
Another anti shudder valve fix: by Wingnut
1$ Anti-Shudder Valve Arm Fix: by Yumanord
How to troubleshoot low power on an A3/B4 ('96 - '97 Passat, '97 - '99 old body style Jetta): By GoFaster
ALH Turbo removal .pdf by TDI Innovations
TDI ALH Turbo Removal HOW TO written by Speedster.
VNT Repair - Clean soot and rust for proper movement. By Drivebiwire
New engine break-in method: By Drivebiwire
New engine break-in method: By LanduytG
Frequently Asked Torque Values: by Runonbeer & others
Snow screen removal for the Beetle By JackBak
KK's CCV Mod by Kayakkermit (PDF done by Cevans)
CCV Mod: One of many ways to reduce intake clogging (A4)
CCV Mod 2.0: My new system (still testing) (discontinued due to clogged paper filter element)
CCV Mod Ver 3.0: This one I hope will not plug up
Installing the Mann ProVent CCV Filter (3.8 megabyte PDF version available here.). by Jddaigle
Hard Starting When Engine is Cold: by Drivebiwire
FUEL/OIL/COOLANT RELATED:
How To video clips Includes fuel & air filter changes, snow screen cleaning, etc. By CinciTDI & friends (MoGolf, RichC, Tim
Hunter, Eric Rothweiler, Paramedick, etc.)
Replacing fuel temperature sensor: by McBrew
DIESEL PURGE HOW TO: by Arby
LM Diesel Purge - PD Engine Procedure (PDF) by SUNRG
Another diesel purge pictoral by Russell Parr
Inline fuel filter (Auxilliary): for running biodiesel. by Bill Blazek
Stanadyne 5-micron Fuel Filter Upgrade by SUNRG
Alternate CAT fuel filter T holder by Paramedick
Traditional method Oil Change instructions. by DeafBug
Hammer mod info
IP Upper seal replacement how to: By [FONT='Verdana','sans-serif']cerickson[/font]
Coolant change procedure: by Runonbeer
Diagnose an overheating car: By Herm TDI
ELECTRICAL:
A4 radiator fan re & re: by Joester
Maf 101: Credits to: bam_ban_dip, bhtooefr, cage, whitedog, paramedik, dieseldorf, & compu_85
Glow plugs 101: How to test the glow plug system - by Wingnut
Glow plugs 101 Ver. 2.0: A newer, revised version of the original with better pictures - by Wingnut (PDF version)
Possible Glow Plug Harness Cure: Products to treat your GP harness - by Wingnut
How to extend the glow time with Vag-com: One way to assist with cold starting (check timing first)
Alternator Re & Re How to: How to remove & replace your alternator. (A4) - by Wingnut
Alternator Pulley Re & Re How To: How to remove the pulley from the alternator. By Paramedick
Voltage regulator Re & Re (a3/B4) by HermTDI
Battery maintenenceby HermTDI
#3 Injector Plug Swap: For anyone who has purchased Injectors from Marc (RedRotors). By Wingnut
Relay 109 info: How to replace the relay 109. By Turbo Steve
How to Re & Re an A4 ECM Courtesy of APR.
Cage Mod - Dielectric grease in MAF connector - Cage Mod Revisited
Evry Mod - Inexpensive performance enhancement. By Evry
BRAKE/SUSPENSION/DRIVELINE related How To's:
Front wheel bearing replacement by scurvy
Front Brake Replacement: How to remove & replace the front brake pads & rotors (A4) by Wingnut
Rear Brake How To: Rear brake replacement procedure. by Cosmic.
Motive Brake Bleedeng Procedure also done by Cosmic.
Power Brake Booster Removal:
Parking brake cable replacement, step by step: by dqa
A4 Brake switch replacement: How to swap out the brake light switch. By Snowman.
Brake light switch repair: How to repair a bad switch. By Je
Sway bar bushing replacement: How to replace your swaybar bushings. (A4). By Wingnut
Lower control arm bushing replacemet (A4) by Wingnut
A4 Ball joint replacement: by Moo Car
Do it yourself rear axle beam bushing replacement. as posted on VW Vortex.
5th gear swap by David 594
VR6 axle swap: How to swap the TDI axles for more robust VR6 axles (A4). By Wingnut
Rear axle bearing Re & Re: How to change your rear axle bearing (A4). By Wingnut
Front Wheel Bearing Replacement Procedure: by DLV
Front strut mount replacement: How to replace your strut mounts without removing the struts. (A4). By Wingnut
Coilover install by Noah
How to make a short shifter. My homemade short shifter. (A4). By Wingnut
Automatic Transmission Fluid Change: by Drivebiwire
Automatic Transmission Line Pressure Mod: by Kerma
INTERIOR/EXTERIOR/STYLING/MISC related How To's:
Wiper linkage RE & RE How to remove, relube & replace the wiper linkage by Wingnut
Flakey Turn signal fix How to re & re the turn signal stalk to fix the annoying signal click by Varkias
A3 boost guage instalation by Juli0s
Disable day-time running lights (DRLs) for A4s. By Burningmoney97
Heater switch lightbulb replacement: How to replace the light bulb behind your heater switch. (A4). By Wingnut
How to change the color of your cruise & flasher LED's by jpdeuce
How to instal extra trunk lighting by Ausgezeichnet TDi
How to change your HVAC control bulb: This ones for the A3/B4 cars. By Rammstein
How to remove the light switch in a B4 By Rammstein
How to disable the DRL By Rammstein
How to make your rear fog lights work on your B4 OEM style By Rammstein
Hot windsheild washer fluid: How to add a heated windsheild washer. By MoGolf
Autodimming mirror/rain sensor: How to add autodimmin/rainsensor mirror by MoGolf
How to fix broken rear w/w sprayer: By Hamsterdiesel
Aluminum Skid Plate Install by Nelly2400
Engine Cover Mod: Homemade wingnuts
Engine Washing: By Herm TDI
Cabin Filter Replacement
Polishing headlights. By Yetta0
Ventectomy - Safely increase fuel tank capacity [Pictures] By Frank M & others
$3 door switch fix: by vwsandman
Remote Keyfob battery replacement for A4: by Schnabba
How to fix rotted antenna base by Louis TDI
Extending the range of your remote (VWVortex thread)
Extending the range of your remote (instructions in an MS Word file)
Extending the range of your remote (PDF format, large, 4 pages)
Extending the range of your remote (PDF format, small, 2 pages)
VW Technical Service Bulletin for Extending the range of your remote
How To Add AC to Your Glove Box (A4): by pepper10
Cold Weather Fuel Sender Mod: by Karmann-diesel
Pierburg Connector Solutions: Varoius ways to modify your OEM connector to fit the Pierburg (A4)
How to troubleshoot flakey cruise control In case yours is like mine was and only worked when it wanted to.
How to post images in these forums-- a walk-through
http://forums.tdiclub.com/showthread.php?t=190549 A LONG list of acronyms and abbreviations used on the forums. Log onto the
picserver and open, file is in MS Word (.doc) format.
Here are some more that I have in my favorites list:
Dubtuning: LOTS more GREAT how to's here
GeWillis home page: Even MORE GREAT how to's.
Huge MKIV FAQ & DIY List From VWVortex.com
Wingnut is offline   Reply With Quote
Old December 31st, 2004, 06:07   #2
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 56.3/44/41
Default HOW TO's
Penclnck's 4130 Products 'Step By Step' Many great tips!
Maintenance Related things:
OldPoopie's Timing Belt Checklist
Car suddenly won't start? Check your Anti Shudder Valve!
Replaceing the headlight bulbs on a Jetta (bt EECSentric) (Link is now dead anyone have a better one? )
Snow Screen Cleaning (lowfi version)
Clutch Change HOW TO. With PDF! By DBW.
Serpentine belt change.
Electrical Related things:
Turn off your airbags selectively with VAG-COM
Benlty's List of DTC Fault codes
Can't get your automatic out of park? Brake switch workaround!
How to bleed the ABS pump after the brake fluid runs dry. By Birdman
List of fuses in the A4 Includes a list of what fuses are hot when.
Immoblizer acting up, but you have the SKC? Input it in the odometer! by MOGolf
Modification related things:
Connecting the rear fog and 5 light mod (on the A4 Jetta Sedan)
Just the 5 brake light mod PDF Version
5 Light mod on the Jetta Waggon (By EECSentric)
5 light mod w/ the turn signals. by Left Coast Resident
David_594's List of OEM+ mods.
Other Useful Threads
Gearbox Ratios.
-Jason
99.5 Jetta TDI. 254,500 miles. 36 / 47 MPG. Half way there!!! Now with power memory seats & Monsoon audio
1992 Jetta ECOdiesel. 155k miles. 28 / 35 MPG. A little work has turned this into a nice lill ride
1991 Jetta ECOdiesel. 420k+ miles. 32/44 MPG. Sold to VeeDubTDI
1991 Mercedes 350SDL 207,000 miles, 57,000 on engine. 18/27 MPG.
Last edited by compu_85; June 12th, 2007 at 08:08. Reason: added Jetta Headlight link
compu_85 is online now   Reply With Quote
Old August 18th, 2005, 18:17   #3
Wingnut
Wingnut's Avatar
Reserved for future links.
Old December 27th, 2005, 14:48   #4
Wypij
Wypij's Avatar
Default Clockspring R&R
Clockspring mysteries unwound.
Wypij is offline   Reply With Quote
Old January 19th, 2006, 06:51   #5
oldpoopie
oldpoopie's Avatar
TDI(s): 2001 golf gl
Send a message via AIM to oldpoopie
Early 1999 cars have a different n75 and n18 connector. Here's a link for part numbers to change the connectors to the later style to be able to buy the less expensive units.
http://forums.tdiclub.com/showthread.php?p=537447
TDIclub trusted mechanic in Oregon - PM me
I use tools
AVAILABLE TO TRAVEL TO GTGs
01 Golf nozzles and fuel filter, VNT20, PD150 intake and tip, R32 airbox, MAF, and snorkle, FMIC, .............
oldpoopie is online now   Reply With Quote
Old March 25th, 2006, 04:14   #6
Audi5000TDI
Banned
Fuel Economy: 44,51, 59.08 mpg
How to replace your leaky A3/B4 Bosch VE Injector pump seals with pictures.
http://forums.tdiclub.com/showthread.php?t=75740&page=2
You should also include learning the Hammer mod for adjusting your Quantity Adjuster on the injector pump.
Audi5000TDI is offline   Reply With Quote
Old May 17th, 2006, 06:55   #7
volmaniac
volmaniac's Avatar
Fuel Economy: 50.0 - 49 - 46.1
Default 04 center console writeup
Mike_M did a nice 04 center console writeup here:
http://forums.tdiclub.com/showthread.php?t=115330
2002 gls golf ||1999.5 gl jetta
Yeah man, I tell ya what, man, that dang ol’ internet, man, you just go in on there and point and click, talk about w-w-dot-w-com, mean you got tdi cars on there, man, just go click, click, click, click, click, it’s real easy, man.
volmaniac is online now   Reply With Quote
Old August 2nd, 2006, 12:01   #8
paramedick
paramedick's Avatar
Default Dieselgeek Panzerplate skid plate video
Compliments of the folks from CinciTDI club and Dieselgeek. Starring yours truly! You need Apple quicktime 7 or newer to run this. Kudos to RichC for the excellent video work and editing.
http://cincitdi.com/richc/panzerplate.html
Apple quicktime installer link
http://www.apple.com/quicktime/player/win.html
TDI Repair Services available. PM or E Mail me. No greasecars, please.
An all TDI Family!!
Old August 4th, 2006, 07:59   #9
aham_uk
aham_uk's Avatar
A4 Ventectomy with write up and Gwillies photos
Coolant temperature sensor replacement - a fix for faulty temperature display readings
aham_uk is offline   Reply With Quote
Old August 14th, 2006, 14:32   #10
paramedick
paramedick's Avatar
Default A3/B4 Timing Procedure
Posts by myself and HermTDI detailing the procedure.
http://forums.tdiclub.com/showthread.php?p=595063
An all TDI Family!!
Old September 4th, 2006, 13:20   #11
SilverBullit
SilverBullit's Avatar
Fuel Economy: Chi-Houston 2 tanks speeding
Default City lights as drls pdf how to
Just made a nice easy .pdf for a nice easy mod. ideal time to do it is during a joey mod but it can be done anytime you have enough time to pull your headlights off the car.
drl.pdf
2000 Golf GL TDI >panzer plate, everything else doesn't matter.
Chuck Norris had an action figure. It was of a character he played. Steve McQueen's was just a Steve McQueen action figure. What does that tell ya?
SilverBullit is offline   Reply With Quote
Old September 7th, 2006, 11:18   #12
daBooj
Fuel Economy: 67/60/43
Default ABS Speed Sensor replacement
It was hard to find this when I needed it (and in the end, it wasn't enough, so I added to it.)
ABS Speed Sensor replacement (for when it glues itself in)
http://forums.tdiclub.com/showthread...03#post1445603
65mpg working on 100
in my 2004 PD Jetta
daBooj is offline   Reply With Quote
Old September 10th, 2006, 12:54   #13
Moo Car
Default Cruise control / Turn signal / Dimmer switch replacement
Cruise control / Turn signal / Headlight high beam switch replacement.
This could also be good for the windshield wiper switch replacement.
http://forums.tdiclub.com/showthread.php?t=151557
2000 Jetta Auto
Moo Car is offline   Reply With Quote
Old September 29th, 2006, 09:42   #14
isukennedy
Fuel Economy: best - 49, average - 42
Default how to buy a TDI / buyers guide / buying guide / buyer guide
http://forums.tdiclub.com/showthread.php?t=75359
I made the title long to include as many search keywords as possible.
isukennedy is offline   Reply With Quote
Old November 15th, 2006, 06:14   #15
spoilsport
spoilsport's Avatar
Fuel Economy: 53/46/40
Cool check it out
Originally Posted by 3800rpmDiesel
anyway i looked all through this thread and only saw a video option at top of thread, and a filter upgrade thread - i want to stay stock....
This is the video you want!
It's one of the masters (MoGolf) taking you through an OEM fuel filter replacement.
spoilsport is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.18280 seconds with 9 queries
[Output: 148.08 Kb. compressed to 125.29 Kb. by saving 22.79 Kb. (15.39%)]
