How to repair your Jettawagon cargo cover.
I have finally figured out how to fix this!
I (foolishly in hind sight) even asked VW Canada’s Customer Service online service. All they did was point me back to the dealer and washed their hands. I tried to point out the cargo cover is their design so they should provide a kit for when the 2mm thick plastic end pieces fail (I really did not want to buy an new one for $700 plus tax as we throw enough plastic stuff away on a daily basis). Enough of my ranting…
My cargo cover of 6 years did not want to rollup again. I found the four teeth on the end plugs worn off. that the end pieces on the central roll had the four teeth on the end plugs worn off. No amount or type of glue could fix this. After numerous bright ideas and attempts I finally came to this on how to replace this end plug. Please read through first before attempting.
Tools and Parts:
What failed:
This tiny piece of plastique with teeth of ~2mm. (the yellow stuff is from an earlier attempt to glue it, which failed)
Pre-work:
Remove plastic end covers from cargo cover
Roll up the cargo cover back into its’ housing (easier to handle)
Remove the end screws and end plugs
Take your set screw (grub screw) and check that they fit into the space where the end plugs were. If this does not work, stop now and get the parts that do fit.
The work:
As always, do this at your own risk.
Enjoy.
Tools and Parts:
- Cargo cover that has the end plugs worn off
- Torx key to remove the screwed in end plugs that are broken
- JB KWIK Epoxy
- A few tooth picks, sheets of newspaper and some paper where you mix the epoxy
- 2 hex (Allen) keys [I used IKEA 5/16” as I shop there a lot]
- 2 set screws (grub screws) with hex sockets that match your hex keys [I used 3/18” with a length of 18mm]
- metal saw
What failed:
Pre-work:
The work:
- Setup your paper underneath each end of the cargo cover (you never know when you will make a mess)
- Mix enough JB KWIK (I used 1 very large drop (~1cm x ~1cm) of each part) for one side.
- Once mixed, use the toothpick and pick up some of the epoxy and rub it onto each of the 4 groves (ensures no air pockets) on the end of the cargo cover, then put the rest deep into the end of this hole.
- There should be a bit of epoxy left over, take the set screw (grub screw) and with it on the hex key, roll the threads into the epoxy (do not get epoxy on the hex key). This will fill the treads and take out air pockets. Now, insert into the epoxy filled end and gently push in until it can go no further and give it a ¼~1/2 turn clockwise. Make sure that the hex key is straight in line with the cargo cover roll and when assured of this you can remove the hex key and wait for the epoxy to harden. (if you prefer to leave the key in you can but ensure that it is supported in the desired position)
- Repeat this to the other end.
- Test your work to see that no epoxy has covered your screw and the hex key can still fit easily. If there is any issues scrap/cut/grind away the excess epoxy.
- Place the end plastic end pieces back on the cargo cover ends and insert the hex keys into both ends.
- Tighten the cargo cover to how it originally was. Sorry, I have no way of detailing this so you will need to do this on a trail and error basis.
- At this point, you will note that the hex keys are sticking far out from the ends. Making sure that the ends are tightly compressed together, measure how far the hex key’s arm is from the end piece and cut this off. This needs to be done on the other side too.
- Now you can return your fixed cargo cover to you car. It will be a tight fit putting it in but it will work again and not cost you the price of a new cover.
Enjoy.
