paramedick
TDIClub Enthusiast, Vendor
I have seen various versions of this over the past year. Most involved cutting a piece of metal, drilling it, and install. I figured there must be an easier way. There is.
As you may have noticed, when using the old style thermostatic T retainer, there is a small gap between the bottom of the T and the filter head. In a few cases, the O rings do not fully seat when using the supplied retainer. With this modification to the CAT fuel filter, you have the thermostatic T sitting flush on the filter head, and the O rings fully inserted into the hole.
Note: This mod is for the earlier generation CAT fuel filter heads. If you have one of the later generation filter heads, the screw holes are spaced wider apart. This mod will not work with the braces listed below. You will recognize the newer heads if the thermostatic T holder has a circular opening that the top of the T fits into.
You will need the following parts:
#8x32x1.25 inches machine screws $0.10 each
#8 or #10 x .75 inch nylon spacer $0.30 each
#8 star lock washer $0.10 each
2"x1/2" mending braces $2.99 for a package of 4
I obtained all these parts at a local hardware store for the price listed. If you want galvanized braces instead of brass-plated, you can save 50 cents.
The mending braces have two holes drilled in them. Guess what? Yup, perfectly spaced for the CAT filter head screw holes.
The purpose of the nylon spacers are to protect the thermostatic T. You won't have a screw thread damage the T by using these.
Take your brace, and insert one screw/star washer through each hole. Add your nylon spacer to the protruding shaft of the screw. Place over the top of the thermostatic T, and secure evenly. If you want the spacer to stay in place, put a bit of silicone glue in the hole before inserting the screw. Wipe excess silicone off the protruding screw threads. You won't ever lose parts this way.
The next two pictures are self-explanatory.
This may be the cheapest mod I have ever done. Hope this helps someone else who has been contemplating something similar, and did not want to make a custom piece.
Bruce
UPDATE: I have replaced the regular screws with allen head cap screws in the same size listed above. The Phillips head screws were starting to strip out. It looks cleaner, too.
Bruce
