Wingnut
The wiper linkage on the A4 model VW's are prone to seizing. Its a very common problem that can be repaired with a few tools. The cost of a replacement assembly has come down considerably, so my recomendation is to simply buy a new one and change it, but you can also follow these instructions and fix your old one if you prefer. Or, if its an emergency and the new linkage has to be ordered in and you need the wipers to work for a few days.
Firstly, you need a few basic tools:
- 13mm socket or wrench to remove the wiper arms
- 10mm socket or wrench to remove the assembly.
- large flat head screwdriver or prybar for prying purposes
- Wiper removal tool to take off the arms (I bought mine for $8)
- Small jaw puller to press out the wiper shaft
- Adjustable wrench to work the shaft back & forth if you don't have a puller
- Penetrating fluid & grease
- Round file to clean the hole.
The first step is to remove the wiper arms. Simply pry off the caps with a small screwdriver:
Then, loosen the 13mm nuts that hold the arms onto the shafts. This is what the wiper arm removal tool looks like:
Many people have also used ball joint or tie rod removal tools available at local autoparts stores for borrowing. Here is the tool in place:
As you can see in this picture, I left the nut in place, but loosened it up just past the top of the shaft so that there was a small divot for the end of the threaded rod to sit in. That way the tool doesn't slide off the end of the shaft.
Now, just tighten the tool until the arm pops off. Sometimes, the arm can be quite stuck. If you have tightened the tool as far as you can go by HAND, don't force it any further. It will have enough tension on the arm that you can probably break it loose by grabbing the arm and giving it a good wiggle. It wil come off with a crack or a pop since the dissimilar metals tend to corrode together.
Once the arm is off, you need to remove the lower valance at the bottom of the windsheild. It is just pressed into place and can easily be pryed off. I use a wide prybar to distribute the force over a larger area to avoid damaging the valance. Pry gently, starting from one end and working your way accross:
You might want to put a rag or something behind the prybar to protect the windsheild. I just took the picture for reference. Once you get it started with the prybar, you can finish it off by hand by pulling it away from the windsheild:
Now you have exposed the linkage. Remove the 3 10mm bolts holding it in place:
Once its loose, you can manipulate it to a better position to reach the plug for the wiper motor. Unplug it and then wiggle the linkage out of the car. It takes a little twisting to get it out, but its not too difficult:
Now, if you have a new one to put back in, instalation is the opposite of removal.
If you are going to repair yours, move on to part 2 below.
