Left Coast Resident
Ubẽr Clubbie
I decided to add my turn signals to the additional brake lights that I had already installed a while ago. Or maybe it's the other way around -- to add the additional brake lights into my rear turn signal circuit. There are lots of links to various write-ups of the original '5 light' mod on the forum here; this just allows one more handy option.
Here you see the original jumper that I made, from the top position (the stock brake light bulb) to the position that would have been used on ROW cars.
Here you see representative components, not to scale, that you'll need to do one wire (obviously you'll need two wires to do both sides of the car).
The diodes have a small grey band on the down side in this photo that will go to the '5th. brake light' bulbs. I paid 61 cents today for 8 of them (I have 2 Jettas to do).
Here you see the wire, the terminals, and the diodes assembled, and about to be heat shrunk. The diodes allow power to go to the bulb from either the turn signal, the brake, or from both, but not back in the other direction. When the turn signal is on, the extra light on that side blinks, when the brake pedal is depressed, that bulb will go solid, without regard to the turn signal state. The turn signal bulb is unaffected.
Here you see a blurry photo of the completed wire assembly ready to be connected into the VW tail light bulb assembly. Sorry for the blur.
Here you see the completed jumper with internal diodes, as it is installed on the VW tail light bulb assembly, ready to go back in the car.
The center unused connector spot contains 3 pins, and is labeled in tiny letters 31 (ground), and BL/S. Ground is the left pin -- ignore it. BL is the center pin -- the bayonet terminal is pushed onto this one. The last pin (S) is for the tail light (or 'marker' bulb as the reference material calls it). The other side of your car will be strikingly similar to, but the mirror image of, this (as the brake light bulb goes to the outside position on both sides of your car). FYI, as though it matters, this is my passenger side.
Here is the finished result showing the left side turn signal blinking (you'll have to pretend it's going blink, blink, blink) as well as I could photograph it at night. The full result doesn't really come across, and the colors are not true (the turn signal blinks amber, and the additional brake light blinks red). They are the same brightness, as they are both standard 21W bulbs, obtainable anywhere. I'm sure you get the idea.
