Orders TDI Club Cards TDI Fest 2009 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
User Name
Password
Thread Tools Search this Thread
Old December 6th, 2006, 12:02   #1
scurvy
Good Ol' Boy
scurvy's Avatar
Send a message via ICQ to scurvy Send a message via AIM to scurvy
Post How to block your front grill with pipe insulation
It's that time of the year again, when plummeting temperatures send us scrambling to dose our fuel and crank our seat heaters to 11. Ever wanted to block off part of your radiator to help your engine warm up faster? It's very easy to do and can help you get better fuel economy, perhaps lower engine wear but most importantly get heat to the passenger cabin faster. This is very easy & cheap, but I thought some of the less imaginative or mechanically inclined may benefit from some pictures. This was done on my 2006 MkIV Golf TDI.
Go to your local hardware store and buy 3 meters (9') of foam pipe insulation for 13mm (1/2") copper pipe (or 10mm iron pipe - pipe sizing is weird, but pipe threading is even weirder). I found it at my local Menards for the whopping sum of $1.64. Menards is a midwestern chain of giant hardware stores, kinda like Home Depot or Lowes, but without all the suck. The pipe insulation usually comes in 2 meter lengths (6') but for some bizarre reason, it was in a bag of four (4) one meter lengths. Whatever. It costs less than $2 total and more than you need.
Note that this is dark grey, which blends in better. Sometimes it is brown or black. It will still work fine. Don't worry. Have a homebrew. Also notice the package is half French. That's because this stuff was hecho-en-Canadia.
Take out a piece of it and notice there's a slit down one side. That's how you would put it around a pipe. And that's how you're going to put it on your grille. Open up the slit by running a finger down it:
Then slide it in place over a slat in your upper grille, and trim to length with your pocketknife:
Repeat three times, and the upper grille is done.
Give it all a nice push to get it settled in there.
Now do the same thing on the lower grille slats. Don't bother with the bottom-most as it doesn't actually go through.
But before you slide those in place, I like to cut some slits to match up with the vertical grille bits, shown below.
Those help it sit nice and far back into the grille openings and block out that awful cold air.
Do that for both lower grille slats and you're done, honkey.
It may seem a little flimsy but I've never had a piece become dislodged for any of the past 3 winters.
Enjoy!
scurvy
Chief Engineer of the Scurvy Winter Front | 2006 Golf TDI | 2000 NB TDI | Schaeffer Supreme 9000 5w40 | VCDS in Chicago, IL USA
Last edited by scurvy : October 12th, 2009 at 17:41. Reason: Big massive updated pictures
scurvy is offline   Reply With Quote
Old December 6th, 2006, 13:40   #2
SoaceMunky
SoaceMunky's Avatar
i'm curious....exactly how much of an effect will this have? it doesent get THAT cold around here, but I'm always up for messing with the car!
2006 MkIV Anthracite Blue TDI PD Golf GLS + tint, stubbie antenna, ventectomy, bike rack, 101Kmi;
SoaceMunky is offline   Reply With Quote
Old December 6th, 2006, 16:38   #3
bugablue
bugablue's Avatar
Send a message via MSN to bugablue
i usually just put a piece of cardboard in front of the actuall radiator. then it doesn't look like my car has braces.
bugablue is offline   Reply With Quote
Old December 6th, 2006, 17:37   #4
MikeS_18
MikeS_18's Avatar
Send a message via AIM to MikeS_18
Hey, and if you spray paint the insulation black it will flake right off so don't bother. Trust me on this one...
I hope that really does help, because I'd hate t drive around looking like that if it had no effect. j/k
'03 Wagon, CWP, 5spd, 17/22 turbo, RC3-, Sprint 520s, Stage 1 clutch, Old Man Intake, TT Short Shifter, EGR Cooler Deleted, Koni Reds, Neuspeed Upper Tie Bar, Euro Tailights, A FIVE BRAKE LIGHT MODDDD!, Audi Lift Pads, Aspherical Mirrors, DG skidplate, Ecodes, Phatbox, Cupholder Console, Thule Roof Basket, 800 Mile/tank club, Secret Ingredient
'64 Ford Econoline Travel Wagon, 170ci straight six, 3 spd, 17mpgs "If it's got a hood, it ain't no good!"
MikeS_18 is offline   Reply With Quote
Old December 6th, 2006, 18:05   #5
RabbitGTI
RabbitGTI's Avatar
I just buy six rolls of cheap duct tape and cover the entire front of my car. I block off everything but the headlights. Just make sure to keep a knife in the car in case you have to get the hood open.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5
RabbitGTI is offline   Reply With Quote
Old December 6th, 2006, 18:15   #6
weedeater
IIRC, that lowest slot does not go through.
I place the slit of the insulation over the fins of the grate. That uses less stuff, and the two pieces (top/bottom) hold each other together.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old December 6th, 2006, 18:50   #7
RabbitGTI
RabbitGTI's Avatar
Seriously, I just use pieces of a 1/2 inch think backpacking mat and put them in front of the radiator. Works great.
Old December 6th, 2006, 19:14   #8
Outbound
Default A/C Cover
99.5 Jetta -- I noticed that my A/C fan died and really had not worked for some time so I pitched it --- my A/C worked fine and it would blow cold on the hot summer days. I also noticed that the large hole in the rad cover where the fan attached would be a great place to cover over for the winter -- for faster warm-up and getting a little more heat. I cut a cover out of plastic and screwed it into the same holes as the fan mount. The rad cover has a divider in the middle so the cover closes off half of the rad. I did not do an eng'r test on this project to see how much faster it warms up, but it seems to get heat faster and holds the temp better on slow around town driving. I have run the x-way at speeds of 75mph in weather temps of 70 degrees and the motor has not overheated. Now that it is getting much colder I have placed another cover over the front lower part of the rad -- 6" high by the length of the rad. The motor warms up pretty well now --- even slow town driving. I see 180 most of the time now on my Scan - even with the heater blowing hard.
Outbound is offline   Reply With Quote
Old December 7th, 2006, 06:29   #9
scurvy
Good Ol' Boy
scurvy's Avatar
Thumbs up So far, so good
Made it a good 75 miles since I installed it in subfreezing weather at highway speeds - so sign of movement.
This morning it was 8F (-13C). Driving carefully and easy, keeping RPMs below 2500, I was off the bottom 3 lines in 1.5 miles, full-on 190F (90C) straight up on the temp gauge 2.5 miles later (4 miles elapsed) on city streets. This is an improvement from previous days, when it wouldn't be fully hot before I got on the Dan Ryan expressway.
I like it.
Old December 7th, 2006, 15:21   #10
brucep
Another benifet of covering the grille is to keep out the SALT SPRAY (Chloride, Calcium, Uride...whatever they use in your area) which comes off of the wheels of the car in front of you.
I have see radiator fins turn to dust after a few winters of salt-spray on them.
I also, in the spring, use copious amounts of water from the garden hose to rinse off my radiator. Otherwise, that salt will stay there and munch away at the fins all summer when it gets humid.
brucep is offline   Reply With Quote
Old December 7th, 2006, 15:31   #11
Audiofyl
Audiofyl's Avatar
Send a message via AIM to Audiofyl
I did mine, but in a different way. I used some slightly larger insulation and fit it over the horizontal bars of the lower big grille, as if the horizontal bars were the pipe that the insulation was designed for. Prior to the fitting, I cut some vertical slits in the insulation to fit around the vertical bars in the grille. Before the final placement, I wrapped a wire tie around a couple of the horizontal bars so the unattached ends were poking out the front of the grille. Once the insulation was fitted, the ties can be attached and trimmed to prevent any movement. I did this with only one long piece of the insulation as it only has to cover 2 horizontal bars.
I agree with scurvy as the temp increase is immediately apparent in the cold climates.
05 golf gls tdi 5mt indigo blue
94 honda civic ex turbo
03 honda cbr600rr
2009 yamaha zuma 125
What's your hybrid sound like?
Audiofyl is offline   Reply With Quote
Old December 7th, 2006, 22:33   #12
Nitrowolf
Nitrowolf's Avatar
You, my friend, are a god. Anyone that can install something on the front of their car in subzero weather while traveling at 65+ MPH without wrecking is a god. I bow before you.
Nitrowolf is offline   Reply With Quote
Old December 7th, 2006, 22:40   #13
Zero10
Zero10's Avatar
Even if he did, it's only half as cool as this guy
http://www.dpccars.com/car-movies/12...ing-Donuts.htm
87 Porsche 951
05 Golf GLS TDI
Zero10 is offline   Reply With Quote
Old December 8th, 2006, 06:52   #14
scurvy
Good Ol' Boy
scurvy's Avatar
Didn't really seem like that big of a deal to me at the time... guess I've just got long arms.
Yeah, that was an awkward sentence to write and to parse. Me fail English? That's unpossible! Lemme rephrase it... "After installing the pipe insulation on my front lower grill, I drove at least 75 miles at interstate speeds in subfreezing weather and the insulation has shown no sign of movement."
It was 5F (-15C) this morning - same story as before. Off the three hash marks after about 1.5 miles, full heat by 4 miles. I like the other methods mentioned, but this one seem like by far the laziest and appears to work well.
scurvy
Old December 8th, 2006, 10:23   #15
kharmin
I'm completely staying out of the grammar discussion, but the pipe insulation in the grille Does make a noticeable difference in warm-up time! My gauge was off dead-cold and moving up in less than 2 miles yesterday, as well.
Thanks for the suggestion, scurvy!
I did top and bottom of the center grilles. The brown-ish color didn't look real promising in the store to me either, but on the car it's fine.
kharmin
'06 Jetta - Spice Red & beige
DSG, pkg0, anti-glare aspherical mirrors, Panzer plate
door locks mod (by the dealer!), key-fob windows by TDIinRI
kharmin is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Powered by vBulletin Version 3.5.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 1996 - 2007, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.09464 seconds with 10 queries
[Output: 101.39 Kb. compressed to 94.10 Kb. by saving 7.29 Kb. (7.19%)]
