vwdsmguy
Has anyone ever tried using the 1.8T dog-bone trans. mount? It is supposed to be stiffer than the TDI mount and bolt right in. I really wonder if more vibration is felt in the car, since it's stiffer?
Having not seen the upgraded poly, perhaps the only advantage might be the mount I have is about as stiff as it comes, or at least I don't see how you can get any stiffer without welding in some box section between gearbox and chassis.Monkey1 said:wow that is pretty cool..
bigger advantage over just the upgraded poly ?
Save yourself the expense and stiffen your own up. Its easy to do. Simply remove it from the car, separate the end that has the 2 rubber inserts. Then shim them up with some 1/8" material. I like to use industrial floor tile. You can buy one at Home depot for under a buck. Cut it to the shape of the "bowl" that the rubber sits in. You can add as many pieces as you need to make it as stiff as you want. If its too stiff, simply remove one shim. What it does is cause the rubber pieces to compress more, thus making them stiffer. It takes less than 1 hour and is 100% reversable, unlike other methods that require cutting the dogbone mount to compress the rubber pieces.vwdsmguy said:Has anyone ever tried using the 1.8T dog-bone trans. mount? It is supposed to be stiffer than the TDI mount and bolt right in. I really wonder if more vibration is felt in the car, since it's stiffer?
Nah, balls to that! Sometimes VW (and others) just say to renew bolts to save their own backsides. The only bolts I replace each time are hubnuts.vwlogue said:The manuals says to replace the mounting bolts every time the dog bone is reinstalled. Does anyone have the part # handy?
Well, thankfully I've never tweaked those. However, I have removed my passenger seat numerous times and the original bolts always go back in well and tight. Same with suspension strut bolts (strut brace attaches to 2 out the 3) and no doubt many other bolts.Wingnut said:And engine support bolts.
I am very interested also, my dogbone is starting to go out, but I was going to fail conservatively and get the Street Density Dogbone.3L3M3NT said:I will be able to report back in a week or so, but I'm going to try the 034 Motorsports mounts. I went with the Street Density Motor mounts and decided to get the Track Density Dogbone, so I'll find out how this combo works in a week when I get my car back.
http://forums.vwvortex.com/zerothread?id=3567029
What Durometer is the mount and what material are they using? They don't really provide you with any details about the Ultimate Dogbone mount on their siteim no hero x said:I had the ECS ultimate dogbone mount in my car for a bit over a month. I couldn't stand the violent vibrations anymore on the car (daily driven) so I went back to stock. I do not recommend it for TDIs.
