Wingnut
For those of you who have broken an anti shuuder valve nipple, this may be of help.
I had a member come by today after he broke his doing an intake cleaning last weekend. I thought we could use a splint, like a WD40 straw or something like that. But then it occured to me that I had some brass nipple fittings that would fit nicely in the empty spot created by the broken nipple
Here is the broken piece:
Mix up a small batch of JB Weld or similar (I used Permatex Cold Weld fast setting) and presto, you have a functioning anti shudder valve again:
The procedure took all of 15 minutes to complete and with the fast hardening version of the Permatex Cold Weld, he was on his way in no time.
