kromicacid
'05.5-'06.5 Jetta FAQ/DIY
DO NOT PM me for updates. I no longer have this car. IF someone else is interested in managing this list, please let me know and request the moderator to make yours a sticky, and delete mine. Again, I will not be updating or managing this post.
How to search the forums - http://forums.tdiclub.com/showthread.php?t=133579
FAQ:
Timing Belt Change Interval? - http://forums.tdiclub.com/showthread.php?t=171926
Break-in Period by Drivbiwire - http://forums.tdiclub.com/showthread.php?p=464223
2009 specific FAQ - http://forums.tdiclub.com/showthread.php?t=231417
All Bulbs - http://forums.tdiclub.com/showpost.php?p=2463457&postcount=2
Rear Air Bags for a 2005.5-2009 A5, with part numbers - http://forums.tdiclub.com/showthread.php?t=254295
Bluetooth FAQ - http://forums.tdiclub.com/showthread.php?t=260897
DIY Service:
Timing belt replacement - http://forums.tdiclub.com/showthread.php?t=264283
Service the DSG - http://forums.tdiclub.com/showthread.php?t=169356
BRM Rear Main Seal Replacement Info - http://forums.tdiclub.com/showthread.php?t=247903
Fuel Filter Replacement - http://forums.tdiclub.com/showthread.php?t=175046
Oil Change - http://forums.tdiclub.com/showthread.php?t=169124
Pollen Filter Replacement - http://forums.tdiclub.com/showthread.php?t=145852
Wiper Blade Replacement - http://forums.tdiclub.com/showthread.php?t=143882
Adjustment procedure to correct Jetta high beam aiming problem - http://forums.tdiclub.com/showthread.php?t=169800
How to Replace Key Fob Batteries - http://www.riskin.org/vwkey/
Change your service reminder from 5,000 miles to 10,000 miles - http://forums.tdiclub.com/showthread.php?t=200463
Rough idle problem - http://forums.tdiclub.com/showthread.php?t=176834
How to timing advance: TDI Cam Timing Adjustment (for rough idle) How-to (with pics) - http://forums.tdiclub.com/showthread.php?t=215202
Easy emergency brake adjuster access - http://forums.tdiclub.com/showthread.php?t=223592
How to inspect PD cam and lifters - http://forums.tdiclub.com/showthread...58#post2313958
BRM cam failure - http://forums.tdiclub.com/showthread.php?t=225918
Brake Flush - http://forums.vwvortex.com/zerothread?id=3184085 + http://forums.tdiclub.com/showthread...brake+bleeding
How to put your High Beam Holder back in easier - http://forums.tdiclub.com/showthread.php?t=233865
Rear mk5 brake pad and rotor replacement - http://forums.vwvortex.com/zerothread?id=4234178
HowTo: Defuel the '09/'10 Jetta (and probably Golf) TDI after a misfuel - http://forums.tdiclub.com/showthread.php?t=288971
DIY Mods:
Auxilliary Input using PIE VW02 and SAT Passthrough - http://forums.tdiclub.com/showthread.php?t=175146
Under Seat Drawer Install - http://forums.tdiclub.com/showthread.php?t=169765
Remote Windows - http://forums.tdiclub.com/showthread.php?t=109405
VAG-COM Tweaks - http://www.ross-tech.com/vag-com/cars/Golf5.html
Speedo Calibration - http://forums.tdiclub.com/showthread.php?t=158652
MPG adjustment - http://forums.tdiclub.com/showthread.php?t=111362
Dash Cubby - link dead - can someone post the PDF?
'10 Jetta / JSW / Golf Specific Information
Enable Remote Windows with VCDS - http://forums.tdiclub.com/showthread.php?t=265101
VWVortex A5 FAQ/DIY:
http://forums.vwvortex.com/zerothread?id=2374154
BRM Camshaft Wear related threads:
A number of owners of cars equipped with the BRM PD TDI engine have reported premature wear of the camshaft and related top-end components. Not every car equipped with this engine has these issues, but the number of owners experiencing this issue is not insignificant. In the North American market, the '05.5, '06, and '06.5 Jetta TDI were equipped with this engine. Other markets may feature this engine in different cars and different model years. Other engines featuring PD technology may or may not experience this issue. Below are a few links to threads with discussions on the issue.:
BRM Cam Wear Thread:
Eddif Cam Related Wear Thread:
http://forums.tdiclub.com/showthread.php?t=241279
As with most Internet forums, the people with the most problems speak the loudest. Rarely do people come on to sing the praises of something that's working well on a regular basis. If you have questions, please search for an answer and ask questions. Your experience may differ greatly from those posted on this forum.
FAQ:
DIY Service:
DIY Mods:
