Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Old February 26th, 2007, 10:21   #1
grandpatim
Default Quick instructions for oil change?
I searched for this and didn't find it if it has already been posted.
I want to change my own oil on my 2006.5 Jetta 1.9 tdi DSG.
I bought the filter ($12 NAPA, and proper oil 505.01 type) and need to change it now.
I've changed the oil on all my cars/trucks religiously since age 16, but never had a vw, and this "ain't no spin off filter!". Is the filter up inside the engine pan? Quick instructions would be appreciated!
Gracias!
Tim
grandpatim is offline   Reply With Quote
Old February 26th, 2007, 10:38   #2
euromade
TDI(s): 98 Beetle
Gracias!
Tim
yes, this filter is in a "cup" located on the top of the engine bay.
euromade is offline   Reply With Quote
Old February 26th, 2007, 11:08   #3
weedeater
Fuel Economy: 54/43/38
quick instructions:
1. drain oil.
2. refill oil.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old February 26th, 2007, 11:36   #4
LF06VWJTDI
LF06VWJTDI's Avatar
1. Use 32mm socket to remove bolt from oil filter. Unthread the oil filter located in the engine compartment. Take it out.
2. Use needle pliers to remove old gaskets and replace with new ones. Two of them. One top and one bottom.
3. Thread the new filter back into place.
4. Remove skid plate and get your oil pan ready. Use T30 torx to unscrew the back. Use T25 torx for the front.
5. Use a 19mm socket to unbolt the oil plug. Let oil drain completely.
6. REINSTALL THE PLUG AND TIGHTEN TO 20Nm
7. Reinstall skid plate
8. Put 4 liters of new oil from the upper engine compartment.
9. Measure it. You want it sliiiiiightly below full.
10. Cover back up. Enjoy your ride.
11. Next day, put another 1/3 liter to top it off.
12. You're good for another 8K-10K miles.
Hope this helps
PS: Thanks to WJDell for showing me how to do this.
'06 Jetta TDI Sport Edition Pkg2/DSG.
114,900 mi. since April 29, 2006. And counting...
LF06VWJTDI is offline   Reply With Quote
Old February 26th, 2007, 11:46   #5
tntdifan
19 mm socket for the oil pan plug.
The oil filter takes a 32 mm socket.
You need a torque wrench (cheap one is fine) to do this job properly. The oil pan is cast aluminum, and the threads will strip easily if you overtorque the plug.
tntdifan is offline   Reply With Quote
Old February 26th, 2007, 12:05   #6
grandpatim
That's great guys! Wow! LF06, Pics and all! THATS what I call a helpful reply! THANKS a ton Diesel pushers!
Old February 26th, 2007, 12:09   #7
grandpatim
This post with pics should be in the FAQs for the A5's
Old February 26th, 2007, 12:12   #8
grandpatim
Wait, looking at the pics, is that a torx head for the bolts holding the skid plate on? What size?
Old February 26th, 2007, 13:56   #9
LF06VWJTDI
LF06VWJTDI's Avatar
Actually, thanks to WJDell. He showed me the procedure step by step.
T30 back; T25 front.
Old March 2nd, 2007, 03:03   #10
subdvr99
Sorry, not to hijack the thread but quick question...
Has anyone had any problems with using a Pella extractor on our MkVs to change the oil without getting under the car? If it worked fine, you wouldn't have to lift the car, remove the skid plate, or the drain plug. Anyone?
--Mark
2006 VW Jetta TDI 5M, Pkg 2, Platinum Grey with Anthracite Leather (RocketChip Stg 1+, DieselGeek Short Shift Kit, 35% Tint, Blue Aspherical Side Mirrors, Euro LED Taillights - Amber Club!, OEM Projector Foglights, VAG-Com, Various Euro OEM Interior Parts)
Previous Dubs:
2004 VW R32
2001 VW Jetta 1.8T Wolfsburg Edition
1997 VW GTI VR6
1986 VW GTI
subdvr99 is offline   Reply With Quote
Old March 2nd, 2007, 03:44   #11
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
--Mark
Yes, just about 50% of us use the Pela, and let us not start that war again.
The Bently CD for the MKV Jetta has instructions for changing the Oil at the dealership, and the first instruction is to locate the VAGXXXX Oil Extraction tool. If this tool is not in your shop, you can elect to remove the belly pan, and drain the oil.
05.5 MKV TDI,Euro Tails, Rear Fog, aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old March 2nd, 2007, 11:28   #12
weedeater
some people have reported that the PD motor has some sort of obstruction in the dipstick path that makes using a Pella a challenge.
Old March 7th, 2007, 21:09   #13
gixxer1000
Thanks LF06 you just helped many newbies
gixxer1000 is offline   Reply With Quote
Old March 8th, 2007, 07:35   #14
scknight
My suggestion would be that if you are going to use a Pela-type device, that the first few oil changes, you do both, the Pela vaccuum extraction, and then the drain plug, and see if you personally are comfortable with the amt of oil that comes out after the Pela. Some people get almost all the oil, some only get 3 of 4 liters. As with anything you do to your car, its a judgement call.
Personally, I use the Pela, then drain to get the last 1/2 to 3/4 liter out. . . now if I could just figure out a reliable way to read this dipstick!
scknight is offline   Reply With Quote
Old March 8th, 2007, 08:32   #15
LF06VWJTDI
LF06VWJTDI's Avatar
Why do the job twice then?
If you're still draining, might as well drain the whole thing...
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.13361 seconds with 9 queries
[Output: 116.42 Kb. compressed to 95.14 Kb. by saving 21.29 Kb. (18.28%)]
