Old April 24th, 2007, 10:50   #1
eluwak
Default '05.5-'06.5 Jetta FAQ/DIY
Ok, I'm going to try to do this a little better than I have in the past but bear with me... Let me know what you guys want to see in here if I miss something
How to search the forums -> http://forums.tdiclub.com/showthread.php?t=133579
FAQ:
Timing Belt Change Interval? -> http://forums.tdiclub.com/showthread.php?t=171926
Break-in Period by Drivbiwire -> http://forums.tdiclub.com/showthread.php?p=464223
DIY Service:
Service the DSG -> http://forums.tdiclub.com/showthread.php?t=169356
Fuel Filter Replacement -> http://forums.tdiclub.com/showthread.php?t=175046
Oil Change -> http://forums.tdiclub.com/showthread.php?t=169124
Pollen Filter Replacement -> http://forums.tdiclub.com/showthread.php?t=145852
Wiper Blade Replacement -> http://forums.tdiclub.com/showthread.php?t=143882
Adjustment procedure to correct Jetta high beam aiming problem -> http://forums.tdiclub.com/showthread.php?t=169800
Fixing the rough idle problem -> http://forums.tdiclub.com/showthread.php?t=215202
P-D cam wear fix? -> http://forums.tdiclub.com/showthread.php?t=253137
DIY Mods:
Auxilliary Input using PIE VW02 and SAT Passthrough -> http://forums.tdiclub.com/showthread.php?t=175146
Under Seat Drawer Install -> http://forums.tdiclub.com/showthread.php?t=169765
Remote Windows -> http://forums.tdiclub.com/showthread.php?t=109405
VAG-COM Tweaks -> http://www.ross-tech.com/vag-com/cars/Golf5.html
Speedo Calibration -> http://forums.tdiclub.com/showthread.php?t=158652
MPG adjustment -> http://forums.tdiclub.com/showthread.php?t=111362
VWVortex A5 FAQ/DIY:
http://forums.vwvortex.com/zerothread?id=2374154
-Scott
Yeah... I used to have some TDIs
eluwak is offline   Reply With Quote
Old April 24th, 2007, 20:36   #2
esteeze
esteeze's Avatar
Fuel Economy: AVG 34MPG
Good stuff... thanks.
esteeze is offline   Reply With Quote
Old April 25th, 2007, 07:19   #3
eluwak
If you guys find something you would like added please post a link too... Or if it doesn't exist feel free to create the how-to
-Scott
Old April 26th, 2007, 19:14   #4
TDI73
TDI73's Avatar
Thumbs up Break-in Period by Drivbiwire
Break-in Period by Drivbiwire - "...This was the best "break in" description yet! "
15 Golf TDI 6MT
Past:
06 Jetta TDI 5MT (BRM)
99 Jetta TDI MKIII 5MT(ALH)
97 Golf MKIII 5MT
TDI73 is offline   Reply With Quote
Old June 12th, 2007, 15:15   #5
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
Perhaps this visual guide on How to Replace Key Fob Batteries?
http://www.riskin.org/vwkey/
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old July 1st, 2007, 20:53   #6
10then34
TDI(s): '06 Jetta
Fuel Economy: 44-48
How to reset the service reminder (which prompts the unsuspecting soul to bring his/her car for 5k oil changes).
10then34 is offline   Reply With Quote
Old August 30th, 2007, 09:02   #7
Zedbra
Zedbra's Avatar
A link to adding fog lights?
2005 Jetta TDI GLS: VNT17VB, 3 Bar, Malone Stage 4, BiXenon retros, OEM Fogs, ST Coilovers, OZs
Zedbra is offline   Reply With Quote
Old September 4th, 2007, 07:08   #8
buckeye96
TDI(s): 2005 Jetta ?
Instead of clogging this post up with requests, why doesn't everyone send eluwak vbmenu_register("postmenu_1701585", true); a private message and it will keep the postings here down to a managable amount.
buckeye96 is offline   Reply With Quote
Old January 11th, 2008, 04:17   #9
kromicacid
kromicacid's Avatar
How to change your service reminder from 5,000 miles to 10,000 miles
http://forums.tdiclub.com/showthread.php?t=200463
~2015 Passat TDI SEL w/ Sunroof + Fender - White
R.I.P
~2012 Passat TDI SE w/ Sunroof - Platinum Grey ~ 170k miles
~ 2006.5 Special Edition Jetta TDI ~ DSG ~ Graphite Blue ~ 65k miles
~ 2004 Jetta TDI GLS~ Platinum Grey ~ 110k miles
kromicacid is offline   Reply With Quote
Old May 22nd, 2008, 20:48   #10
Lightflyer1
Lightflyer1's Avatar
Rough idle problem:
http://forums.tdiclub.com/showthread.php?t=176834
Old May 30th, 2008, 13:37   #11
Steve-O
Steve-O 's Avatar
TDI(s): 2006 Jetta
Fuel Economy: 40-42 mpg's
EXCELLENT!
<CLAP.wav>
Tan 2006 Jetta 11/05 build date Package 1
You may go to hell, I will go to Texas.
Davy Crockett
Steve-O  is offline   Reply With Quote
Old June 9th, 2008, 13:55   #12
SBAtdijetta
SBAtdijetta's Avatar
Fuel Economy: Best 51.4mpg, AVG 38+ and climbing
Originally Posted by Lightflyer1
And a how to was writen up as well, otherwise the good info in that thread above starts at pg. 10 or 11.
How to timing advance: TDI Cam Timing Adjustment (for rough idle) How-to (with pics) by Hurst89: http://forums.tdiclub.com/showthread.php?t=215202
10 Jetta TDI 6spd Cup - Tune, Turbo back Exh, BBS, etc
02 Jetta TDI Auto beater - Stock - Soon to be for sale
06 Jetta TDI 5spd - VNT2556,PD150 Injectors,3"TB,Pelq.,etc., Never dynoed in final config. - Sold
Need help? I have VAG-COM
SBAtdijetta is offline   Reply With Quote
Old September 6th, 2008, 17:44   #13
donutman
donutman's Avatar
Fuel Economy: 50
Wow, great stuff. I bought the 06 Jetta in Jan.08 with 14,000 miles on it and had the dealer change the oil first couple times. I question if they are using the correct oil since the part number on my invoice is different that the correct vw part # for the correct oil. I have always changed my own oil on other vehicles, but was a little worried about a diesel. This information is very valuable to me. I hope you keep up the great work on this web site. Thank you.
donutman is offline   Reply With Quote
Old September 6th, 2008, 23:19   #14
Lightflyer1
Default Easy emergency brake adjuster access
http://forums.tdiclub.com/showthread.php?t=223592
Old October 17th, 2008, 14:23   #15
Lightflyer1
Default How to inspect PD cam and lifters
http://forums.tdiclub.com/showthread...58#post2313958
Page generated in 0.10316 seconds with 9 queries
[Output: 124.63 Kb. compressed to 103.07 Kb. by saving 21.56 Kb. (17.30%)]
