Old April 21st, 2007, 20:35   #1
TerribleTDI
Fuel Economy: First Tank: 46 City BABY!
Lightbulb MKV Fuel Filter Replacement Procedure
What is the proper procedure for replacing the fuel filter on the MKV TDi's?
Found ALOT of miscellaneous information throughout the board, but nothing definitive.
Doin' the 20k service and lovin' every minute of it!
TDi: my dirty little secret...
2006 VW TDi Jetta: North Sea Green, Pkg 1, DSG, DP Box, Scan Gauge 2, tinted, Zender spoiler.
TerribleTDI is offline   Reply With Quote
Old April 21st, 2007, 22:11   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
http://forums.tdiclub.com/showpost.p...1&postcount=18
And get yourself a service manual, too!!
http://www.tdiparts.com/catalog/prod...roducts_id=518
HTH
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old April 22nd, 2007, 07:44   #3
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
Order your Fuel Filter based upon (include) the VIN Number.
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old April 22nd, 2007, 09:21   #4
TerribleTDI
Thanks for the beta. Alot of new things have come available for the MKV since I was last drooling on this site! Been researching biofuel policies to the point that I cant keep up with my fellow TDi's!
Q: For those of us who dont yet have the Bentley Manual what are the correct placements for the funky blue gasket and the washer?
Old April 22nd, 2007, 10:11   #5
40X40
Experienced
The big gasket goes on the fuel filter cap. The little multi-hole gasket goes on the center pedestal inside the fuel filter canister just under the fuel filter cap. The METAL washer goes under the sealing bolt for water extraction located right in the middle of the fuel filter cap. Your car likely does NOT have this bolt and so doesn't need the metal washer.
It makes perfect sense when you take it apart.... really!
Can someone post a picture?
HTH
Bill
Old April 22nd, 2007, 12:15   #6
DieselDavid
DieselDavid's Avatar
Fuel Economy: Typically between 53 and 57 MPG per tank
Smile
This is a picture posted by another forum member at his web page along with other pictures and instructions for changing the fuel filter in our cars.
http://nofreerides.blogspot.com/2006...er-change.html
∙ 2005.5 reflex-silver NewJetta TDI 5-speed manual, 143,196 miles
5-tank averages: 47.23 MPG current, 57.05 MPG best, 42.24 MPG worst
∙ 2015 candy-white Passat SE TDI 6-speed manual, 19,574 miles
5-tank averages: 50.17 MPG current, 52
.88 MPG best, 48.34 MPG worst
DieselDavid is offline   Reply With Quote
Old April 22nd, 2007, 12:27   #7
40X40
Experienced
Thank you, DD
Bil
Old April 22nd, 2007, 17:29   #8
TerribleTDI
Default Some reference pictures
Pic 1: Car off? Good, now unbolt the stars and wrap the fuel filter housing with a rag. Make sure it's against the housing good so that any drips dont go where you dont want them. Notice the little "tab" on the top of the housing facing you? That's for a screwdriver to break the "seal". Be gentle, and it will come off easily. Prop the top to the side.
This is what you will now have in front of you. The little blue gasket (looks funny) is currently stuck under the housing top.
Pic 3: GENTLY pull up while twisting. Its not difficult, but is actually simple/easy. It will take some force, but be gentle with it as other have said to keep things clean. You might even want to wear eye protection if you tend to reef on things.
Pic 4: Filter is out! See, not so bad now was it?
Pic 5:
New filter goes in smoothly over the center filter post.
Pic 6:
Install the new little olympic gasket into its recessed housing as can be seen here. It only goes one way so you cannot mess this one up (but go ahead and try on your own ). Edit: Now, replace the green housing gasket and then the housing top. I guess the fuel system with prime if you turn your key to "on" (dont start it though) a few times. Thought it was a "closed loop" fuel system, but after letting it prime the VW fired right up with no hiccups.
Pic 7: NASTY old filter! I did have some low throttle hesitation and "stammering" prior to changing the filter. That has ceased completely now that it has a new filter. Ive decided that 20k miles is FAR too long for these filters, and will be changing mine every 10k miles or every other oil filter. Took all of about 20 minutes enjoying the air while taking photos. Hope this thread can help some of us TDiers in the future!
Old April 22nd, 2007, 17:38   #9
TDI 4 RD
TDI 4 RD's Avatar
Fuel Economy: ~38 mpg (first tank); 41.2 (second tank); now averaging ~42 mpg.
I thought there was a need to dump out the contents of the filter housing, once you have the old filter out, and before you put the new one in. Is that not the case? Thanks.
2006 Jetta TDI (build date Oct. 2005). 185000 miles. Mods: Euro LED Tail Lights, Amber Mode; Rear Fog Light; Aspherical Mirrors (Blue Tint); Osram SilverStar Hi/Lo Beams; DieselGeek SkidPlate; Hella Dynabeams; TDIFrostheater. Best Tank: 632.9 miles on 11.8 gallons = 53.6 mpg (06/08; cruise control set at 65 mph for most of the tank). Member of the 700 club (04/23/08).
TDI 4 RD is offline   Reply With Quote
Old April 22nd, 2007, 17:48   #10
TerribleTDI
Ah forgot to mention that I used a turkey baster to siphon out the remaining stuff in the bottom of the filter housing, and used a shop towel to soak up the rest. Got everything out ! Dont know if it was needed really.
Old April 22nd, 2007, 19:58   #11
Lightflyer1
Lightflyer1's Avatar
You also forgot to mention changing the seal on the cap.
2015 Beetle TDI.
Old April 22nd, 2007, 20:39   #12
10then34
TDI(s): '06 Jetta
Fuel Economy: 44-48
Thanks.
Is there any difference in the change procedure between the earlier and later '06 models ? The filter cartridge seems to be slightly different between the two (there is a VIN cutoff between the two).
10then34 is offline   Reply With Quote
Old April 22nd, 2007, 22:18   #13
TerribleTDI
Yah, yah, yah...thanks! Edited accordingly.
Old April 23rd, 2007, 04:06   #14
DieselDavid
Smile
Nice pictures! Two more things to add from my first experience changing the fuel filter.
1) The cap with the 4 hoses on its top will be damp with diesel fuel when we lift it up. Put towels underneath it or wrap a plastic bag around it to keep the diesel fuel from dripping on the big fat hose directly below.
2) When replacing the cap mine did not push down into place on top of the canister containing the new fuel filter. So I positioned the cap into place, inserted the 5 screws slightly, and then gradually tightened those 5 screws in a star pattern (like we use when tightening the wheel's lug nuts). The cap slowly went into place in a fairly level manner and eventually it was seated correctly. No leaking happened afterward. I think the 5 screws are size Torx T-30.
Old April 23rd, 2007, 07:09   #15
TDI 4 RD
TDI 4 RD's Avatar
A tip based on a mistake I made - be careful tightening the bolts for the filter. I nearly stripped one by over-tightening (I didn't realize the Craftsmen torque wrench I used would not "click" because the required torque setting was too low).
Worldimpex sells the bolts individually for about $.30.
Page generated in 0.18200 seconds with 9 queries
[Output: 129.94 Kb. compressed to 108.33 Kb. by saving 21.61 Kb. (16.63%)]
