The following are LINKS to the various components involved in doing the ALH engine install in my 84 Tin-top Vanagon. The subject matter is mostly in chronological order. In some links, there will be more than one topic. The narrative is generally there but may be found in the posts that follow. Also, in about all links, it will be necessary to scroll down to find what the reference subject might be. Just
use the Post Numbers to find the subject.
I believe this will be very helpful in trying to decipher this huge Thread.
Note: The TDI Club Web Site software was updated about 2018 or 19. I did make an effort over a couple of years to correct the post page numbers that changed due to the software update. (The Post Numbers are the same.)
Note: All links have been updated. In the topic you wish to dig thru, look at the Post # then click on the link which will take you to the page. Then, scroll to the Post(s) you are looking for.
I hope this helps everyone. Shoot me a message if you have a specific question rather than posting.
Transmission (this topic is updated with New Links per new website software, 1/2/21)
Post #4, 5 & 8
http://forums.tdiclub.com/showthread.php?t=276798
Shifter Mod for the DK Trans, Post #336,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-12
Comparing a 5-speed with a 4-speed (gearing)
Post #855,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-29
Pulled trans to look for whine
Post #1298,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-44
Flywheel, Clutch, etc., & Related. (this topic is updated with New Links per new website software, 5/17/21)
Post #10,
Post #917,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-31
Post #937, 944,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-32
Starter modification for clearance of the G-60 SMF (I later changed to the TDI starter)
Post #953,
TDI Pilot Shaft
Post, #1279, see first photo,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-43
TDI Starter Upgrade
Post #1283,
These are pics of cracked clutch disc
Post #1307,
Below, I ordered the DMF but no documentation of install. I think I installed it May, 2017
Post #1315,
Fuel Tank (this topic is updated with New Links per new website software, 10/13/20, 5/17/21)
I tried to rehab a rusty tank. I am only linking the photos/narrative showing how I modified the fuel level assembly of the Vanagon fuel tank to use the Jetta level sensor.
Beginning with Post #122 & #150,
https://forums.tdiclub.com/index.php?threads/alh-tdi-engine-transplant-into-84-vanagon.276798/page-5
Cluster Modification, Jetta cluster and Related (this topic is updated with New Links per new website software, 5/18/21)
Posts #154, 163 and 164,
https://forums.tdiclub.com/index.php?threads/alh-tdi-engine-transplant-into-84-vanagon.276798/page-6
Post #166,
Post #186,
https://forums.tdiclub.com/index.php?threads/alh-tdi-engine-transplant-into-84-vanagon.276798/page-7
Post #474 (last two pics),
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-16
Post #616,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-21
Oil Pan and Suction Tube in Pan (this topic is updated with New Links per new website software, 5/18/21)
Post #76,
https://forums.tdiclub.com/index.php?threads/alh-tdi-engine-transplant-into-84-vanagon.276798/page-3
Post #159,
Post #182,
Post # 286,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-10
Post #345,
Post #378,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-13
Post #551,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-19
The link below is kind of a repeat but has good info
Post #895, 898,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-30
Stainless Steel Oil Pan
Posts #1015, 1016,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-34
Engine Photos and Related (
this topic is updated with New Links per new website software, 7/20/21)
Post #62,
Posts #236 & 237,
https://forums.tdiclub.com/index.php?threads/alh-tdi-engine-transplant-into-84-vanagon.276798/page-8
Post # 261 & 265, show making room for the engine in the bay,
Post #497, random pics of the engine bay,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-17
Post #587, engine start-up narrative,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-20
Mounts, Engine, Transmission & Related (this topic is updated with New Links per new website software, 10/2021)
Posts #241 & 253,
https://forums.tdiclub.com/index.php?threads/alh-tdi-engine-transplant-into-84-vanagon.276798/page-9
Posts #258 & 259,
Post #290,
Post #310,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-11
Post #372,
Posts #383 & 384,
Posts #498, 502, & 503,
Broken engine mount bracket
Post #875,
Post #925,
Post #1198,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-40
Down Pipe, Exhaust & Related (this topic is updated with New Links per new website software, 12/13/22)
Post #259,
Post #271, 274, 281,
Post #294,
Post #511 & 519,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-18
New Custom Made Stainless Steel Exhaust System
Post #1302,
Coolant pipe return (small black metal pipe mod) and Coolant Flange on the end of the head (
links below updated 12/13/22)
Post #266 & 267,
Post #274,
Post #367,
Below, is a link that shows the Coolant Glow Plugs and mounting hardware (scroll down to see)
Post #378,
Inter Cooler & Related (this topic is updated with New Links per new website software, 11/12/21)
Post #290,
Post #331,
Post #365,
Posts #452, 458,
Post #496, 509 & 510,
Post #604,
Post #1021,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-35
EGR Modification (this topic is updated with New Links per new website software, 12/13/22)
Post #299,
Post #495,
Post #525,
Air Filter Box & Related (Coolant Expansion Tank) (this topic is updated with New Links per new website software, 12/13/22)
Post #317, 318 & 330,
Metal Coolant Pipes (Rehab) (this topic is updated with New Links per new website software, 12/13/22)
Posts #327, 328,
Accelerator Mounting & Related (this topic is updated with New Links per new website software, 7/14/21)
Post #348,
ECU Location & Associated Fuse Panels and Wiring (this topic is updated with New Links per new website software, 12/13/22)
Post #355,
Posts #393, 394, 397, 400, & 402,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-14
Posts #407, 414, 417,
Posts #425, 431, & 432
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-15
Posts #436, 439,
Posts 461, 465 & 467.
AC Compressor and Hoses (modification to fit TDI Compressor)
(updated with New Links per new website software, 6/16/22 & 12/13/22)
Post #378,
Post #520, (inside the AC compressor),
In the link below, you’ll see I continued to have issues with AC leaks
Post #1060,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-36
Windshield Washer & Related (this topic is updated with New Links per new website software, 12/13/22)
Post #463,
Vehicle Speed Sensor & Related...
Post #467,
Post #694,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-24
Post #1003,
Post #1121,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-38
Clutch and Brake Switches and Related (this topic is updated with New Links per new website software, 12/13/22)
Post #474,
Random Pics, unspecific ...
Post #523 & #536,
Post #543, More interior & AC,
Fuel Filter Mount & Related (this topic is updated with New Links per new website software, 12/13/22)
Post #544,
Oil Dip Stick Location & Related (this topic is updated with New Links per new website software, 12/13/22)
Post #551 (scroll down),
E-Vac Scavenger Crankcase Gas Handling System (blow-by evacuation)
Posts #569 & 570,
Post #597,
Engine Cover
Post #580,
Post # 564,
Road Trips & Related (this topic is updated with New Links per new website software, 12/13/22)
Trip to Western Kentucky
Post #681,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-23
Trip to Ypsilanti, Michigan, TDI Fest, 2012
Post #707,
Fuel Stats on the Ypsilanti road trip
Post #713,
Summary list of To Do Things after the Ypsilanti road trip
Post #740,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-25
Out with grand kids, etc.
Post #863,
Road trip to Bethel, Maine, 2013 TDI Fest
Post #1141, 1148, 1150, 1152,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-39
Post #1173,
Getting ready for a road trip to Alaska
Post #1241,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-42
Post #1269,
Injection Pump Re-seal and related (
this topic is updated with New Links per new website software, 2/11/23)
Re-sealing the IP was done to address a hard-start issue that I had experienced from day one. Long story, short the issue was a bad ground at the transmission mount.
Post #770, 777, 778, 779, & 780,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-26 (link update 1/19/21)
Post #792, related to IP re-seal,
https://forums.tdiclub.com/index.ph...ine-transplant-into-84-vanagon.276798/page-27
Post #806, IP shut-off valve voltage,
Dash Removal to Replace Fan and Related (
Post #1022,
Post #1047,
CV Joints & Related (this topic is updated with New Links per new website software, 2/11/23)
Post #1066, 1069,
Sound Deadening (
Starts in the link below as narrative only, then pics much later
Post #1130,
Post #1184,
Power Steering Install (this topic is updated with New Links per new website software, 2/11/23)
Post #1183,
Exhaust Gas Temperature sensor and gauge install (
Post #1250,
Coolant Temp Sensor in Oil Cooler Coolant Return Hose (this topic is updated with New Links per new website software, 2/11/23)
Post #1251,
Note: I did install a DMF some time prior to the Summer of 2017. However, I did not document with photos and narrative. It works great!
