Update
Alright!........... High-5 for sure! The E-Vac Scavenger
now pulls a nice vacuum! (smiling face here) As I stated in the last update (ate crow), locating the device pre-CAT caused back pressure as opposed to a vacuum. Now, with the engine
at idle, there is a very distinct pulsating vacuum that will hold my spit wet finger on the end of the nipple of the CCV puck........that's encouraging!..........
EDIT: If you are lost concerning this Update, go back to Post #569 which shows when I first installed the E-Vac Scavanger......
So, today after picking up everything from my welder, I installed the hose (extremely modified, see pics) and the E-Vac unit. I was so pleasantly satisfied that I just stood there for a moment and admired the smell of diesel burning.............(smiling face here!)
Anyway, here are some pics (
Comments are at the top of each photo)
But, first this pic provides "some" proof that I've had the engine started (thanks brother for the help, it definitely would have been a challenge without you). Maybe we will get that video up and running...
Yep, that's a *eff peanut butter container. Nope, diesel fuel will not deterioate it. That plastic jar has been sitting on a shelf in my garage almost a year with diesel fuel in it......... just testing Also, the fittings are secured with JB Weld....good stuff!
This is side shot showing the STAINLESS BRAIDED hose..... Yep, those are El-cheapo hose clamps with cute little wing tightners on them (choice of yellow, blue, red or black...or leave 'em off). (More about how I did it below)
This is another angle of the stainless braided hose "connected" to the OE CCV puck
This is an excellent shot showing the stainless braided hose
Below, you can see the hose as it passes between the Intake and Valve cover just above the engine mount bracket and adjacent to the TB cover. Also, there on the left is the 'modified' EGR with the Turbo boost connection.
The pic below is a little farther down stream as it rounds at the end of the engine at the TB cover...
In the pic below, you can see the stainless braided hose as it passes across the back of the engine. The red thingy you see there is my creeper on the floor under the Van.
Below, in this pic, you can see where the stainless braided hose is coupled with the black braided hose heading down to the E-Vac Scavenger!
Here, (below) you can see the E-Vac Scavenger. The CAT is to the right and the short 12 inch glas-pak muffler is to the left........
Below is just a close-up of the E-Vac and where it is located
Okay, as for how I "connected" the Stainless Braided hose to the OE CVV puck ........ my secret! It is there to stay, but can be removed! Sure, no fancy clamps, but, gees, time is running out for me!......maybe some fancy stuff later!
Oh, I almost forgot to say, it was a PITA cutting the welded bung off the exhaust pipe using the old fashion hacksaw!
