Friday night Update
Okay, here are a few more pics as I promised. (
Comments are at the top of each pic.)
The following pics show the oil fill tube from the oil pan to the top of the customized cap at the license plate door.
Below is a shot of the oil fill tube where it is bolted to the oil pan. As posted previously, the tube is from a 2.0 Vanagon Air-cooled engine.......customized to fit my application.
Below is a shot from another angle. Notice that the clearance for the exhaust and Serp belt is pretty much balanced....
In the pic below, you are looking up at the front side of the license plate door.
In the pic below, you can see the customized cap of the oil fill tube. I bored a hole in it to accommodate the "cut-off" TDI dip-stick tube .......JB Weld and friction fit holds it in place. There is a flat rubber seal for the cap. Also, I have cut the dip-stick to a shorter length...... it may need additional trimming.
And, another angle of the Dip-stick. That's the Intake piping above the dip-stick....the Intake are travels right-to-left to the Turbo.
Next are some random shots of the engine top-side.
The engine is basically finished on top. I need to connect the electricals to the add-on oil pressure sensor (had to order a new sensor), connect the add-on temp sensor and tiddy up the Intake piping and install the plexi-glass shield cover over the InterCooler area............ and, install the E-Vac Scavenger Kit for the CCV system.
The pic below is of the left side of the engine ....... you can see that the CCV system is not finished. I hope to address that next.
This angle is of the right side of the engine......... center-top, you can see where the "return" fuel line goes thru the firewall using the old OE set-up (nipple on each side). I know that some of the Vanagon Gurus eliminate that fitting....... this one was cleaned and inspected. I believe it will be just fine. Also, notice that the power steering reservoir is just that and nothing else.....a line goes in and one out back to the pump .....I will install PS lines and R&P up front later!
This is another angle of the right side of the engine bay.
The pic below is another angle of the left side of the engine. Notice that the clamp is not on the Intake pipe .........and, yeah, I haven't eliminated the EGR diaphram pipe yet.
As I mentioned above.........the E-Vac Scavenger system needs to be installed. I am amazed by the folks at verociousmotorsports.com. They took my screwed-up order and straightened it out and rushed it to me... Brian was really great with his help!
So, my goal is to start the engine on Monday or Tuesday!
