AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
Okay, a few tidbits for an update.
1. The coolant temp problem was a corroded splice. I plugged to a new temp sensor and got the same reading (418f) and the same with the old sensor. Looked at schematics, the ECU monitored side of the Temp sensor goes directly to the ECU (no plugs). So, I looked for a splice ... found it. It was something I did when dealing with the hard start issue. ... problem solved.
2. Intercooler Fan - Again, it was a corroded crimp at a connector .. dang, I removed the entire IC and Fan before finding out that it was only a bad connection.. problem solved.
3. As mentioned previously, in replacing the shifter linkage on the tranny (had to be removed to fill with oil), I screwed things up. It would not shift properly. Well, apparently the splined arm went on incorrectly (Yeah, I know, it supposed to go on only in one position.). So, after correcting the problem, the tranny shifts better than ever before, and not that it shifted bad previously.
Well, as far as I know, the ALH Vanagon is ready to head north, other than a little detailing inside and out, which I plan to do tomorrow afternoon and then pack!
So, unless there is something major, I'll not be posting here for a while!
Oh, one last comment, I am amazed at the "damage" salted snowy roads done to my nice clean engine on the bottom ......... sucks really bad!
Again, here is a link to our Road Trip to Alaska: http://forums.tdiclub.com/showthread.php?t=417129
