In preparing for the Road Trip next week, I've been doing maintenance on the Vanagon over the last few days, as I found time.
Things I've done or in the process of doing.
-New fuel tank as previously posted
-Engine oil out
-Tranny oil out
-Filters out (oil, air and fuel)
-Left side engine mounting bracket out as well as carrier bar (going to the welder tomorrow)
-Turbo/manifold off for re-locating EGT sensor and removal of the exhaust port to the once EGR system (This will be a "cut-off and weld on a cap" deal.)
-Coolant out.. new T-stat and ECT sensor installed
-Exhaust system completely off ........ needs major rebuild. It was/is in bad shape due to a number of reasons. I plan to do more than a patch-up job. However, I do intend to completely replace the entire system when the Road Trip is over. I have all the parts, however, not enough quality time to see that the job is done right....... gees, I'm at the 11th hour
Things still to do:
-Rear brakes, inspect and adjust (seems the auto adjuster isn't working)
(Done)
-Remove front rotors for a slight mill job
(finished)
-Replace front disc pads
(installed, and greased front wheel bearings)
-Install a "new" speedometer cable from wheel to counter box
(installed as well as a new VSS)
-Re-do the grounding connections in the dash. I have too many items grounded together ......... my understanding this can affect readings on gauges, etc.
(finished)
-Install new O-rings in AC system (found one to be leaking)
(fixed..)
-Replace Turbo pressure hose over to the InterCooler
(installed)
-Install a dedicated positive wire for power to the Deep Cycle Battery on the Popup Camper
(installed)
Not that the upcoming long distance Road Trip is something new, I am working on a list of things to take along, such as tools and spare parts. Of course, there's a limit as too how much one can drag along. I tend to take more than enough tools and rely locally for parts. So, in the parts department, I'll keep it pretty basic. I'll post a list of things later.
Here is a link to the Road Trip thread I've started:
http://forums.tdiclub.com/showthread.php?t=417129
