Update
Since the last update, I have installed the "conduit" for the cables. It extends from under the back seat on the left side of the rear heater, down under the van body up to and thru the rubber grommet next to the heater hoses below the front dash.
As I stated in the last update, I was able to install inside the 3/4 inch flexible conduit two cables containing 15 wires of 22 gauge and one cable containing 9 wires of 18 gauge.
After going over the wiring schematics, it appears that I will be using all but one of those wires.
Here are a few shots of what it is looking like, front to rear of vehicle.
(all comments are at top of photos)
This is pic of the conduit with cables just below the dash of the Vanagon.
This pic is just below where the conduit comes out in the cabin at the dash (previous photo). As those who know, the conduit here is just to the left of the gear shifter box of the Vanagon.
This pic is from an angle a little farther back. You are still looking toward the front of the vehicle and the gear shifter box can be seen there in the background on the right. Notice that the support is a segment of Serpentine belt secured with two stainless steel screws.
This pic is a little farther back looking from the right side of the vechicle. The gear shifter tube can be seen with the new center bushing. Also, another securing strap can be seen. Also, in the pic below, if you look at the upper left corner you can see a metal strap hanging there. Well, to put things into perspective, that strap holds the cross-over vent pipe on top of the fuel tank. When the fuel tank is re-installed this section will not be visible from below or anyother angle..........those that know Vanagons, knows!
This pic shows the conduit with sweep elbow at the point it goes up and under the back seat on the left side of the back heater. It will have a securing strap attached later.
This pic shows the three cable bundles laying across the rear heater extending over to where the ECU and fuse panels will be located. See previous posts and photos relating to this area and the ECU. Yeah, that heater assembly needs a good cleaning!
In this last pic, you can see the area where the ECU and fuse panels will be sitting. The wiring harnesses have been temporarily removed. The large access hole and two holes for the coolant pipes to the heater can be seen as well.
Also, as I stated above the last photo, I removed the two wiring harnesses for some additional custom modifications. I shortened the GP circuit by about 8 inches. I tape warped the custom wire bundle containing circuits for the PCV heater, coolant level sensor and MAF sensor. I used some liquid electrical tape to seal all the "branches" to protect the wiring from water. Everything has been wrapped in good electrical tape. However, I wanted the added protection of the liquid tape, especially at those branches.
