Update/Comments
Well, we are back at the Ponderosa! I decided to swing back home to address some of the gremlins that keep nagging at us and the Vanagon!
Although we had plenty of fuel, it's hard to pass up a good buy. So, at the last fill-up, 212.1 GPS miles, it took 6.148 gallons to completely full.... 34.49 mpg.
That involved about 90% on-the-road miles running at about 60 mph average with AC on. Most of the roads had 55 mph speed limits. I did do about 20% at 65 mph and a little faster but never over 70 mph. And, we are loaded pretty heavy (wife, brought everything but the kitchen sink
It seems that the sweet spot is between 63 and 67 as far as road and engine noise. On the level and slight inclines the engine noise is barely noticeable! So, running 70 mph would be okay! The roar or resonance is most noticeable in the 35 to 45 mph range in 4th gear........as it moves up and away from 45 mph the engine really smooths out. At 65 mph, the RPMs hang around 2875, based on ScanGauge!
Tomorrow, I plan to address several problems.
1. Oil leak(s) ....... drain plug (Gees, give me a break), and what appears to be around the pan to block on the Turbo side near the TB end and in the center along the dip-stick side of the engine. Also, the rear oil filler tube leaks a little where the top plastic piece fits on to it (see previous photos several posts back). There may be a leak here or there in the weld seams.......not really sure! And, to settle my mind (and those thinking out-loud), I plan to test the E-Vac System at high RPMs. Previously, I only tested it with the engine at idle, which proved to be okay! I don't think it was the reason for the temporary "paper towel plug" to come out of the OE dip stick tube and cause the oil mess. That paper towel plug was in very loose and hand been there for weeks!
2. Brake pedal not popping back to the top position. It got worse all day long.....really irritating in stop and go situations! As you may know, if the brake switch is activated, the ECU cuts fueling to an idle, even if the accelerator is on the floor........and, no cruise!
3. Overhead AC duct to the front needs re-postioned. Apparently when I had it out thinking the Expansion Valve was plugged, I didn't get it pushed forward enough to install the screws in the correct holes (not a big deal, just needs addressed).
4. Install an in-line cut-off valve for the heater coolant........ the OE valve lets a small amout of coolant circulate .....warm feet! Otherwise, the AC handled the issue just fine. I did know this was a problem before hitting the road. I manually pushed the valve closed. But, apparently it still allows some flow due to age! The rear heater valve works like a champ!
5. Add a charge of oil to the AC ....... gut feeling that would be a good idea! The AC really is impressive...... the compressor kicks on and off quite nicely. As I previously noted, I did install a green LED on the dash to reflect when the compressor is in operation.
6. The InterCooler fan needs to be changed to Ignition Switched Power with a relay. That thing can run on for 10 minutes after the engine is cut-off!.....especially on these 90F + days!
I'm sure there is something I'm forgetting at the moment!
So far, the plexi-glas barrier at the InterCooler is holding up okay.....no cracks, yet!
