i guess we shall see, and i did mention that they can wear and lead to sloppy boost control, but i would be very surprised to see a control ring worn to such a degree it would lead to anything more than a little slop - i know i've seen a pic of one, but i would have to bet wear that bad has to be pretty rare. now i don't take turbos apart day after day, but i've done enough, and seen enough from others, to know that most all of the time there is no wear. my wifes 220k mi vnt17 i took out ~last year showed ZERO signs of wear. been on the car for a long time...so why one could wear so bad? bad metallurgy? combined with a car in a state of tune/hardware issues + the type of driving, such that the control ring is bouncing around a ton - i suppose.
I've taken apart enough myself to know it's a lot more common than you think it is. Biggest factor is type of driving. Cars that do a lot of stop and go city driving, they wear faster because the vanes are being moved through their full range of motion more frequently and are also likely to experience more soot build up that ends up meaning the vanes require more force to move than one that is under a more consistent higher load on the highway.
When I was in the Bay Area, I saw numerous cars with only 100k miles that had a worn out vane mechanism, because they were largely stop and go cars. This is also why whenever someone would ask me what kind of car they should get, I first ask them another question in response: what is the most common type of driving you do?
If the answer came back as a lot of around town and stop and go, high traffic driving on local freeways that come to a stop often, I tell them to buy a hybrid or EV instead. Diesels just end up being more problematic and expensive in that environment, especially ones equipped with a VNT turbo. But, if you do a ton of long distance highway driving, there is no better tool than a diesel, and the diesel will be a lot happier in that environment, give you far fewer issues than they do in frequent stop and go driving. This is even more true with modern diesels equipped with DPFs...
And at this point, when you're talking an ALH, it's more than a 20 year old car now. Band-aid fixing an old turbo is rarely going to give you the long-lived fix you hope for. If it's still on its original turbo, that's more than 20 years of wear on that lever and control ring.
