spifflifkin
I did some Googling over break and found a few things to look in to.
There is a TSB from VW regarding parasitic drain: https://pics.tdiclub.com/data/500/TSB_27_08_04_Matrix.pdf
In VWVortex there is a thread about aftermarket radios not turning off the Monsoon Amp. https://www.vwvortex.com/threads/mk...ion-and-modifications.9487666/#post-115282118
I installed a new aftermarket radio recently. There was an after market one in there when I got the car. With the new radio I had Crutchfield make an adapter harness. One interesting note is that the power to the radio I took out was run to a switched fuse on the fuse panel. The new radio gets power through the wiring harness.
I'll check with our electrical guy here to see if he has a current clamp.
