burpod
teh stallionz!!1
- Joined
- Nov 27, 2004
- Location
- cape cod, ma
- TDI
- 82 rabbit vnt ahu, 98 jetta vnt ahu, 05 parts car, 88 scirocco.. :/
Malone Tune Analysis – What’s in a Malone tune?
This is the short version.
So what’s in your malone tune? Ever wonder? Stage1? Stage 5? here’s the skinny…
This is coming from me, a 100% tdi enthusiast. you could find this out all yourself if you got an mpps and downloaded the free edcsuite. i'm posting this very short synopsis with as much objectivity as i can
A malone stage3 is what I would call the “base” tune. Fuel is set to max “50mg” (stock alh limits). Of course, 50mg is meaningless because it’s not a truly calibrated tune, how much fuel would depend on what pump/nozzles you have + QA position (where it’s hammer modded to). This goes for most every name-brand tune. 0-50mg is what it says, but that’s not what it means. On a factory tune, of course, 40mg should mean 40mg pretty accurately. on a malone or other tune, 40mg might mean 32mg or it might mean 60mg in reality, and that will vary depending what you have and based on rpm..
A stage 1 or 2 fueling is just limited to something like “45mg”. Rest of tune is the same as a stage3. Every map.
The stage3 just takes a stock tune and fudges up the last column or two of the pump map for more fuel (longer injection duration), fudges up basic limiters for boost, timing, and fuel, deletes egr error codes etc. trivial stuff. It also fudges up the boost in the last couple columns of fuel for 40 and 45mg. Below that, it’s just a stock boost map (makes no sense when fueling has been changed). However, fueling goes to 50mg, and there’s a significant jump in injection duration between 45 and 50mg. But regardless, boost maxxes out at 45mg. not sure why you would want to do that, but that's what it does. it's virtually a stock tune with literally a few maps fudged.
(for anyone who understands this, the pump map which is [fuel X rpm X duration] is going to be very different for different pump/nozzles. you can't just use the same stock pump map fudged up for every combo FWIW).
The stage4 is the exact same tune as a stage3, except the last couple columns for 40 and 45mg are fudged up a bit more. Fueling still goes to “50mg” as always and there’s a very large jump between 40mg and 50mg. The entire rest of the tune is the exact same.
The stage5 takes it one step further, it fudges up the boost in the last couple columns a little bit more!! but the entire rest of the tune is the exact same. yet still, the 50mg boost is absent. only goes to 45mg
The most problematic thing about this all, is every tune uses the same timing maps. And they are horribly over-advanced (this is subjective
). The engine is choking to death. But he only changes the timing maps for coolant temps for 70C – 86C (the last few hot coolant temp maps). All the colder temp timing maps are simply stock timing maps.
Take it or leave it! If you think you got a stage5 custom tune, think again
if you got a stage4 for your big tonky 11mm .230s and 1752 with hood stack, well, you actually have the same tune as your little buddy who coudln’t afford as much and has a vnt17 10mm .205s. Read in over 3 dozen malone tunes from all kinds of setups for 10mm/.205s and vnt15 to 11mm race520s and 2260. even the 2260 tune either has a stock vnt15 n75 map or it might have something different like a vnt17.
screenshots always help with this, but i won't post those
the summary is, stage1-5 are the same exact tune. the only difference is 1-2 have fuel limited to "45mg" or so. stage3+ goes to "50mg". from stage3 to 5 the boost map is just fudged up more in the 40 and 45mg columns, and thats it. but fueling always goes to 50mg on stage3+ so you can do the math if you want.....
edit- this only applies to ALH/VE tunes. but IMO, if you can't get VE right.. well... it's doubtful you put much time into the more "complicated" types. i've seen a few logs heh
