DPM
Seems like the steering sensor is exactly one turn out of place, if it's showing -366deg.
Sounds like you've got the wrong master cylinder. It should only have one connector for your model year car. I am assuming you have the MK60 and NOT the MK20?ward1e said:Hi,
I live in the UK I'm in the process of doing this modification and I have managed to get the master cylinder, brake booster, combination sensor, steering angle sensor/cancelling ring, ABS/ESP pump, and ESP ECU for £250. I have all the relevant connectors on order from VW.
I have been studying the wiring diagrams in the bentley manual / elsawin and I can't work out why there are 2, identical 3 pin connectors on my master cylinder. One of them is mentioned as Sender 1 for brake booster -G201- the other one looks exactly the same but is at the end of my cylinder (away from the brake booster), but what is it for? Does it need to be wired up?
Any info will be appreciated.
Cheers
Ben
Well, that is going to be a very big problem. You will definately not be able to code or configure anything if that sensor is needed and can't be found by the ABS computer.However though there still seems to be no information how they are both wired up to the ABS ECU. So still any help would be appreciated.
Part numbers from PAGE 1 of THIS threadward1e said:I just wondered can anybody post a picture of a MK60 ESP Master cylinder and servo - prefereably from a right hand drive, but left hand drive will be better than nothing. Or just the master cylinder will do if thats easier.
I think you might be right about it being off a MK20 system, I think the parts must have gotten mixed up on the shelves because there is no way of checking the part number actually on the master cylinder. I'm gonna go back to the breaker and try and swap the parts over they were really helpful last time. It would really help if I had a photo though so I can show them exactly what I mean.
Thanks for all the help and advice.
any upgrade??M206 said:hello guys, very interesting discussion!!
i'm an Italian owner of a 2005 Seat Leon 1M (the old one) FR TDI 150cv with the TCS (traction control system) but without the ESP.
What would I have to check in my leon system to be sure that i can order the parts of the list in the first page?? (i'm quite sure that most of the parts will be the same of the lasts MK4 golf TDI 150cv).
And what about some prices, if you know??
Thanks in advantage.
Thanks Glen. So the 637 D number is the complete assembly, then?MOGolf said:Yes, the full part number is probably 1J1 907 637 D.
The latest listing shows the sensor 1J0 907 655 A, plus the bracket and nut pictured all as individual parts.
Any help??M206 said:hello guys, very interesting discussion!!
It worked...MOGolf said:Give it a try. It can have two results: 1) works, 2) fault code and ESP is disabled.
If the controller in the car is not an ESP controller, then the jumper wire should be in 14 not 12.
ESP is stability control. An LSD will not give you that.lasrsktr said:It worked...
My issue was i swapped in a wire harness from an ESP enabled car so it was prewired for ESP..
I didn't want ESP as the cost of components locally is nuts and I already accomplish it mechanically with an LSD...
So all i had to do was swap the wire from position 12 to position 14 to make everything talk the way it should..
Oh man Dan, you arent kidding. I'm doing this for BleachedBora right now.... Making my own heated seat wiring harness was easier....danix said:To those comtemplating this project, who perhaps read my earlier ASR install post - this is a lot, lot more work than just swapping hydro units on the ASR. I haven't looked at a wiring diagram in almost a year, so I'm being very slow and careful, but still. Don't underestimate the size of this project.
How far along are you? It is actually not that bad if you do it in stages. Let me know if you need any thing, but considering your qualifications, I'm sure you'll be fine!!!! It is just time consuming!!oldpoopie said:Oh man Dan, you arent kidding. I'm doing this for BleachedBora right now.... Making my own heated seat wiring harness was easier....
