tongsli
I'm going to get this started and will post pictures when I take them
Parts List:
Master Cylinder: 1J1 614 019C **You must get the Master Cylinder and Brake Booster together. It is IMPOSSIBLE to put an ESP Master Cylinder onto a non-ESP Brake booster. The Bolts and holes will not line up!
The non-esp(master cylinder) bolts are 90 degrees offset from the esp(master cylinder) bolts.
BE 2002-2004
BEC 2003-2004
GOB 2002-2004
JEM 99-01
JEM 2002-2004
JEW 2002-2004
Brake Booster: 1J1 614 106J **-see not above
BE 2002-2004
BEC 2003-2004
GOB 2002-2004
JEM 2002-2004
JEW 2002-2004
ABS Pump and Controller:1C0 907 379M or ..375M
BE 2002-2004
BEC 2003-2004
GOB 2002-2004
JEM 2002-2004
JEW 2002-2004
Canceling Ring/Steering Angle Sensor:1J0 959 654AG
BE 2002-2004
BEC 2003-2004
GOB 2002-2004
JEM 2002-2004
JEW 2002-2004
Combined Sensor
You will need this housing for the sensor:
4B0973712
Using wires 000 979 131, 2 repair wires needed.
Wiring seals 3B0 972 742B(yellow) 4 seals needed.
Master Cylinder Connector for Sensor:1J0 972 483A
using wires 000 979 009, 2 repair wires needed. **I do not have the wiring seal part number. I will look up and post it here. For the other end, use wires 000 979 131, 2 repair wires needed wiring seals 3B0 972 742B(yellow) 3 seals needed
Wiring Diagrams
ESP wiring 2002+ **Be sure to relocate Pin T47a/14 to T47a12. This jumper is an EXISTING wire in the 47-pin connector!! It will not work if you forget this step!!!!
Connector for Canceling Ring
4B0 971 636
Installation Procedure:
1.drain brake fluid from reservoir
2.disconnect all brake lines to Master Cylinder and ABS pump
3.disconnect brake booster from car and release brake pedal
4.remove ABS pump, brake booster and Master Cylinder
5.Install new ABS pump, booster and Master Cylinder, connect brake pedal.
6.Fill power bleeder
7.Bleed all four wheels and clutch slave cylinder
8.Disconnect battery and remove airbag
9.Remove old canceling ring and install new one
10.Connect wires, reinstall airbag and battery
11.Bleed ABS pump and brakes using Vag-com THIS IS A REQUIRED!! If you don't have Vag-com, do not perform this modificiation.
12.Code ABS module and calibrate ESP sensors. Be sure to write down your existing software coding. Look up the digit for ESP in the Bentley's manual.
An example of Software Coding from newjettaguy for a 2003 Jetta Sedan:
Address 03: ABS Brakes
Controller: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04257
Shop #: WSC 05311
No fault code found.
DCTDIWagon's is 04097 - he's got a Jetta Wagon
ESP Calibration
You must complete all the other sensor calibrations before you engage the final driving test.
http://www.ross-tech.com/vag-com/cars/steeringangle.html
The driving test, once initiated CANNOT be turned off or stopped UNTIL the ESP is configured. It stays in ESP Configuration Hell! I left the car last night and tonight, after starting the car and stepping HARD on the brake it immediate went into road test mode!
Thanks to Eric (SVTWEB), Glen (MOGOLF) and especially Brian(Strretch) for helping me bleed the clutch and get the ESP sensor configured tonight.
From Glen:
You must, must be going 15kph and they mean it. A figure 8 is best because the turns happen FAST. You need SPEED to get the lateral sensors to trigger.
Speed + hard turns=G-force & Sensor Calibration.
The mistake I was making was not enough speed and not enough G-Force to get the sensor to trigger!!!
Parts List:
BE 2002-2004
BEC 2003-2004
GOB 2002-2004
JEM 99-01
JEM 2002-2004
JEW 2002-2004
BE 2002-2004
BEC 2003-2004
GOB 2002-2004
JEM 2002-2004
JEW 2002-2004
BE 2002-2004
BEC 2003-2004
GOB 2002-2004
JEM 2002-2004
JEW 2002-2004
BE 2002-2004
BEC 2003-2004
GOB 2002-2004
JEM 2002-2004
JEW 2002-2004
Combined Sensor
4B0973712
Wiring Diagrams
4B0 971 636
Coding: 04257
Shop #: WSC 05311
ESP Calibration
From Glen:
Here's the deal:Now perform test drive for maximum 50 seconds at a speed of 15km/h...30km/h:
It must be driven so that no ABS, EDL, ASR or ESP regulation is performed.
Make a turn with steering wheel turned at least 90.
When the ABS warning lamp -K47- and ESP warning lamp -K155- go out, the ESP driving test has been successfully completed.
