ESP - Golf/Jetta/Jetta Wagon/NB 2002-2004
Baumeister
Auburn, CA
'15 Beetle Convertible, '03 New Beetle TDI 5sp, '94 Audi Cabriolet(AFN swap in progress)
T47 Pin Numbering & Assignments
For reference, here's the complete T47 connector pin numbering and assignments.
Contact Wiring connection to component ...
1 ⇒ Voltage supply from battery +
2 ⇒ Connector T16/7 , K wire
3 ⇒ Vacant
4 ⇒ Voltage supply from ignition/starter switch
5 ⇒ Vacant
6 ⇒ Transverse Acceleration Sensor G200
7 ⇒ Vacant
8 ⇒ Vehicles with navigation system only
9 ⇒ Vacant
10 ⇒ Vehicles with navigation system only
11 ⇒ Data bus wire ⇒ wiring diagrams
12 ⇒ Coding bridge to contact 38
13 ⇒ ASR/ESP Button E256
14 ⇒ Coding bridge to contact 38 (vehicles with ABS only)
15 ⇒ Data bus wire ⇒ wiring diagrams
16 ⇒ Ground point on left-hand longitudinal member
17 ⇒ Vacant
18 ⇒ Brake Pressure Sensor 1 G201 voltage supply
19 ⇒ Brake Pressure Sensor 1 G201 signal wire
20 ⇒ Brake Pressure Sensor 1 G201 Ground wire
21 ⇒ Vacant
22 ⇒ Vacant
23 ⇒ Vacant
24 ⇒⇒ Ground wire for Transverse Acceleration Sensor G200 and Rotation Rate Sensor G202 Ground wire for ESP Sensor Unit G419 , vehicles from m.y. 12.01
25 ⇒⇒ Vacant Data bus wire for ESP Sensor Unit G419 , vehicles from m.y. 12.01
26 ⇒ Voltage supply for Transverse Acceleration Sensor G200 and Rotation Rate Sensor G202
27 ⇒ Vacant
28 ⇒ Vacant
29 ⇒⇒ Vacant Data bus wire for ESP Sensor Unit G419 , vehicles from m.y. 12.01
30 ⇒ Vacant
31 ⇒ Vacant
32 ⇒ Voltage supply from battery +
33 ⇒ Right Front ABS Wheel Speed Sensor G45
34 ⇒ Right Front ABS Wheel Speed Sensor G45
35 ⇒ Vacant
36 ⇒ Left Rear ABS Wheel Speed Sensor G46
37 ⇒ Left Rear ABS Wheel Speed Sensor G46
38 ⇒⇒ Coding bridge to contact 12 (vehicles with ABS/EDL/ASR/ESP front wheel drive only) Coding bridge to contact 14 (vehicles with ABS front wheel drive only)
39 ⇒ Vacant
40 ⇒ Rotation Rate Sensor G202 signal wire
41 ⇒ Brake Light Switch F
42 ⇒ Right Rear ABS Wheel Speed Sensor G44
43 ⇒ Right Rear ABS Wheel Speed Sensor G44
44 ⇒ Vacant
45 ⇒ Left Front ABS Wheel Speed Sensor G47
46 ⇒ Left Front ABS Wheel Speed Sensor G47
47 ⇒ Ground point on left-hand longitudinal member
Lanp900
PNW
ALH Golf 2001-Bert
Just installed ESP in the 2001 Golf built 12/2000. No telltales, etc. Seems to be golden, and working swell. Don't know that this means it will work for all 01's, but it works on this one.
Any questions, just ask!
dremd
South Louisiana
06 sprinter. 03 jetta wagon premium with 6 speed ALH swap, 14 JSW
Power memory seat "drift" when used with reverse.
Sorry
tongsli
Baltimore, MD
What pump do you have MK60?
tongsli
Baltimore, MD
3 ⇒ Vacant
5 ⇒ Vacant
7 ⇒ Vacant
9 ⇒ Vacant
17 ⇒ Vacant
21 ⇒ Vacant
22 ⇒ Vacant
23 ⇒ Vacant
27 ⇒ Vacant
28 ⇒ Vacant
30 ⇒ Vacant
31 ⇒ Vacant
35 ⇒ Vacant
39 ⇒ Vacant
44 ⇒ Vacant
The Pin 12 to 38 bridge initially messed me up! But I eventually figured it out. Thanks for the info.
joelbert
NJ
2004 Jetta TDI GLS Wagon, 5 Spd, Sold-2002 Jetta Sedan auto, 2003 GLS Wagon auto project
First a big thank you to tongsli, and everyone else who contributed information to this thread.
I just finished this project, and never would have attempted it if others hadn't done it before, and documented it too. I took the car out for a test drive got everything coded, and calibrated. Everything is good, with the ESP, but I am getting two vcds errors on the Steering Wheel module.
01426 - Controls in Steering Wheel (E221)
49-00 - No Communications
01336 - Company Data Bus for Comfort System
80-00 - Single-Wire Operation
I buzzed out the clockspring and only the 2 airbag pins conduct, the other three are open. My old clockspring all 5 pins are through. I used clockspring 1j0959654ap because that was readily available (aka cheaper) on ebay than the 1j0959654ag . ETKA says "part number is not interchangeable with replacement (forward only or linear supersession). I know the 1j0959654ap was used on MK4s with esp, so I figured it would be okay. Does anyone know if the 1j0959654g has all 5 pins through on the clockspring? Pretty sure this is my problem, but it would be nice if someone could confirm before I go buy another clockspring.
joelbert
NJ
I saw those. The Audi Allroad references in those ebay listings made me go looking in ETKA for the Audi Allroad, and I got an answer there. On the Audi page it describes the 1j0959654ag as "cancelling ring with slip ring and steering sensor for vehicles with multifunction steering wheel"
ticketed2much
Lehigh Valley
2010 JSW
Bumping an old thread to see if anyone has success depinning the ABS plug? I have tried an assortment of home-made tools with little to no success. I can usually get them out but end up damaging them a lot of the time. I have considered buying a set of depinning tools but most of them don't list a tool for pins under 1mm?
turbovan+tdi
Abbotsford, BC.
2003 TDI 2.0L ALH, auto, silver wagon, lowered, Colt stage 2 cam, ported head,205 injectors, 1756 turbo, Malone 2.0, 3" exhaust, 18" BBS RC GLI rims. 2004 blue GSW TDI, 5 speed, lowered, GLI BBS wheels painted black, Malone stage 2, Aerotur
Stupid question, what's ESP?
turbovan+tdi
Abbotsford, BC.
bmali98
Dunsford Ontario
O4 golf pd auto
LOL, I did that but didn't put VW in front, got a whole bunch of gibberish, :rolleyes: :cool: Thanks.
Ok, so watching a video in that link, ESP seems to me, its for stupid drivers who can't drive to help them be safe? And Government mandated by 2012? :(
It's also for "good" drivers that like to freak people out. In my wagon I was able to throw it around on a gravel road to demonstrate what the button in the centre of the dash does. My younger brother nearly pissed himself as I jerked the wheel side to side demonstrating you can't spin it around if you wanted to.
turbovan+tdi
Abbotsford, BC.
LOL. :cool:
mrrhtuner
London Ont Canada
2003 Jetta Wagon TDI, 2015 Passat TDI, 2015 Touareg TDI
Truthfully, I think it's great. Some people will complain because they don't 'feel' in control of their car, but the car will detect and attempt to correct the vehicle's action's before the user will even try. Not going to get into this as I'm sure there is a large pro and a large con group.
I think it's great and I'd install ESP...if it wasn't so much work :p
where2
North Palm Beach, FL, USA
One '13 JSW_TDI & One '04 Variant_TDI
You may laugh at ESP, but I looked at it from a different perspective. Back in 2006, my wife rolled her '98 4Runner on the interstate two days before she test drove her 2006 Jetta_TDI with ESP, the addition of ESP seemed like a worthwhile expense, along with the multitude of air bags and having a lower CoG.
I can't afford to replace vehicles every 5 years, and at that point in our marriage, she had been in two vehicles that were totaled in accidents in under 5 years. Before your mind tosses a blanket statement about my wife's driving, she's actually a very conservative defensive driver, not an aggressive driver. That being said, I'd still love for her to take a road course driving school to become more familiar with vehicle dynamics.
When I analyzed the accident with the 4Runner, I determined that a functional ESP system would have likely saved that vehicle. The fact that she was able to walk away after 1.5 rotations onto the roof was amazing. The fact that she flat spun the 4Runner multiple 360° rotations across 3 lanes of Interstate 95 and a breakdown lane is what ESP could have helped with. When you hit the dirt shoulder in a flat spin in a high center of gravity vehicle, your likelihood of rolling it is nearly 100%. The Michelins that were on the 4Runner were not the fault of the accident, and they left some great tracks on the dry pavement trying to dissipate the vehicle motion. I drove that section of interstate daily for 15 years.
If ESP saves anyone's family member from going through the ride of a lifetime and ending up on the roof of their vehicle on the shoulder of the highway in a rural area at night, it's probably worth it. The EMT's who showed up were amazed my wife walked away from the accident that night.
Sure, there were some things that my 2006 Jetta_TDI (company car) with ESP didn't like, especially one particular on-ramp I used to pass every morning where the road grading crew obviously screwed up a grade mark they set on a stake at the beginning of the curve. However, most of the times that the ESP system obviously triggered in the 90k miles I put on that company car were times were the driver deserved the notice. ;)
Now, I need to go read all these posts and see what it takes to add ESP, because the 45+ pages of retrofitting ASR sounded too easy to add to my 2004 MkIV. :)
EmiD
Romania
1.9 AJM, AUY, AXR, 2.0 GLGC
Hi everyone!
I just swapped my manual transmission in MY2001 Golf Mk4 Variant with DQ250 and I'm stuck at one thing. In order to communicate well between DSG and ESP I had to upgrade from MK20 ESP with t47 plug to MK60 ESP with T47a plug. Almost everywhere I was able to find the corresponding pin, but I'm not sure about the Brake switch wire from MK20 ESP. In my wiring diagram for MK20 ESP I have a brake load relay J508 ...
MK20 ESP and Brake switch connection (F)
MK60 ESP and brake switch connection (F)
Can anyone tell me which wire/pin from T47 (MK20) is the correct one for 41/T47a (MK60)?
Thank you! After finishing I can post the table I have created with corresponding pins... :)
graeme86
Brisbane, Australia
Not yet - fuel is too cheap! - 3.2 VR6 R32
I believe that relay was kind of a cobbled up fix to stop the brake lights pulsing if the ABS pump was working on the mk20's. The Mk60's don't even have this relay, so just follow the Mk60 wiring now...you will probably find that the extra -A89- connection in Mk20 harness is eliminated on the Mk60 and it is all just the one connection point -A18- now.
SilverGhost
Back in So Flo - St Lucie
@EmiD - I'm interested in the project as a whole. Getting a DSG with newer CAN to work in a much older car with rudimentary CAN. Makes my little side project of a 2.5 Jetta more doable ;)
Jason
EmiD
Romania
Hi! I will keep posting until everything works perfect.
I think that this is the main issue why DSG do not work by default in Golf MK4 = Can version of different components (e.g ECU/ ABS). Hope that I do not have to change also the ECU, but I'll see. :) Even so, the gearbox sees the pedal position, engine RPM and so on.
I have to finalise first the swap to MK60 ABS ESP and then give it a try. For the moment, DQ250 works okish with ABS shut off but it has to work perfect. With ABS off works but the gearbox doesn't know when to upshift, how fast or slow to shift so I have to be careful while driving the car in this condition.
Until now I have already changed the Instrument cluster to a newer version (Immo3 FullFIS) and newer CAN - Which I cannot recode (another issue).
I promise I will come back :)
cheers,
EmiD
Romania
Hi Everyone.
I have almost finished with ABS MK60. I still have one error: ABS light on and Flashing handbrake light. No errors in ABS unit, but, in Measuring Group - 03 group, I have Brake Sistem Warning Light - flashing ON/OFF and also ABS System Light- flashing On/OFF,and I cannot find out why is this happening.
For the moment, DSG works after I have changes also the ECU.
My2001 AJM ECU for MT, didn't want to accept coding for Automatic Transmission and it was easier to take another ECU from AUY 2004 Automatic, IMMO Off and voila! Works.
-Video with DSG working and abs error
EmiD
Romania
Hi Guys,
ABS, ASR, EDL and ESP are working fine. The main issue was the Passat Instrument cluster installed on the Golf. Switched to a MK4 Full Fis cluster and everything worked fine.
From time to time, I still have a ESP light, but switching off the engine and turning it on solves it. I think it's only a drop in the power supply while starting the engine, so I will check all the cables from the wiring loom to the ESP Unit. No errors in the ESP unit and all the measuring blocks are showing the right data.
So yeah, MK20 ESP to MK60 ESP upgrade, can be done.
Drive safe!
shoebear
Colorado Springs, CO
1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
Just did a quick eBay check of the parts listed in the original post. I looked for used parts where I could find them, and my total with shipping came to $330. If I had picked new parts, it likely would have cost twice as much (or more) and included aftermarket parts such as Dorman. Also, I didn't read through the thread to see if there are additional parts I would need. For example, I think ESP installation should include a switch and light, which were not in the OP list.
