Revised B4 MFA conversion article
RIP TDI
Santa Barbara, CA
2015 GSW SE 6MT 2001 Golf GLS 5MT 1996 Passat Wagon
No problem with an auto cluster. Yes, the TDI tach face will cover the gear selection display.
goodmonkey
Anchorage, AK
2014 Passat TDI, 2011 Touareg TDI
Thanks Chris. I just snagged one for $75. I won't get to play with it though until I fix my wife's Nissan (manifold gasket replacement, fun fun). I guess the hard part will be finding someone locally to reprogram the mileage.
robertgalka
Winnipeg Canada
2015 Passat Highline
I have everything to do the conversion but I haven't taken anything apart yet. I would like to know why only six wire connectors are needed? We have to make a four wire harness from the wiper switch to the fuse box. Wouldn't that require eight ends already? Then we should need four more for the temp sensor harness.
robertgalka
Winnipeg Canada
I am having some more minor problems. The part number 1H0 953 635 is a 5 pin plug but the MFA plug is four. Does anyone know the part number for the four pin plug?
The two wires for the outside air temp sensor have a 2 pin plug part number 1H0 973 131 A. I would like to know the part number to the mating plug and wire connectors. I think the plug is 1H0 973 131 C, but I am not sure. I could cut and solder but a plug would look better.
robertgalka
Winnipeg Canada
I got it all together last night, I robbed some connectors from a wrecked car. The only problem is I can't get my outside temperature to show up on the display. The German cluster also doesn't have an engine and trunk light.
RIP TDI
Santa Barbara, CA
I'm sorry about the incorrect P/N for the switch connector. I added those numbers for the revised article years after actually doing the conversion and didn't verify the numbers with the actual installed parts. I guess you're the first to do the conversion since the revision was published...sorry you had to be the guinea pig.
If the Euro cluster doesn't have an MIL, you should determine if all fault triggers, split between MIL and GP light in NA models, are combined into the GP light. Unplugging the MAF and driving for a few minutes should be a sufficient test (triggers the MIL in NA clusters). This assumes that Euro models don't use a remote MIL.
As to your ambient air temp, did you trace the two wires back to pins G1/2 and G2/2 of the relay panel? Neither my '96 nor '97 (US-spec.) had a connector on the end of those wires..they were unstripped and taped together.
robertgalka
Winnipeg Canada
I think the part number for the four pin plug is 1H0 953 634. I will have to unplug the MAF and see what happens with the GP light.
I am pretty sure I found the correct wires for the ambient air tems, I will have to check again. It's hard to see with that birds nest of wires in the way. The wires are red/white and brown/white and they are short. My car was an early tdi, it was made in 10/95. Maybe the later ones are different.
One other thing is the Euro clusted didn't have any pins in the RH back plug. The plug just plugs in to the plastic without doing anything. There is only one one wire in that plug anyway.
RIP TDI
Santa Barbara, CA
Then you only have partial fault indication capability, if any. That single wire in the 2nd 28-pin connector is the MIL signal. To remedy, you'll have to add the MIL LED, resistors and signal wire (pin 26) to the cluster. If the PC board of the Euro cluster is pretty much the same as the NA cluster, hopefully everything will work correctly. If not, you'll have to trace the PC circuit to the desired bulb location, or add a remote LED.
jnxtheband
pdx
92 GTI AHU swap (gone), 91 GTI VR6
has anyone done this with an A3? The 2.0 GTI's used an mfa cluster which also had a 140mph speedo which would make it a good candidate for this I would think.
RIP TDI
Santa Barbara, CA
Yes I have, but with a GLX VR6 cluster. There is an issue of a change in warning light circuitry configuration in, IIRC, '96, so a later MY cluster should be used.
The conversion is very similar to the B4 but A3s are missing some additional wires & harness connector pins that must be added.
Missing cluster & relay panel connector pins & wires between cluster and relay panel:
  • Cluster pin 6 - MFA controller switch - goes to pin 8 of the U2 connector on relay panel.
  • Cluster pin 15 - MFA controller switch - goes to pin 4 of the U2 connector on relay panel.
  • Cluster pin 17 - oil temp. sensor - goes to pin 1 of the U1 connector on relay panel.
  • Cluster pin 19 - outside air temp. sensor - goes to pin 2 of the U1 connector on relay panel.
  • Cluster pin 1 - outside air temp. sensor - goes to pin 7 of the U1 connector on relay panel.
Missing cluster and ECM connector pins & wire between cluster and ECM:
  • Cluster pin 26 - Fuel consumption signal - which connects to ECM pin 9. This wire goes directly from cluster to ECM without passing through the relay panel.
Note that the above list does NOT include the missing 4-wire harness that runs between the MFA controller switch and relay panel.
Dizel Mork
Montreal, Canada
Jetta, 1999, midnight blue
I've swapped a euro cluster in my A3, and i'm wondering if anyone knows where the purple fuel consumption wire can be found in the fuse box? (or where ever else it may be)
RIP TDI
Santa Barbara, CA
Revised B4 MFA article and article CORRECTIONS
The wire (lilac/white) goes directly from pin 28/26 of the cluster to pin 68/9 of the ECM without passing through the relay panel or anything else.
Stafford Virginia 22556
96 glx variant tdi
Sometimes it's hard to see the forest because all the trees are in the way. When we retrofit a tdi motor into a glx chassis and use the original glx cluster, all we have to do is add the glow plug led and ?
RIP TDI
Santa Barbara, CA
...install a pulse adaptor for the tach and use the tach face & surround from a TDI cluster.
codeblue
Kitchener, Ontario, Canada
98 Vento GLX TDI
Hi all,
I just wanted to bring this back up because I have an A3 and was interested in doing an MFA conversion myself, especially now that I have a donor GLX with all the trappings. There's little to no info about MFA for the A3 Jetta so I'd like to contribute some info:
Last night I was doing some fooling around with my TDI cluster and a GLX cluster. Reading from Chris' posts it seems that you need to wire up a MIL light. I'd just like to say that I think those of us with A3's may be in luck.
Please correct me if I am wrong but here is what I did:
I took apart the GLX cluster completely (by the way it is a U.S. GLX VR6 Automatic tranny cluster), put my TDI gauge face onto it, then put the red needles on top. After assembling everything back together, and putting it into the car, everything worked and lit up normally as expected! The speedo worked, all the lights came on, including the CEL light, and turned off after starting the car, like normal. The glow plug light came on for a few seconds as normal as well. All I had to do, was put a bulb into the CEL light spot. However the tach was completely off, as expected, as it is an unmodified cluster.
For FURTHER testing of the MIL/CEL light, I removed Relay 109 (power to the ECU), and after turning on ignition, the CEL light no longer comes on. Not even for a bulb test, as normal.
I didn't really go any further into it, testing any CEL's, I could have purposely tripped some but it's too cold out to work right now. I also didn't test the MFA because I don't have the stalk installed.
In conclusion, the fact that the MIL light worked fine should indicate that no soldering is required on the cluster for us A3 folk. Feel free to chime in for those that have successfully and completely done this on an A3.
In the end I went back to my stock TDI cluster because I don't really need the MFA, and I don't want to go into wiring up a pulse thingamajig. I also didn't want to deal with Fahrenheit and Miles (I'm Canadian). I kept the red needles though :D
Here's some pics:
Clusters side by side.
codeblue
98 Vento GLX TDI
One more thing for the A3's. If you transfer the TDI face onto the GLX cluster, you HAVE to move the digital readout peice and the digital transfer film stuff (the clock and odometer displays) from the GLX face into the TDI face. Without doing this you will get garbled text on the odometer and clock.
When you do this, it will also be a good time to take out the green light filter and put in some blue stuff, if you want to change odo and clock colors :).
RIP TDI
Santa Barbara, CA
That shouldn't be. Was the GLX cluster a late ('97/'98) one? I didn't have that problem (with a late cluster). There are some issues with an early A3 cluster in a TDI, but those are primarily warning light circuit mismatches. You may have had a bad GLX cluster.
Also, refer to my post #42 on the 3rd page of this thread for details on the additional wiring that needs to be added.
RIP TDI
Santa Barbara, CA
Also, on A3s it isn't necessary to use the pulse frequency adaptor. Unlike B4 clusters, A3 clusters can be reprogrammed for number of cylinders and country code. This solves both your tach problem and your unit of measurement issue (and the stored odometer value can be changed at the same time). I believe that using this method, the tach will read correctly using the GLX tach face, not the TDI face. It may be possible that entering the TDI's "program version" code into the GLX cluster in addition to the changing the number of cylinders code will allow correct tach reading with the TDI tach face, but I can't confirm that. If that didn't work, the pulse adaptor would solve the problem.
RIP TDI
Santa Barbara, CA
No. On A3s, the reprogramming is done with a chip editor.
The read-only status of B4 cluster chips apparently cannot be broached to allow this method.
codeblue
98 Vento GLX TDI
Both clusters are 100% good and are both from 98's. I've used both of them. When I had the VR engine in the car, the MFA worked perfectly. I think I know why the text was garbled though:
For the A3 TDI cluster, I believe it was only designed to show a clock in right hand display, and a odometer in the left hand display. I noticed that when I take out the little screens, they will light up temporarily displaying all digital info (kinda like looking at a microwave screen you can see the lines where all the digital numbers light up) on the TDI screen only the digital area where the clock is will light up, with 88:88 for example. It didn't show anything else.
When I took out the screens from the GLX cluster, it lit up with the clock and little arrows along the edge of the screen (to point to the MFA descriptions above the screen)... Everything works fine once I transfer over the right screens.
Anyway, now that you say that I can change everything over to Canadian I think I may try again with setting up the MFA. The only problem is it still shows MPH on the speedo face and fahrenheit on the coolant temp face. You wouldn't happen to know anyone up here that can do "Chip reading"?
Would I have to identify what chip has to come off, or whats the deal with that?
RIP TDI
Santa Barbara, CA
Huh...that's interesting. The GLX cluster displayed correctly in my A3 TDI, or at least that's how I remember it (its been a few years since I did it). Now I did have all the missing wiring in place...maybe that makes a difference, I don't know.
If you can give up the white faces, just use the TDI face plates to keep metric markings.
As to chip editing, you just send the whole cluster to the programmer. There may be experienced cluster programmers in your area but the only one I know of who has experience with VW clusters is ele28 and I think he did pretty much this same job on his own A3. The only thing I don't know is if he used the GLX or TDI tach face and whether or not he played with the program version code to accomodate the TDI tach face if it didn't read correctly after changing just the cylinder number code.
Ltigator
Golf, 2002, Silver
Ok, So I Just Don't Get It
Can you help me out here? I've been over all the articles. Can you just lay it out for a dummy like me by wire color? I pulled the switch harness with the MFA switch and just want to go by wire color to the back of the fuse panel. What pin does each wire go to? I really have read the article a dozen times at least and the update, but I'm just not understanding it.
Thanks a million,
Jim
Lug_Nut
Sterling, MA. USA
2015 GSW 6M in S trim the other oil burners: 1967 two stroke Sonett 1988 Bolens DGT1700 1962 Quantum III
Do you still have the plug at the fuse block end of the switch wiring you plled? The plugs are keyed to fit only in the proper port in the fuse/relay block. With the plug it is not possible to make a misconnect.
B4 anyway. I don't know about the A3.
<edit>Or your 2002 A4.<end>
Ltigator
Golf, 2002, Silver
Lug Nut, Thanks
I apologize for my unclarity. I also have a B4, 1996, and pulled a GLX cluster from a 1997. The MFA harness I only pulled out 24" of and cut off. If I pull the rest of it, will it connect directly to the fuse block? Is there a way I can just splice what I have into the fuse block? The junk yard is over an hour away, so I'd hate to have to go back, but I'm probably going to be back there in a few weeks, so I can add it to my list of stuff to get.
Thanks for the reply. The rest of the cluster works great, except for the tach, which I'm not worried about setting up to read accurately (don't really have the dough to put into the dakota box).
You guys have a great site. Keep up the good work.
Jim
CIB, ABN, AA
Lug_Nut
Sterling, MA. USA
Yes, and,
not without the pins.
The plug at the fuse/relay block end will mate with either the TDI or VR6 block. Just splice the cut middles back together.
Without the plug to the block, or more specifically without the pin connectors to the block, you will have a difficult time locating the proper conductors. You might wish to re-read Chris' parts list for these items that you can get from a dealer rather than wait the weeks plus an hour to get back to the yard.
therabbittree
Red Hook, NY USA
B4 passat, 2000 Golf, 2003 Allroad tdi
I noticed that the glx cluster unmodified stops the trip odometer at 1000. Ie it will start over at 0 after 1000miles.. Is there a way to have it work liek a tdi cluster in that regard. as my '96 B4 Wagon will go over 1000 miles pretty easily.. any ideas? I am doing the cluster conversion and want to know if I can solve this at the same time.
thanks
Deo
therabbittree
Red Hook, NY USA
I forgot what year cluster I'm running ..now its been soo long ha..its a vr6 auto cluster that I didn't convert.. just threw it in temp to get a fuel guage and a speedo. The car Im taking the glx stuff from is a '97 so I guess I snag that cluster too.
thanks,
Deo
