Curious Chris
I have one too. I was at Oreily's for a oil filter and they have the same set as I do. Very nice.Thanks for the offers Farmboy, and V8, I found out that Oreilly "lends" them, so I am just going to go that rout
Just ordered my 2.5 inch downpipe no cat system.As far as I know our transmissions are pretty beefy, f
Chris if you get an LSD you should be fine, but first get a damn exhaust.
Sweet. Bring it to the GTG.Just ordered my 2.5 inch downpipe no cat system.
Sounds good. I am thinking drive the car up on my ramps. Jack up the rear of the car and put it on jack stands. Either borrow or buy one of those cool multiwheeled cutters to cut the exhaust; or use my Sawzall.Sweet. Bring it to the GTG.
Remember how the pipe was off center at the hanger behind the cat? When I pull it to center it moves the tail pipe left & the hangers sometimes pull out of the rubber. I need to trim a fraction of an inch off the offset to bring the tail pipe back. I've got it set in a compromise now but I get an annoying rattle from the center hanger at idle. I have a nice quality SS clamp to rejoin the pipe.Yes, just buy the gasket Chris.
What do you need to trim Richard?
You mean one of these?Either borrow or buy one of those cool multiwheeled cutters to cut the exhaust; or use my Sawzall.
Isn't the stock exhaust stainless?You mean one of these?
I have one, worked well on the stock exhaust. You are welcome to use it. Doesn't work on stainless steel if you need to do any cutting to the new exhaust.
Yes mine is 304 IIRC and I was at a GTG where someone had the tool Jeff has and it worked on the stainless. Sears sells them for $37-$71 so maybe I borrow Jeff's and if I break it I buy a new one!Isn't the stock exhaust stainless?
Maybe then I will buy a new one and also bring my Sawzall. At the GTG where I saw it used it did take quite a while to cut through the stainless too. Or maybe get cut off wheels for my Dremel......Well if the stock exhaust is stainless, why was my old exhaust so rusty? Even if it was 409 stainless it shouldn't rust that much.
All I know is, it cut through the stock exhaust quite well, tried it real quick on a chunk of 304 stainless and it didn't leave a mark.
I'd better toss mine in the trunk too.Make sure you have plenty of blades. I burned through one Torch blade just cutting the transition cone off my catback. That stainless is tough stuff. I'll bring mine with too as backup.
I will also bring my 12 inch miter saw with a metal cutoff wheel in it. I was talking about cutting 304 with another engineer and he piped up that he had a cutoff wheel that fits a 12 inch miter saw. So off the car this will work great, and Jeff's tool will cut off the exhaust in the car. Of course I will bring my Sawzall as a back up with a couple of Torch blades.I'd better toss mine in the trunk too.
I can't say that you would get enough fuel without an 11mm pump and a lift pump pair with big injectors to get "power" up there anyways.I took a drive to check it out, once it was warmed up ran it up to 5 k in 3rd gear. It still seemed to cut out at about 4800 rpm. Not really an issue for me.. I very seldom punch it anyway.
