Old July 15th, 2009, 18:21   #1
MOGolf
MOGolf's Avatar
Default How to: replace metal door trim piece
A few of us have had the rear door trim piece come loose at the front edge. Opening the rear door causes the trim to catch on the front door and bend.
Here's how to fix:
Obtain the replacement part. 3B0 853 753 D GRU (left) or 3B0 853 754 D GRU (right).
It is two pieces. The metal piece that needs to be replaced, and the part that needs to be painted before installing on the car. If you follow these instructions you will only use the metal piece.
Obtain trim mounting tape. If you can find tape 1/2 the width of this, use it. I applied the tape and used a utility knife to cut it down to the needed width.
Apply the tape to the back side of the metal piece. It will take the place of the tape pre-installed on the primed plastic piece (not used) as seen along the top edge of the piece. Trim the tape to the required width.
Pull off the bent trim piece straight away from the door. It leaves the old tape on the car. You need to clean that off.
Unchained motoring
MOGolf is offline   Reply With Quote
Old July 15th, 2009, 18:22   #2
MOGolf
MOGolf's Avatar
Default Installation
I used a sturdy thumbnail protected by a rag and adhesive cleaner such as this.
I soaked the old tape with the cleaner and scraped with nail/rag. Note the cleaned area on the left vs. the old tape on the right. Be careful not to remove/damage paint, or get the adhesive cleaner down behind the painted trim piece. You'll have smooth black plastic once the old tape is removed. Wash thoroughly to remove any remaining cleaner.
Now the easy part. Peel off the paper from the trim tape and apply trim to the car. I noticed that the trim piece extends to an area of no contact on that edge that had bent on the old piece. I added a couple of layers of small pieces of trim tape there to secure that edge better (I hope).
Long term results are not yet determined.
Unchained motoring
Old July 16th, 2009, 17:34   #3
Chanley
you are AWESOME! thank you, I needed this.
Chanley is offline   Reply With Quote
Old July 14th, 2010, 11:28   #4
markmc90
How about the upper trim piece on the door. The one just below the window. Mine has come loose on the ends and is no longer straight.
markmc90 is offline   Reply With Quote
Old July 15th, 2010, 16:19   #5
MOGolf
MOGolf's Avatar
Front door or back door?
Unchained motoring
Old July 15th, 2010, 17:40   #6
VWSHPFRMN
I also like to use 3M adhesion promoter along with the 3M tape. This stuff works wonders when used together.
VWSHPFRMN is offline   Reply With Quote
Old July 16th, 2010, 13:45   #7
markmc90
Back door.
Page generated in 0.11649 seconds with 9 queries
[Output: 75.91 Kb. compressed to 65.47 Kb. by saving 10.44 Kb. (13.75%)]
