FletchMan
- Joined
- Apr 1, 2006
- Location
- Black Hills
- TDI
- 2006 Jetta, 99.5 Jetta...previously owned 2000 Beetle and 1990 Jetta 1.6
I didn't own the car at the time but records show my 2006 had the dmf replaced at 147k.
Listening to your video it's hard for me to tell. It's difficult to get a good recording and playback (esp on my cellphone speaker) that is the same as what you will hear in person.Hm. Drove around last night, it was around 4*C out, heard a lot of rattling in lower gears when accelerating. My old Honda Accord used to do similar stuff, but with all the talk of how bad the DMF's are in these things, its pretty easy to be paranoid.
Drove it around the block a bit, its warmer out today, and no sign of rattling. Though I let it set some and heard that sort of "pebbles in a can" sound that seems to be a telltale sign of the DMF. I'll attach a video with that. I'm still new to diesels, so still getting a lot of the noises sorted out and all.
I've also noticed, after having the transmission 40k fluid service done, downshifting from 2nd to 1st and coming to a complete stop, there's a slight kick that I don't really recall being there. In addition, the transmission clicks some when shifting from P or N to D. It's weird, these last two things, on VWvortex and a couple of other sites, were said to be normal in some DSG's. Some even reported them in brand new cars (Golfs and GTIs mostly) during test drives. I'm not entirely sure what to make of it.
https://youtu.be/yHFjL7n8nB4
Had someone else listen to it in person who had to replace theirs. They didn't hear anything either. Had listened to other videos and I certainly am not hearing any loud rattle outside, especially compared to what is reported in failing DMFs.Listening to your video it's hard for me to tell. It's difficult to get a good recording and playback (esp on my cellphone speaker) that is the same as what you will hear in person.
I didn't take a video of mine before replacement, but it sounded / rattled like the link below at idle and wound go away off idle. The unique sound of mine was its irregular pattern. It was easily distinguished from the engine which is very regular and consistent.
To me the best way to check for a bad DMF is to Disconnect the battery, remove the airbox, remove the starter and you can access the DMF teeth that engage the starter. Use a screw driver carefully to not damage the teeth and rotate the DMF clock and counter clockwise. A little play is as expected. Mine was getting around an inch without a lot of force at the teeth when I replaced it. This was almost completely cover the DMF to Crank bolts.
https://youtu.be/55aMHmfNUYc
Other test you can do is pull starter and see how far you can move DMF Mine was making noise and I pulled starter and could move it around one inch. Place I had replace it said max should be 10mmHad someone else listen to it in person who had to replace theirs. They didn't hear anything either. Had listened to other videos and I certainly am not hearing any loud rattle outside, especially compared to what is reported in failing DMFs.
Sent from my GT-N5110 using Tapatalk
Alright, thats something else i'll take a look at. I think, at least on some level, i'm mostly just being a bit paranoid. But you know.Other test you can do is pull starter and see how far you can move DMF Mine was making noise and I pulled starter and could move it around one inch. Place I had replace it said max should be 10mm
Your DMF sounds find.Alright, thats something else i'll take a look at. I think, at least on some level, i'm mostly just being a bit paranoid. But you know.
They are replacing the flywheel (DMF).Now that you have my story, what other DMF related issues should I have them check for?
Should I insist the fly wheel be replaced along with the DMF? Should I have them check the clutch pack / gear box for excessive play? Do I insist the alignment be done since the suspension has to be taken apart partially? What questions should I ask or what else should I have replaced?
Any input would be greatly appreciated.
Thanks in advance…
Whoa now. You can't just drop in here with that statement & no link. We want to see some pictures.my 09 dsg wagon is @ dcb automotive (brandon's shop) getting an awd conversion done to it
just talked to Brandon(DCB automotive)a couple of days ago & he's agreed to snap some pics & post them as he goes thru the process. rear was out, spare wheel bin was cut & shallowed, & about to strip out interior for wire harnesses(aka, the "fun" part of the projectWhoa now. You can't just drop in here with that statement & no link. We want to see some pictures.![]()
I have a bunch of photos but cannot figure out how to put them on here. The job itself wasn't bad at all. I had a few stuck bolts, the previous owner had replaced the mech unit with a used one from somewhere but cranked down on the bolts instead of just torquing them to specified 5nm. All in all took me about 4 hrs taking my time being careful not to lose anything. That is taking old unit out, replacing with new, tearing down, cleaning, and putting back together.That sounds like a project. would be nice if you ever get time to put the set of photos you took someplace with a few notes.
congrats on getting it all back together. how long did it take you?
four hours seems like it is not that long. you must not have dropped too many parts.I have a bunch of photos but cannot figure out how to put them on here. The job itself wasn't bad at all. I had a few stuck bolts, the previous owner had replaced the mech unit with a used one from somewhere but cranked down on the bolts instead of just torquing them to specified 5nm. All in all took me about 4 hrs taking my time being careful not to lose anything. That is taking old unit out, replacing with new, tearing down, cleaning, and putting back together.
I was going to take it apart just for fun. .
Lol! Really there isn't a lot to drop if you are careful. There was one small bearing that dropped out and I didn't see it, but I was able to find where it went pretty quick.You get all the cool toys.
Ok thanks. Sorry for that still new and trying to figure this out.Open your pictures on a separate instance of TDI forum.(click on the picture you want to show)
The picture expands and right click on it and save image address.
On the first instance where you are making the post click on the square yellow block with the mountains and past the address you copied there.
Click OK and the image is saved in the post (in a coded format to direct the browser to show it for the user, not you in your post block.
When I clicked on the big picture it did not work, but the thumbnail is what I right clicked on to paste, Lets see how it worked.
OOPS it didn't work for me then lets try again.
I clicked on the bigger picture and opened a bigger picture and now paste it in
http://www.evosoft.dk/diagrams/DSG_02E.pdfSomeone here may still have a link to the DSG self study online. I'm pretty sure it showed an oil flow diagram.
