Go Back   TDIClub Forums > Forum and Web Page Info > TDIClub and TDIClub Forum News, Issues, Problems and Suggestions
TDIClub and TDIClub Forum News, Issues, Problems and Suggestions This is the place for updates on the website and forums. This is also the spot for forum questions, comments, ideas, gripes, requests, etc. This forum is NOT for posting problems about your car. Non-topic posts will be moved or removed.
Old July 1st, 2010, 11:24   #1
Torque_Delight
Modded
Torque_Delight's Avatar
Fuel Economy: ~5 l/100km
Arrow How to upload/post pictures using the TDIClub picture server
Uploading and posting pictures using the TDIClub picture server
With the new forum server update, the picture server has also been upgraded. Here's the new procedure.
To insert images in a post, you can use different services such as Photobucket, Picasa, Flickr and others but the advantage of using the TDIClub picture server is that your photos will always stay online in your posts. Pictures showed as a link to another website have the risk of being deleted or the link can sometimes change resulting in a missing picture in your message. That is particularly bad when the images are in a important reference post like a "how to".
Even better, your account on the picture server is already created using your forum identifications informations.
How to do in 10 easy steps:
1. Access the server by the link pics.tdiclub.com or by clicking the "Photos" link into the forum's header.
2. If you are not already logged in, you need to do it by clicking on "Login".
3. Login using the login informations of the TDIClub forum.
4. Once connected, your username will be shown.
Click on "Upload Photos".
5. Select the file from your computer using the Browse button and then click "Upload/Submit".
6. You can now add some optional informations about your image.
Click "Process".
7. Your photo will now be shown in your personal folder.
Click on it.
8.
a) To insert a small sized image which is a link to the big image in your personal folder : Select the address "Linked Thumbnail" and copy it (CTRL-C).
For the other choices, click on the icon next to the previous link.
b) To insert a medium sized image which will be a link to this image in your photo folder : Select the address "Linked Medium" and copy it (CTRL-C).
c) To insert a medium sized image only : Select the address "Medium Image" and copy it (CTRL-C).
9. Now go back to your already started post or start a new post/thread.
Paste (CTRL-V) the address you just copied in your message. I decided to paste the 3 links to show you the difference it makes.
10. Here's the result !
Some more informations:
You can also upload some small videos, PDF documents, Word and Excel files and insert them into your message the same way you would do it for an image with the "Linked Thumbnail" link.
This "How to" isn't explaining every aspects of the picture server but is you have any questions, just ask.
English not being my primary language, if something is wrong, please tell me.
French version
Torque_Delight is offline   Reply With Quote
Old July 1st, 2010, 11:54   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Originally Posted by Torque_Delight View Post
Nice write-up, Torque.
Things haven't been the same since the forum was upgraded. Even though it says "click on photo to make larger (or smaller)", it doesn't work...nothing happens.
Also, I don't see that little icon you are pointing to with the red arrow or the two boxes below it that are the text/code you are supposed to copy
Old July 1st, 2010, 12:03   #3
Torque_Delight
Modded
I told Fred about that Larger image issue, he will fix that soon.
The little icon should be at the right hand side of the "linked thumbnail" address of under it like I posted.
The other links will appear when you find/click on that icon.
Maybe it's a bug.
Jetta TDI 2001 GL (~680 000 km) : GT-1749VB, EGT/O2/Boost Gauges, Scangauge II, Sachs VR6 Clutch kit, OEM G60 Flywheel, 502 Nozzles, MRTuning, Euroswitch, Hella Micro-DE w/ yellow bulb, Rear fog, Wolfsburg's Heated Seats, Koni STR.T Shocks, H&R OE Sport Springs, TT Control Arm Bushings, 17" Santa Monica (GTI VR6) Wheels, DieselGeek Skid Plate, FX35 HID Projectors Retrofit, GLI Tail Lights, 2004 Trunk lid.
Old July 1st, 2010, 12:13   #4
dieseldorf
top post dawg
dieseldorf's Avatar
OK, I'll try that. Maybe I need to find larger pictures.
We used to see links defined by the picture's size that you could click. No we just see the file size and the hyperlink(s) is gone.
Merci
Old July 1st, 2010, 13:17   #5
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Default Test pdf
Well, I tried to upload and paste a pdf file and the above is what I got. Is something wrong here?
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old July 1st, 2010, 13:22   #6
VW Derf
Administrator
Fuel Economy: 5.9L / 100km
Thanks for doing this Torque_Delight. It is some great work and I'm sure it will help the rest of the members significantly. Under the old implementation I had done a number of customizations and it is apparent I'll need to do some additional tweaking to this update as well. If there are any other issues/problems with the pics section, please post in a separate thread so we can keep this one just for the how-to.
2010 Golf Highline Wagon (Blue Graphite Pearl)
Aspherical Mirrors
- Past VWs:
2003 Indigo Blue TDI Bora Wagon;1996.5 Black 2.sl0w Golf
VW Derf is offline   Reply With Quote
Old July 22nd, 2010, 12:08   #7
ninedee_golf_tdi
Can you upload more than one picture at a time ?
ninedee_golf_tdi is offline   Reply With Quote
Old July 22nd, 2010, 15:22   #8
Torque_Delight
Modded
I don't think so...
Fred that would be a nice add-on :P
Old July 23rd, 2010, 17:35   #9
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Well if you read the text on the upload page it keeps refering to pictures as PhotoS. Strange.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old July 23rd, 2010, 20:07   #10
ninedee_golf_tdi
Well I did read the text on the upload page several times and did notice it say photoS but couldn't figure out how to upload several at once. Does anyone know if you can you upload more than one picture at a time ?
Old July 25th, 2010, 05:39   #11
T_D_I_POWER
T_D_I_POWER's Avatar
I simply use MSO 2003 w/ 2007 upgarde to re-size a large picture to a web size.
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old July 25th, 2010, 09:51   #12
VW Derf
Administrator
Nope, not at this point.
I don't think so...
I agree. Let me see what I can do/if there is any potential for that.
To resize pictures just upload the full size version. The picture server will automatically keep a copy of the full size image as well as make a medium sized version which is fine of the forums and an thumbnail.
Aspherical Mirrors
- Past VWs:
Old July 30th, 2010, 19:57   #13
VW Derf
Administrator
It is now possible to upload five non multi media files at a time now.
Aspherical Mirrors
- Past VWs:
Old July 30th, 2010, 20:00   #14
Torque_Delight
Modded
Well done !
Old August 7th, 2010, 09:50   #15
Roller
Fuel Economy: 38 to 40ish
Hey, what he said is KEY. You can't upload photos that you have downsized if you still want to be able to show the 'medium' size in your thread. There is some minimum picture size threshold that once your photo is below it (like if you shrink the size before you upload), the little icon next to 'linked thumbnail' won't appear as an option, then you're stuck with only uploading the thumbnail link in your thread. Long story short, upload full sized photos -- funny since I shrink them to save space on the server!
04 Jetta wagon 5sp, VNT17, Kermatune
Roller is offline   Reply With Quote
Page generated in 0.17526 seconds with 9 queries
[Output: 135.07 Kb. compressed to 113.27 Kb. by saving 21.80 Kb. (16.14%)]
