First - thanks to all who have written info on this in previous threads.
Second - I am half way though my swap and have discovered a few things not previously mentioned.
Let's start with the REAL parts list: (Work in progress will update as I complete my swap.)
6 Speed transmission
Passenger side heat shield above axle
240mm flywheel/clutch (get new bolts if reusing used parts)
Pilot bearing 056105313C
6 speed shifter & rods, boot and knob.
Starter
Axles. (larger inner CV than 5 speed units)
5.5mm spacer plate between bellhousing and transmission 01E 103 551B if using stock 240mm DMF. 228mm can do without.
*** 16x18.8 dowel pins x 2. 01E 301 153E. No one has mentioned this before!
Clutch switches and pigtails.
Clutch pedal with longer mounting pin
Brake pedal and rubber - OR cut and modify your original one.
Clutch master cyl, slave cyl and line. Apparently one from a NA 1.8T will work fine
Longer upper starter bolt
Longer bolt + nut for passenger side lower through block
Also used a bolt + nut to relocate the starter wire support on the passenger side. There is an extra through hole up there not used.
Fresh gear oil (recommended)
New outer CV boots (recommended)
In the beginning.........We had a funny looking brake pedal, and something was missing.
In this image you can see where the master bolts in above the steering shaft. There are two grommets you will pull out. Push them through to the engine side. Bolt up the master without the pedal attached
garage flooring dallas. It sticks through the firewall far enough to clip in the line after. Then put the pedal in. It's a tight squeeze, but just fits between the fuse panel and the steering shaft. Just rotate it around, it goes.
Here's how I dealt with the brake pedal, as I didn't get a donor one:
The all important 3 pedal shot:
I chose the perfect timing to do my swap. There was a vibration in the front right, which I had assumed was from a torn CV boot eating up the outer joint. WRONG:
Here you will notice 2 bolts missing. The other 4 also were well on their way out. Car was dealer service prior to my purchase.....
More updates to come....
