BHW/01E 6 Speed Swap
MILESB
alberta
03 Jetta, 04 Passat Wagon
In that case, good luck. Those are getting increasingly difficult to find used. The shifter, base and plastic housing are relatively easy to find since they were essentially the same on the B5 A4/S4 and C5 A6/S6/allroad. The rods however differ by model, and even by year within a model. You're specifically looking for the 6-speed setup from a B5 S4 or C5 A6/allroad that had the 2.7 biturbo V6. The shift selector rod and the cross rod can vary depending on whether your transmission uses the "early" or "late" style mounting for the cross rod. Check the JH Motorsports site for info on the B5 S4 shifter, they have pictures showing the differences. There's also a rare, undocumented 3rd setup with the cross-rod attached to the top
middle of the transmission. My own 01E came from a later model C5 A6 (euro TDI model), but has both the "early" and "late" style mounting holes, and I was able to find an S4 "early" style shift selector rod assembly on eBay that works fine. I also upgraded to the JHM HD cross-rod, solid short throw shifter, solid selector bushing, stiffer centering spring, and weighted selector arm. Only reason I remember all this is because I just rebuilt that transmission from scratch a couple weeks ago :D
edit: shift selector rod is part number 8D0711151 (optionally followed by letter A, B, C, D or H depending on the style) and includes the cross rod
shift locator rod is part number 8E0711271 (followed by letter A, B C or D depending on style)
Hello, thank you. Is there a vehicle model years that I need to stay within
GoremanX
Vermont
2001 Audi A4 Avant quattro w/BHW TDI & 01E 6-speed
Depends which 01E you have. Take a photo of the cap on the opposite side of the selector arm, the one that has the electrical connector for the reverse switch.
Another fun quirk, the "early" and "late" style rods change mid-year :rolleyes:
MILESB
alberta
The plan is to get a DQS gearbox, I’ve got a AVF motor with a manual crank from UK. The motor and petals are all I have gathered so far. The shifter assembly, starter and the spacer are next on my shopping list.
deaster
White Mtns - NH
02 Golf TDI Variant - 80 Caddy Diesel - 04 WDI Passat Variant
@Braddman I sent you a PM.
I found a great solution to the issue of not having enough transmission input shaft engagement in the pilot bearing. I bought an HK1522 (21mm OD, 15mm ID, 22mm long) drawn cup needle bearing and a 21mm OD, 15mm ID, 3mm width oil seal to keep the grease in the bearing and the dirt out. I got the seal and bearing from a local bearing supplier for about $7 each. The original pilot bearing is 16mm long with a built in oil seal which reduces the amount of the rolling element length to about 15mm. I took a piece of mild steel drilled it 20mm deep with an 11/16” bit bored it to 14mm deep about 20.95mm diameter (basically just a press fit for the bearing.) Turned a 45 deg. chamfer 4mm from the end of the bar stock to support the bearing inside the chamfer in the crank. I turned the diameter of the material to 0.25mm smaller than the flywheel bore which is around 35mm +-5mm (I don’t remember the actual size). I parted the bar stock off at 17mm long. This gives me 11mm of bearing engagement in the crank and 11mm in the bearing and seal retainer I made. The total input shaft support is about 14.5mm. I installed the oil seal with the numbers facing the bearing to prevent dust getting in the bearing. I have not had a chance to run my car after installing the new clutch but I sure this bearing setup will work great.
Uberhare
Ontario, Canada
Too many.
I'm considering selling my 6 speed wagon complete and AWD parts as a package deal:
Body is rusty - but mechanically very good. Runs and drives except for a broken front spring.
BHW w/350K kms (stock BSM)
Malone Tuned ECU for 6 speed
01E 6 Speed (GVS)
Car has stock DMF 240mm installed currently
New in box: LUK DMF & Sachs SRE clutch kit
01E AWD trans (GLX / 3.89 R&P)
Matching rear diff from W8 Auto (3.89 R&P)
Send me a PM if you are serious. Only offering as a complete package.
Optional: 2003 Passat W8 Wagon - runs & drives, needs fenders/hood/windshield
Uberhare
Ontario, Canada
Too many.
My plan was to use all the bits listed above to build a nice BHW / AWD car with the 01E manual. However I am not so ambitious these days and plans have changed. I'll just keep driving my other W8 wagon till something expensive breaks....
vwztips
Greenville, SC
2005 Passat GLS Wagon TDI 5 spd manual w/BSM delete 2011 Tiguan TDI/DSG 2005 Audi A4 Avant 6MQ TDI 2011 BMW X5 35d
It will never break. Because you want it to.. lol
yahmon
canada
04 passat tdi 6spd stage2 webasto TC3 , 04 passatW8 6 spd, 10 Jetta TDI 6spd stage 1
they have w8 manuals. just rare
Have one of those 6 speeds, factor in the trim color package and it was the only one, not to mention it was original canadian destination to begin with it being km/h. They are rare but not a serious collector item. Was also contemplating the diesel swap, got the 4wd diesel 6speed for it too.
MILESB
alberta
6 speed half shafts
Hello, happy new year everyone. Does anyone know the part number for the half shafts I would need for a 04 tdi Passat 6-speed conversation? The gearbox will be from Europe.
Windex
Cambridge
05 B5V 01E FRF
Depends on the flange size you go with.
108mm are different than the 120mm. I went with the 108 and will dig up the part #s
imo000
Cambridge
2009 M-B ML320 Diesel & '05 Passat TDI Manual 5-Speed
I think I also have the smaller flange on my FHN manual transmission . The CV axles for mine were from a 1.8T manual Passat.
MILESB
alberta
01E 6 Speed (GVS)
Hello, would you happen to know the part numbers for the front axles or half shafts, if they’l work in a front wheel drive 6 speed?
sword_guy
NECT
2004.5 2.0L Passat Wagon
I have some questions about your 6 Speed swap, if you don't mind. I asked Dutch Auto about a 6 speed and they said the DMF won't work unless I change my crankshaft. What does he mean? I also heard the SMF will cause the transmission to damage itself. Is there a mod so that the DMF can be used? If it's covered somewhere in the forum thread, I can't find it. Can the final drive gears be changed on those transmissions? Also, does the parts list in the post include everything you ended up needing for the swap? Wondering which axles you ended up using. Thanks a lot if you can answer this stuff!
Uberhare
Ontario, Canada
Too many.
The difference is the length of the crankshaft where the pilot bearing goes in. It's covered about 10 pages back. You can get away with the stock BHW crank. Just don't drive the bearing all the way in.
sword_guy
NECT
Thank you. I wondered if that was it. Nice to know it's that simple. Do you have part numbers for the driveshafts? Or a vehicle they would have come from? Apologies if that was also covered. I tried my best to read through the whole post.
Uberhare
Ontario, Canada
Too many.
The axles came from the same vehicle as the trans. Sorry don't have the part numbers handy. You can change the flanges on the trans and use the smaller diameter shafts that are more readily available here. I think someone on here has the part number for the flanges? I never looked into it myself.
sword_guy
NECT
That's ok. Thanks for replying. That only leaves the last question. Are the final drive gears changeable on these? I want to get really tall gearing. Having a tough time finding reliable gear ratio data.
Windex
Cambridge
05 B5V 01E FRF
No, no aftermarket gears available for the O1E. If you get a dqs or frf from a V6 tdi, it will have the tallest gearing available in a fwd 01E gearbox
imo000
Cambridge
Why do you want that?
sword_guy
NECT
Land speed record attempt? Or maybe trying to push the BSFC out the bottom of the curve to burn more fuel?
Realistically, 2000 to 2500rpm range is ideal for best economy, lower the rpm, it gets worse. Raise it, it gets worse.
You caught me. Definitely land speed record. Seriously though, fuel economy is greatly dependent on load. At extremely low loading (level ground), it's more efficient to run at a lower RPM. I ran some tests. We have a dam nearby that's about half a mile long and level. My car will allow a shift at 41 mph (indicated), but it will not automatically shift until 45. I set cruise at 41 and observed instantaneous fuel economy. Forced the shift into 5th and economy went up by roughly 12mpg. There are times when a low RPM is better. Taller gearing with a 6 speed would allow the ability to adjust accordingly.
For the V6 transmissions you mentioned, I was under the impression that they would not bolt up to the 4cyl engine. Is that not the case?
Windex
Cambridge
05 B5V 01E FRF
The 6 cyl tdi transmission will indeed bolt up to the 4 cyl tdi engine. The bolt pattern is the same at the 4 cyl 01E transmission.
If you need any more convincing that it will fit, I can send you pictures of the FRF 6 cyl 6 speed that has been in my car for the last 200k miles.
MILESB
alberta
6 speed gearbox mounting bracket
I’m still piecing together all the parts for my DQS 6 speed conversion project. I’m hoping that someone knows the part numbers for the left and right of gearbox mounts? Also, the part number for the pillows between those and car body? And Is there a part number for the piece of sheet metal that is between bell housing and motor? Not the 5.5 spacer.
