Amsoil
The AMSOIL 5W-40 for European Engines meets the requirements to use in the TDI. As a pure synthetic PAO based oil it cannot be beat!!!!
AMSOIL Synthetic 5W-40 European Engine Oil
- Specially formulated for the lubrication needs of European gasoline and diesel cars and light trucks.
- Advanced AMSOIL polyalphaolefin (PAO) synthetic base stocks, premium additives and a broad 5W-40 viscosity rating.
- Allows the maximum extended drain intervals recommended by European automakers.
- Provides second-to-none protection and performance in the most demanding operating conditions.
- Surpasses the North American SAE and European ACEA oil specifications for high temperature/high shear (HTHS) viscosity.
- Does not shear back in the high temperature/high shear conditions of today's smaller, high RPM automobile engines.
- High quality anti-wear additives provide superior engine performance.
- Resists effects of heat, blowby chemicals and oxidation.
- Won't vaporize (burn off) in the high temperatures that vaporize conventional motor oils for consistent high temperature protection, improved fuel economy and reduced oil consumption and emissions.
- Provides cold temperature fluidity to -59 degrees F (-51 degrees C) for easy engine cranking, fast starts and immediate start-up protection.
- Rust and corrosion inhibitors protect iron parts, as well as copper, lead and aluminum bearing materials.
- Recommended for European gasoline and diesel vehicles, including but not limited to Saab, Audi, Volkswagen, Mercedes-Benz, Volvo, Land Rover, Opel, Mini Cooper, BMW, Peugeot and Porsche.
- Meets or exceeds the following specifications for domestic and foreign gasoline engines: API SL, CI-4, CF - ACEA A3, B3, B4 - BMW LL-01/98 - DaimlerChrysler 229.1, 229.3, 229.5 - Opel Long Life Service Fill GM-LL-A-025 - Opel Diesel Service ill GM-LL-B-025 - Porsche - Volvo - SAAB - Volkswagen 501.01, 502.00, 503.00, 505.00, 506.00
Cliff
Twin-City-Synthetics.com
