V10: low power and engine vibration
da.hs
SK, Canada
2010 Golf, DSG, silver (from new). 2010 Audi Q7 (from 2016), 2004 Touareg V10 (from 2018)
This machine is a bit temperamental, sometimes has startup messages of "Running Gear Fault" or "Exhaust: workshop" which generally disappear the next time it's used. Something different now.
On Friday: normal. On Sunday: low power, can just about do 50MPH on highway uphills (far from normal) and significant engine vibration when under any load (smooth when running downhill). Today; no engine vibration but power still low.
VCDS log below, taken just before today's run. Some of the codes may be old, I do not recall when I last cleared them.
Would much appreciate advice from anyone familiar with this engine. Thanks.
Monday,29,June,2020,17:43:36:21237
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
Mileage: 215330km-133799mi Repair Order:
Chassis Type: XX (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 215330km-133799miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 997 016 R HW: 028 101 172 9
Component: V10 5,0L EDCG000AGMª2813
Revision: 5KO3 Serial number: XXXXXXXXXXXXXX
Coding: 0060575
Shop #: WSC 91403 999 84520
VCID: 29591D4F83ABD7CE7C-5140
8 Faults Found:
19456 - Glow Plug Indictor Light (K29)
P3000 - 000 - Malfunction Message from Instrument Cluster
Freeze Frame:
RPM: 0 /min
Torque: 379.2 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Temperature: 9.0°C
17668 - PD Unit Injector: Cylinder 1 (N240)
P1260 - 000 - Implausible Signal
Freeze Frame:
RPM: 1638 /min
Torque: 197.5 Nm
Speed: 52.4 km/h
Load: 18.0 %
Voltage: 13.07 V
Temperature: 70.2°C
(no units): 127.0
17678 - PD Unit Injector: Cylinder 4 (N243)
P1270 - 000 - Regulation Range Exceeded
Freeze Frame:
RPM: 1386 /min
Torque: 134.3 Nm
Speed: 34.5 km/h
Load: 17.3 %
Voltage: 13.22 V
Temperature: 65.7°C
(no units): 127.0
17675 - PD Unit Injector: Cylinder 3 (N242)
P1267 - 000 - Regulation Range Exceeded
Freeze Frame:
RPM: 1638 /min
Torque: 276.5 Nm
Speed: 97.6 km/h
Load: 0.0 %
Voltage: 13.15 V
Temperature: 69.3°C
(no units): 127.0
17672 - PD Unit Injector: Cylinder 2 (N241)
P1264 - 000 - Regulation Range Exceeded
Freeze Frame:
RPM: 1638 /min
Torque: 300.2 Nm
Speed: 97.6 km/h
Load: 0.0 %
Voltage: 13.00 V
Temperature: 69.3°C
(no units): 127.0
18091 - Powertrain Data Bus
P1683 - 000 - Implausible Message from Airbag Controller - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001100
Bin. Bits: 00000000
Torque: 0.0 Nm
18057 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 2.4 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Torque: 0.0 Nm
16685 - Cylinder 1
P0301 - 000 - Misfire Detected
Freeze Frame:
RPM: 588 /min
Torque: 110.6 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.45 V
Temperature: 55.8°C
(no units): 98.0
Readiness: 1 3 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 BB
Component: AL 600 6Q 0467
Coding: 0004136
Shop #: WSC 31414 000 00000
VCID: 6FED33577DCFF9FEE2-5140
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0022785
VCID: 3A7BD203760D6C5605-5140
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: Kessy 6400
Coding: 0131304
VCID: 2F6DF357BD4FB9FEA2-5140
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
5 Faults Found:
00576 - Terminal 15
009 - Open or Short to Ground
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
01049 - Supply Voltage Term 50
009 - Open or Short to Ground - Intermittent
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77FD0B37059FB13E3A-5140
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0021030
VCID: 3561C13F5F13832EE8-5140
1 Fault Found:
01592 - Air Quality Sensor (G238)
008 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3001
Coding: 0079068
Shop #: WSC 91403 999 54351
VCID: 479DBBF735FF01BE8A-5140
2 Faults Found:
00907 - Intervention load Management
000 - -
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSª2813
Coding: 0060575
2 Faults Found:
18361 - Turbocharger Control Module 2
P1953 - 000 - Defective - Intermittent
Freeze Frame:
RPM: 1722 /min
Torque: 284.4 Nm
Speed: 80.9 km/h
Load: 37.6 %
Bin. Bits: 00000000
Bin. Bits: 00100000
Absolute Pres.: 1458.6 mbar
Absolute Pres.: 1876.8 mbar
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2562 /min
Torque: 316.0 Nm
Speed: 89.3 km/h
Load: 61.2 %
Voltage: 13.07 V
Bin. Bits: 00101000
Absolute Pres.: 2101.2 mbar
Absolute Pres.: 1652.4 mbar
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0C Airbag 8.4E+ H10 0952
Coding: 0012355
VCID: 2541117FEFB3F3AE58-515C
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000232
VCID: 4189A5EF1BDB3F8E44-515C
Address 17: Instruments Labels: None
Part No: L6 920 880 S
Component: KOMBIINSTRUMENT RB4 2921
Coding: 0007331
VCID: 0F2D53D71D0F99FE82-5140
Address 18: Aux. Heat Labels: 7L6-819-008.clb
Part No: 7L6 815 071 B
Component: Standheizung E1MAC 0235
Coding: 0000000
VCID: 3169F52FAB7BAF0EB4-5140
1 Fault Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 55289 000 104857
VCID: 70EF302B60F1E606FB-5140
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 04076CFB4449EAA62F-5140
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F0DE3172DAF897E72-5140
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
VCID: 66C35673523538B691-5140
1 Fault Found:
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 3663C63342158836E1-5140
Address 36: Seat Mem. Drvr Labels: None
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
Shop #: WSC 91449 999 58632
VCID: 67DD5B77553F21BEAA-5140
1 Fault Found:
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2N HSG 0201
Coding: 0000085
Shop #: WSC 91403 999 59052
VCID: 3E73DE136A25407639-4AE8
Subsystem 1 - Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0201
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective - Intermittent
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 466
Component: 12K-AUDIOVERST 0108
VCID: 71E9352F6BFBEF0EF4-5140
1 Fault Found:
00464 - Control Module with Display for Radio and Navigation (J503)
004 - No Signal/Communication - Intermittent
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 377DCB37451F713EFA-5140
1 Fault Found:
00003 - Control Module
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
Shop #: WSC 91403 999 00503
VCID: 387FC80B48017E46F3-5140
1 Fault Found:
02580 - Trailer; Right Brake Lamps (M66)
011 - Open Circuit
Freeze Frame:
Count: 0
Count: 0
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 G
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009268.03
VCID: 3B75D7077937555E1E-515C
Address 75: Telematics Labels: 3D0-035-617.lbl
Part No SW: 3D0 035 617 A HW: 3D0 035 617 A
Component: Telematik NAR1 0106
Coding: 0076510
Shop #: WSC 91403 999 54020
VCID: 1E333E93CAE5207619-515C
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - MIL ON
Address 76: Park Assist Labels: None
Part No: 7L0 919 283 E
Component: 0E Einparkhilfe 0907
End-------------------------(Elapsed Time: 07:54)--------------------------
Matt-98AHU
Vallejo, CA
2014 Passat SE DSG, 2005 Passat wagon, 2004 Touareg V10.
Start by taking a log of measured value block 23 in both ECUs.
You can do them both at the same time by using address 31, it allows you do retrieve codes, watch live data and perform basic settings in both ECUs simultaneously.
So, in address 31 "Engine-Other," go to measured values, block 23, top block will be bank 1, 2nd block bank 2's readings. Start at idle, put it in gear, go for a quick spin around the block and hit wide open throttle at some point. Let's see how the injector BIP readings change with engine load and RPM.
da.hs
SK, Canada
(this may be a near-duplicate post.. something went wrong with the previous attempt)
I don't see the ability to use address 31, (no data from that setting), ore "engine-other". I do have a log file from block 23, will post a bit below in next post. I could email the CSV file to you - would be happy to pay for your time
Cleared DTCs before today's run. The only significant DTCs to reappear are shown below. No shuddering today, power somewhat better but below normal
Wednesday,01,July,2020,16:14:40:21237
www.Ross-Tech.com
VIN: WVGGH67L24D065386 License Plate: V10
Mileage: 215370km-133824mi Repair Order:
VIN: XXXXXXXXXXXXXXXXX Mileage: 215370km-133824miles
Coding: 0060575
2 Faults Found:
Freeze Frame:
RPM: 1218 /min
Torque: 189.6 Nm
Speed: 72.6 km/h
Load: 15.7 %
Voltage: 13.38 V
Temperature: 44.1°C
(no units): 127.0
Freeze Frame:
RPM: 1575 /min
Torque: 189.6 Nm
Speed: 94.0 km/h
Load: 17.6 %
Voltage: 13.15 V
Temperature: 60.3°C
(no units): 127.0
Readiness: 1 2 0 0 0
Coding: 0060575
1 Fault Found:
Freeze Frame:
RPM: 2520 /min
Torque: 323.9 Nm
Speed: 86.9 km/h
Load: 64.7 %
Voltage: 12.92 V
Bin. Bits: 00001000
Absolute Pres.: 2193.0 mbar
Absolute Pres.: 1723.8 mbar
da.hs
SK, Canada
Wednesday 1 July 2020 15:31:38:21237-VCID:29591D4F83ABD7CE7C-5140 VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
070 997 016 R V10 5.0L EDCG000AGMª2813
Group A: '023 Group B: Not Running Group C: Not Running
(no units) (no units) (no units) (no units)
TIME TIME TIME
Marker STAMP STAMP STAMP
0.09 100 114 104 106
0.26 97 111 101 107
0.44 97 111 101 107
0.6 97 111 101 107
0.75 97 111 105 111
0.92 97 111 105 111
1.09 97 111 105 111
1.26 97 109 103 111
1.44 102 109 100 109
1.6 100 109 100 109
1.77 100 109 100 107
1.94 97 110 100 104
2.12 98 110 100 104
2.29 98 110 100 108
2.47 102 110 100 108
2.65 103 108 101 108
2.82 101 108 101 109
3 101 108 101 109
3.17 99 108 98 109
3.35 99 108 102 109
3.51 97 108 106 110
3.68 97 109 104 110
3.85 97 109 101 110
4.02 95 109 101 114
4.2 99 109 101 114
4.36 99 110 101 114
4.52 99 110 101 114
4.7 100 111 99 112
4.87 100 111 103 109
5.05 104 111 103 106
5.23 104 112 100 106
5.38 104 116 100 106
79.27 127 127 127 127
79.43 127 127 127 127
79.6 127 127 127 127
79.78 127 127 127 127
79.95 127 127 127 127
80.12 127 127 127 127
80.3 127 127 127 127
80.47 127 127 127 127
80.65 127 127 127 127
80.82 125 127 127 127
81 127 127 125 127
81.16 127 127 126 127
81.34 127 127 127 121
81.52 127 127 127 119
81.67 127 127 127 122
81.85 127 127 127 117
82.02 127 127 124 117
82.2 127 127 125 116
82.38 125 127 123 111
82.53 123 127 121 108
82.69 118 127 123 113
82.88 109 127 116 119
83.05 121 127 113 114
83.22 110 127 117 111
83.38 107 126 116 107
83.55 106 127 112 115
83.73 98 125 103 111
83.9 99 124 108 107
84.07 109 124 102 105
84.25 108 126 107 101
84.42 101 125 110 107
84.58 100 127 109 115
84.76 100 126 108 102
84.93 100 125 105 104
85.1 93 115 105 108
Matt-98AHU
Vallejo, CA
Very odd. I've seen a couple cars with a single injector with super high readings like that, but to have all of them reading super high is very unusual.
Makes me wonder if there's an injector harness issue with the shared ground, or a bad ground on the engine harness side.
Basic interpretation of the injector "beginning of injection period" measurements here: it's a measurement in microseconds of how much of a deviation it's taking the injector solenoids to close vs. the computer's mapped expectations for the conditions present. The computer assumes the solenoid is closed by watching for a spike in the current it's directly sending to each injector.
If the numbers are negative, that indicates the solenoids are closing faster than normal, which can indicate a loss of fuel pressure since the theory goes the injectors aren't having to fight as much pressure to fully close. If the numbers are positive, this can indicate healthy fuel pressure, or if the numbers are WAY too far positive (as in numbers approaching 100 or greater), this can mean there's more likely to be an injector problem with the solenoid or the wiring to it.
Being that ALL injectors in bank 1 are at some point maxing out the reading at 127 at some point, this is pointing to there likely being a shared wiring problem to them, also backed up by the fault codes stored for at least 2 injectors hitting their regulation limits. The ground side is shared between all the injectors on a bank. The computer sends power to each injector individually and directly to operate them.
So, lucky you, looks like you get to start tracking down wiring problems. Need to suss out if it's in the injector harness that lives inside the head or in the engine wiring harness somewhere.
Matt-98AHU
Vallejo, CA
Measured value block 18 might also shed some light on the injector situation. That block shows injector status in a digital-decimal form which I can decode.
You could do the same with that block, wide open throttle run logging 18, see if there's any other hints it gives us, but sometimes it's not at all helpful.
Fourdiesel
SW Wash. USA
'04 Touareg V10 TDI
Just a thought but have you checked for any unusual cam wear? That wouldn't explain all the issues - some of them seem to indicate wiring issues (wet wiring shorting to other wires and to ground occasionally).
The turbo faults could be wiring caused of could indicate one of the turbos is crudded up and the VNT vanes are not adjusting correctly - this will also result in loss of power because of incorrect boost. If you can get at them, see if the VNT levers move freely.
Good luck.
da.hs
SK, Canada
The intermittent nature does make electrical seem likely. It's up on a lift now (though only a 10ft high garage so cannot lift very high) and will look harder in the next few days. I do notice the undertray has disappeared.. so perhaps more water in the area than normal. Looks quite clean.
The previous owner said the turbos would occasionally get sticky if it sat parked for too long - and run it hard to fix. I had a single incident about a year ago of low power coming out of a junction and black smoke behind - it recovered and nothing like that since. No significant smoke in the last few days.
There is still an occasional MFD warning "Exhaust: Workshop" which sets the MIL - yet the only MIL ON in the VCDS log is for the radio (third party head unit so not surprising) which is puzzling.
Coding: 0076510
VCID: 1E333E93CAE5207619-5140
1 Fault Found:
01304 - Radio
Matt-98AHU
Vallejo, CA
Coding: 0076510
1 Fault Found:
01304 - Radio
"Exhaust workshop" is for engine or transmission codes. Addresses 01, 02 (transmission) and 11. It's basically saying there's a fault that could affect emissions. Same thing as the check engine light.
Most common issue with these turbos is the external linkage corrodes and then begins to bind. Even the "Turbo Control Module defective" code is more often than not a mechanical limitation caused by corrosion in the linakges. But getting to the upper linkage in particular with the engine in situ is not easy.
It is supposed to be a part of annual maintenance/10k mile oil change intervals to apply the VW lubricating paste to the turbo linkage joints. And if that were infact religiously done, it goes a long, LONG way towards preventing turbo related issues on these. Just where those turbos are situated, they are much more prone to road grime that leads to their corrosion. They are very much exposed to the elements, much more so than 4 cylinders in other chassis and even the newer V6 diesels where the turbo is up top.
da.hs
SK, Canada
Thanks again. I have seen two of your posts on these turbos and it's very helpful information. On my initial look, I could not see them - I assume from underneath? I'll have more time over the weekend. Do you have any pictures of what the linkages look like? It's almost due for service though no warning light yet.
On the principle of fixing the obvious first, I'll replace the engine cover and see if it does any better before getting excited with wiring looms. It was a very wet day Friday when these issues started. I don't know when the cover disappeared - it is entirely possible Friday was the first wet drive since it fell off. Local VW dealer said there is just one replacement cover in North America.. it's on order. Centre cover is available from ebay (Europe) if VW don't have any - less important.
