da.hs
- Joined
- Jul 28, 2012
- Location
- SK, Canada
- TDI
- 2010 Golf, DSG, silver (from new). 2010 Audi Q7 (from 2016), 2004 Touareg V10 (from 2018)
This machine is a bit temperamental, sometimes has startup messages of "Running Gear Fault" or "Exhaust: workshop" which generally disappear the next time it's used. Something different now.
On Friday: normal. On Sunday: low power, can just about do 50MPH on highway uphills (far from normal) and significant engine vibration when under any load (smooth when running downhill). Today; no engine vibration but power still low.
VCDS log below, taken just before today's run. Some of the codes may be old, I do not recall when I last cleared them.
Would much appreciate advice from anyone familiar with this engine. Thanks.
Monday,29,June,2020,17:43:36:21237
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
Mileage: 215330km-133799mi Repair Order:
Chassis Type: XX (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 215330km-133799miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 997 016 R HW: 028 101 172 9
Component: V10 5,0L EDCG000AGMª2813
Revision: 5KO3 Serial number: XXXXXXXXXXXXXX
Coding: 0060575
Shop #: WSC 91403 999 84520
VCID: 29591D4F83ABD7CE7C-5140
8 Faults Found:
19456 - Glow Plug Indictor Light (K29)
P3000 - 000 - Malfunction Message from Instrument Cluster
Freeze Frame:
RPM: 0 /min
Torque: 379.2 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Temperature: 9.0°C
17668 - PD Unit Injector: Cylinder 1 (N240)
P1260 - 000 - Implausible Signal
Freeze Frame:
RPM: 1638 /min
Torque: 197.5 Nm
Speed: 52.4 km/h
Load: 18.0 %
Voltage: 13.07 V
Temperature: 70.2°C
(no units): 127.0
17678 - PD Unit Injector: Cylinder 4 (N243)
P1270 - 000 - Regulation Range Exceeded
Freeze Frame:
RPM: 1386 /min
Torque: 134.3 Nm
Speed: 34.5 km/h
Load: 17.3 %
Voltage: 13.22 V
Temperature: 65.7°C
(no units): 127.0
17675 - PD Unit Injector: Cylinder 3 (N242)
P1267 - 000 - Regulation Range Exceeded
Freeze Frame:
RPM: 1638 /min
Torque: 276.5 Nm
Speed: 97.6 km/h
Load: 0.0 %
Voltage: 13.15 V
Temperature: 69.3°C
(no units): 127.0
17672 - PD Unit Injector: Cylinder 2 (N241)
P1264 - 000 - Regulation Range Exceeded
Freeze Frame:
RPM: 1638 /min
Torque: 300.2 Nm
Speed: 97.6 km/h
Load: 0.0 %
Voltage: 13.00 V
Temperature: 69.3°C
(no units): 127.0
18091 - Powertrain Data Bus
P1683 - 000 - Implausible Message from Airbag Controller - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001100
Bin. Bits: 00000000
Torque: 0.0 Nm
18057 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 2.4 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Torque: 0.0 Nm
16685 - Cylinder 1
P0301 - 000 - Misfire Detected
Freeze Frame:
RPM: 588 /min
Torque: 110.6 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.45 V
Temperature: 55.8°C
(no units): 98.0
Readiness: 1 3 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 BB
Component: AL 600 6Q 0467
Coding: 0004136
Shop #: WSC 31414 000 00000
VCID: 6FED33577DCFF9FEE2-5140
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0022785
VCID: 3A7BD203760D6C5605-5140
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: Kessy 6400
Coding: 0131304
VCID: 2F6DF357BD4FB9FEA2-5140
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
5 Faults Found:
00576 - Terminal 15
009 - Open or Short to Ground
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
01049 - Supply Voltage Term 50
009 - Open or Short to Ground - Intermittent
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77FD0B37059FB13E3A-5140
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0021030
VCID: 3561C13F5F13832EE8-5140
1 Fault Found:
01592 - Air Quality Sensor (G238)
008 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3001
Coding: 0079068
Shop #: WSC 91403 999 54351
VCID: 479DBBF735FF01BE8A-5140
2 Faults Found:
00907 - Intervention load Management
000 - -
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSª2813
Coding: 0060575
2 Faults Found:
18361 - Turbocharger Control Module 2
P1953 - 000 - Defective - Intermittent
Freeze Frame:
RPM: 1722 /min
Torque: 284.4 Nm
Speed: 80.9 km/h
Load: 37.6 %
Bin. Bits: 00000000
Bin. Bits: 00100000
Absolute Pres.: 1458.6 mbar
Absolute Pres.: 1876.8 mbar
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2562 /min
Torque: 316.0 Nm
Speed: 89.3 km/h
Load: 61.2 %
Voltage: 13.07 V
Bin. Bits: 00101000
Absolute Pres.: 2101.2 mbar
Absolute Pres.: 1652.4 mbar
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0C Airbag 8.4E+ H10 0952
Coding: 0012355
VCID: 2541117FEFB3F3AE58-515C
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000232
VCID: 4189A5EF1BDB3F8E44-515C
Address 17: Instruments Labels: None
Part No: L6 920 880 S
Component: KOMBIINSTRUMENT RB4 2921
Coding: 0007331
VCID: 0F2D53D71D0F99FE82-5140
Address 18: Aux. Heat Labels: 7L6-819-008.clb
Part No: 7L6 815 071 B
Component: Standheizung E1MAC 0235
Coding: 0000000
VCID: 3169F52FAB7BAF0EB4-5140
1 Fault Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 55289 000 104857
VCID: 70EF302B60F1E606FB-5140
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 04076CFB4449EAA62F-5140
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F0DE3172DAF897E72-5140
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
VCID: 66C35673523538B691-5140
1 Fault Found:
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 3663C63342158836E1-5140
Address 36: Seat Mem. Drvr Labels: None
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
Shop #: WSC 91449 999 58632
VCID: 67DD5B77553F21BEAA-5140
1 Fault Found:
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2N HSG 0201
Coding: 0000085
Shop #: WSC 91403 999 59052
VCID: 3E73DE136A25407639-4AE8
Subsystem 1 - Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0201
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective - Intermittent
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 466
Component: 12K-AUDIOVERST 0108
VCID: 71E9352F6BFBEF0EF4-5140
1 Fault Found:
00464 - Control Module with Display for Radio and Navigation (J503)
004 - No Signal/Communication - Intermittent
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 377DCB37451F713EFA-5140
1 Fault Found:
00003 - Control Module
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
Shop #: WSC 91403 999 00503
VCID: 387FC80B48017E46F3-5140
1 Fault Found:
02580 - Trailer; Right Brake Lamps (M66)
011 - Open Circuit
Freeze Frame:
Count: 0
Count: 0
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 G
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009268.03
VCID: 3B75D7077937555E1E-515C
Address 75: Telematics Labels: 3D0-035-617.lbl
Part No SW: 3D0 035 617 A HW: 3D0 035 617 A
Component: Telematik NAR1 0106
Coding: 0076510
Shop #: WSC 91403 999 54020
VCID: 1E333E93CAE5207619-515C
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - MIL ON
Address 76: Park Assist Labels: None
Part No: 7L0 919 283 E
Component: 0E Einparkhilfe 0907
End-------------------------(Elapsed Time: 07:54)--------------------------
www.Ross-Tech.com
Coding: 0060575
8 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 379.2 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Temperature: 9.0°C
Freeze Frame:
RPM: 1638 /min
Torque: 197.5 Nm
Speed: 52.4 km/h
Load: 18.0 %
Voltage: 13.07 V
Temperature: 70.2°C
(no units): 127.0
Freeze Frame:
RPM: 1386 /min
Torque: 134.3 Nm
Speed: 34.5 km/h
Load: 17.3 %
Voltage: 13.22 V
Temperature: 65.7°C
(no units): 127.0
Freeze Frame:
RPM: 1638 /min
Torque: 276.5 Nm
Speed: 97.6 km/h
Load: 0.0 %
Voltage: 13.15 V
Temperature: 69.3°C
(no units): 127.0
Freeze Frame:
RPM: 1638 /min
Torque: 300.2 Nm
Speed: 97.6 km/h
Load: 0.0 %
Voltage: 13.00 V
Temperature: 69.3°C
(no units): 127.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001100
Bin. Bits: 00000000
Torque: 0.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 2.4 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Torque: 0.0 Nm
16685 - Cylinder 1
Freeze Frame:
RPM: 588 /min
Torque: 110.6 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.45 V
Temperature: 55.8°C
(no units): 98.0
Coding: 0004136
Coding: 0022785
Coding: 0131304
Component: ELV XXXX
5 Faults Found:
00576 - Terminal 15
011 - Open Circuit
011 - Open Circuit
Coding: 0021030
1 Fault Found:
Component: 3001
Coding: 0079068
2 Faults Found:
000 - -
Coding: 0060575
2 Faults Found:
Freeze Frame:
RPM: 1722 /min
Torque: 284.4 Nm
Speed: 80.9 km/h
Load: 37.6 %
Bin. Bits: 00000000
Bin. Bits: 00100000
Freeze Frame:
RPM: 2562 /min
Torque: 316.0 Nm
Speed: 89.3 km/h
Load: 61.2 %
Voltage: 13.07 V
Bin. Bits: 00101000
Coding: 0012355
Coding: 0000232
Coding: 0007331
Coding: 0000000
1 Fault Found:
00664 - Fuel gauge
Coding: 0000006
Coding: 0000003
1 Fault Found:
Coding: 0015521
Coding: 0000003
1 Fault Found:
Coding: 0000085
1 Fault Found:
1 Fault Found:
Coding: 0000004
1 Fault Found:
Coding: 0000002
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Count: 0
Count: 0
Coding: 0076510
1 Fault Found:
01304 - Radio
