Feb 8 2014 Failure
- Miles on car at failure: 15000
- Build date: May 2013
- Corrective actions from dealership: Turbo, Exhaust Manifold, DPF & Related.
- Outside air temps at failure: 18F
- Failure warning signs, if any: Increasing Turbo Noise over 100 miles. Barely noticeable loss of power. Several instances as what others have described as running a hammer handle over a slinky toy. Last... GP & CEL accompanied by immediate loss of power.
- Warning lights on dash/MFI:Glow plug light flashing & CEL
- Problems since replacement: still at dealer
- Repair time: eta less than 1 week
- Any dealer divulged info on other incidents involving other failures: Hasn't been discussed at this point.
- Did the dealership perform all maintenance and on schedule: All maintenance is done in-house. I know our cars from stem to stern. We have a fully equipped shop.
- If not dealership, what oil was used/miles on oil:Liquid Moly top tech 4200. Changed at 9500 mi. along with filter. General inspection also completed at this time. All nominal.
- Are you the original owner of the car:Yes
- Did you baby your car or not: Respect is a better term. The car is always respected but not babied.
- Do you interrupt DPF regenerators: No
- How long is your daily commute: Average 500 miles/week
- Transmission:Manual
Failure Log:
Monday,10,February,2014,09:21:22:09822
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: 1VWBN7A32DC141715 License Plate: MILLER
Address 01: Engine Labels: 03L-906-012-CKR.clb
Control Module Part Number: 03L 906 012 BM HW: 03L 907 309 S
Component and/or Version: R4 2,0L EDC H24 5557
Software Coding: 00190012042400000000
Work Shop Code: WSC 09003 957 00200
ASAM Dataset: EV_ECM20TDI01103L906012BM 004007 (VW41)
VCID: 70E4C03DAB854D9E643-8025
6 Faults Found:
10624 - EGR System
P0402 00 [101] - Excessive Flow
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 24172 km
Date: 2008.14.05
Time: 15:42:43
5171 - Boost Pressure Regulation
P0299 00 [109] - Control Range Not Reached
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 24167 km
Date: 2008.14.05
Time: 15:38:46
8809 - Cylinder 3 Internal Pressure Sensor
P13D6 00 [101] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 24174 km
Date: 2008.14.05
Time: 15:43:39
8808 - Cylinder 2 Internal Pressure Sensor
P13D3 00 [101] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 24174 km
Date: 2008.14.05
Time: 15:43:39
12896 - Boost Pressure Regulation
P0299 00 [237] - Control Range Not Reached
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 24167 km
Date: 2008.14.05
Time: 15:38:46
9126 - Actuator Module for Turbocharger 1
P00AF 00 [096] - Stuck
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 24173 km
Date: 2008.14.05
Time: 15:43:09
Readiness: 1 1 0 0 0
