Update: The Passat's turbo warranty has been extended to 10 years or 120,000 miles, whichever comes first.
http://pics.tdiclub.com/data/3209/vwp-14-04_turbocharger_limited_warranty_extension_2012_-_2013.pdf
Unfortunately it seems that there have been numerous reported turbo failures on our NMS Passats that I have seen recently. Being the investigative type it would be interesting if people that have experienced failures could update the group on the facts surrounding the failure.
This thread is a data collection thread ONLY. General discussion and followup questions about turbo failures should happen in the discussion thread found here: http://forums.tdiclub.com/showthread.php?t=360617
username year mi on car trans OAT at failure state build date
*ajanikula
*Iviurtimus
*PassatDriver
*lundervold
*Oasiscrazey
Turbo's reported replaced by CarbonVW, tech at VW shop = 6
It would be nice if people that havent had failures would avoid crapping up the thread so we can determine if there is any common denominator in these known turbo failures and possibly help someone avoid a similar occurance.
If you have had a failure, please post the following.
Passat NMS Turbo Failure SURVEY
In addition to posting in this thread, please click the survey link above - this survey will compile the data and generate failure points on a map.
Map results are here
Report your turbo failure to the NHTSA by using their online report form.
- HellandJ = 2013, 6000 mi, DSG, below 0*, ND, UNK build
- WVU TDI (dads car) = 2013, 9500 mi, 6 Man, 35* at failure UNK, WV, 7/12
- 767Wrench = 2012, 22700 mi, 6 Man, 15* at failure, OH, 4/12
- MBmaring = 2012, 9900 mi, DSG, 15* at failure, MN, 7/12
- TI Master (dads car) =2013, 4K+/- mi, DSG, 50*, OK, 9/12
- Mikerad56 = 2013, 7500 mi, 6 Man, 15* at failure, OH, 9/12
- Rocket Racer = 2013, 7700, 6 Man, 50* at failure, OH, unk build
- 1alfie = 2012, 15,XXX, unk, unk, Canada, unk build
- 1Alfie = 2012, unk, unk, Canada, unk build
- HammerTDI = 2013, 14,500, 6 Man, 35*+/-, Ohio, 8/12
- kilroy = 2012, 10K+/-, Unk, 5*, PA, unk build
- paulk124 = 2013, 5500, 6 man, 25*ish, UT, 8/12
- bigman = Unk, 3000, unk, unk, unk
- AWD9590 = 2013, 7900, 6 man, 20*, NY, 9/12
- Rockwell = 2013, 18,900, DSG, 25*, NH, 7/12
- jetpuck = 2013, 4500, 6 Man, 25*, PA, 8/12
- MandeeC = 2013, 8789, DSG, 50*, WV, 6/12
- EloveVDub = 2013, 6400, Unk, Unk, UT, Unk
- AggieDave = 2012, 23,000, DSG, 60*, Tx, 3/12
- AIRFORCEtdi75 = 2012, 8500, DSG, 30*, NY, UNK
- newtran = 2012, 16,500, 6 Man, 28*, AK, unk
- newtran #2 = 2012, 18,000, 6 Man, 20*, AK, unk
- Axxkicker = 2013, 10,568, DSG, 30*, NJ, unk
- Milanfire22 = 2013, 5-7.5k, 6 Man, 32*, OH, 8/12
- bgglook = 2012, 10-15K, 6 Man, 30*, KS, 9/12
- X_Khan = 2012, 20-30K, DSG, 21*, UT, 2/12
- kruschpa = 2013, 10-15K, DSG, 23*, MN, 7/12
- scpd92 = 2013, 4900, 6 Man, 30*, NY, 10/12
- bboshart = 2013, 6000, 6 Man, 29*, Ontario, 11/12
- zuhalter 82 = 2013, 660, 6 Man, 86*, CA, unk
- Petar.raf = 2013, 10000, DSG, 65*, Canada, unk
- mike518_2002=38.6
- Peterwinkle= 2012, 37K, DSG, 80*, UT, 10/11
- ASCOTT = 2013, 6.6K, DSG, 80*, NJ, 12
- rmd0311= 2013, 40K, 6 M, 55*, NY, 8/12
- Tulipana = 2013, 23K, unk, unk, OK, 7/12
- marsholio= 2013, 39.5K, 6M, 55*, AR, 10/12, 0005/V120, unk
- countryboy1644= 12, 26K, DSG, unk, VA, ?/12
- countryboy1644= 12, 49K, DSG, 20*, VA, ?/12
- NSTDI=2013, 26.4K, 6M, 7*, Nova S, 7/12, 0005, unk
- Oilhammer= Shop repair, 2012, 100K, ?/12, unk, 0005, 0020
- Turbo_Diesel= 2013, 5K, 6M, 0*, WI, ?? 1st turbo
- Turbo_Diesel= 2013, 7.5K, 6M, ?*, WI, ?? 2nd turbo
- Turbo_Diesel= 2013, 10K, 6M, unk, WI, ?? 3rd turbo
- Turbo_Diesel= 2013, 7.8K, 6M, -10*, WI, 6/13 0020/0020
- bboshart= colleague, 2012, unk, unk, Ontario, unk
- dudg = 2013, unk, unk. unk, MN, unk
- passsattdi = 2012, 37K, DSG, 7*, NE, 2/12
- vtski = 2013, 17K, 6M, 7*, VT, unk
- wiseman89 = 2013, 22.5K, DSG, 12*, Canada, unk
- Rmohd = 2012, 12K, DSG, -7*, IL, 1/12
- 1998redwagon = 2013, 15K, 6M, -5, MN, 3/13
- copbait = 2013, 10.5K, DSG, 45*, TN, 11/12, unk, unk
- TDI258 = 2013, 19.3K, DSG, 28*, TX, 11/12, 0005/V500, unk
- nord = 2013, 15K, 6M, 18*, NY, 5/13
- AreaMan = 2013, 10.5K, 6M, 27*, OH, 2/13, 0005/V500, 0020
- dansluga = 2013, 20K, unk, 10*, IL, unk
- Av8r3400 = 2012, 23.5K, DSG, 4*, WI, 5/12, 0005, 0020
- Sardoc = 2013, 22K, unk, unk, MD, unk, unk
- Dead turbo il = 2013, 18.6K, DSG, 23*, IL, 3/13, 0020, 0020
- dee74 = 2012, 38.2K, DSG, 26*, unk, unk, unk
- mlcraig4267 = 2013, 34.5K, 6M, unk, MI, unk, unk,
- mafrif = 2013, 25K, 6M, 0*, MN, 0005/V500, unk
- hermittony = 2013, 52K, 6M, 10*, IN, 8/12, 0005/0020
- Turbo_Diesel = 2013, 9K (929), 6M, -5*, WI, 6/13, 0020, ??
- mlcraig4267 = 2013, 34.5K, ??, 15*, MI, 12/12, 0005/0020
- Ryanav = 2013, 8.6K, 6M, 25*, IA, 6/12, Probable 0020/0020
- tncrom = 2013, 14K, 6M, 0*, IA, 8/13, ??/??
- maryphotoNH = 2013, 25.5K, DSG, 15*, NH, ??, ??/??
- Rockwell (#2) = 2013, 60.5K, DSG, 25*, NH, 7/12, ??/??
- Hauger38 = 2012, 26K, DSG, 2*, CAN, Unk, unk/unk
- Bad Eric = 2012, 61K, DSG, 70*, FL, 11/11, 0005/0020
- newguy = 2013, 15.5K, 6M, 25*, MN, 8/12, unk/unk
- reduetdi = 2013, 9.5K, DSG, 35*, WA, 7/12, 0005/0005 1st
- reduetdi = 2013, 9.55K, DSG, 40*, WA, 7/12, 0005/0005 2nd
- kat1234 = 2013, 10K, unk, unk, OH, unk, unk/unk
- kat1234 = 2013, 30K, unk, unk, OH, unk, unk/unk
- strokendiesel002 = 2013, 37K, DSG, 30*, WI, unk/unk/unk
- Dubbayou = 2013, 5.5K, DSG, 20*, NH, unk/unk/unk
- Glacier Blue = 2013, 28K, DSG, 7*, PA, unk/unk/unk
- Passa_TDI_essel = 2013, 16K, DSG, 40*, NY, unk, unk/0020
- traveler103 = 2013, 15K, 6M, -10*, WI, unk, 0005/0020, 1st
- traveler103, 2013, 17.5K, 6M, 24*, WI, unk, 0020/unk, 2nd
- TypeRod, 2013, 17K, DSG, unk, VA, unk, unk/unk
- Herkguy, 2013, 34.5K, DSG, 21*, unk, MN, unk, 0005/unk
- thenixon, 2014, 10K, 6M, 20*, ME, 9/13, 0020/0020
- dgstrate, 2013, 22.5K, DSG, 20*, MI, unk, unk/unk
- usarmy132, 2012, 32K, DSG, 30*, IL, 4/12, unk, unk
- dereksreynolds, 2013, 30K, 6M, 35*, OH, unk, unk/0020
BadNewsMike (friend, place held awaiting details)
*ajanikula
*Iviurtimus
*PassatDriver
*lundervold
*Oasiscrazey
- Miles on car at failure:
- Build date:
- Corrective actions from dealership:
- Outside air temps at failure:
- Failure warning signs, if any:
- Warning lights on dash/MFI:
- Problems since replacement:
- Repair time:
- Any dealer divulged info on other incidents involving other failures:
- Did the dealership perform all maintenance and on schedule:
- If not dealership, what oil was used/miles on oil:
- Are you the original owner of the car:
- Did you baby your car or not:
- Do you interrupt DPF regenerations:
- How long is your daily commute:
- Transmission (DSG/auto or manual):
- Failed turbo part number (if known):
- Replacement turbo part number (if known):
Did you have the Jan 2015 23N5 software update:
