wjdell said:
TomB I found both papers and yes they say as much as 50% reduction in oil life using bio fuels. One paper 2 parts is from Chevron lubrication the other is from Amsoil tech paper TSB: MO-2006-05-04. Try a search LubricantsUniversity.com if your interested.
Other than AMSOIL being ANTI BD is all their negative assumptions, here is the exact recommendation.
"AMSOIL Motor Oil extended drain interval recommendations
do NOT apply to vehicles using biodiesel
fuels at any mix ratios with petroleum diesel."
Here is the key phrase. 10K is VW recommended oil change interval.
"When using biodiesel fuels at any mix ratio, follow
the OEM recommended oil drain interval"
As well the testing does NOT show any BD dilution of the sample. Blackstone's test for this because I told them about the 100% usage. They have seen NO contamination as claimed by AMSOIL in their assumptions on 100% BD usage.
As well the 2007 Jeep Grand Cherokee with the post combustion injections and the particle filter does NOT show any dilution of the oil from 100% usage either based on ACTUAL testing of the oil.
