ntmzp9
INTRODUCTION:
Let me start off by saying, enjoy this forum and others like it very much. Very helpful information out there, if you know where to look. I have a 2012 VW JSW TDI, bought in January 2015. Long story short, i bought it salvage, didn't do anything with it due to the emission scandal coming out, and then fixed what VW told me to fix (flipping from salvage to prior salvage). 3+ years later of doing what they asked, and waiting for the "prior salvage" issues to get resolved on VW's side, they denied my claim as well as my appeal via email. No clarification as to why. Car has basically sat still during this time. Can't get the fix either. No clue as to why on ANY OF IT. I'm crushed, but i'll get over it and fix this thing properly.
REPAIR:
In "fixing" it, i took to a repair shop here in KC as the alternator mount was broken (interlocks with the HPFP) so timing would be an issue that I'm not familiar with. They timed it, it would move on its own, but not much more than that. i replaced the VNT mechanism, and it runs GREAT. 40 mpg all stock. Until yesterday.
THIS PART SUCKS:
Hop in to run a quick errand, grab my groceries, and car won't stay running more than 1 second. Call a tow, drop me off at house and hook up vcds and get an error code for camshaft/crankshaft signal error (00022 i believe). Let it sit for a few hours, car starts up, test drive it, and at 60mph it dies. Call tow truck, same damn driver appears and tows me home.
In doing some investigative work, i pull timing belt cover off and see one of the roller bolts is loose (small one, top right). Belt is still loose, so i keep digging and find the Large Roller (middle right) BOLT has BROKEN off. Car no go, and i can't catch a break. Its a money pit. Call shop that did timing (less than 200 miles on it since timing work done but its been a few months) and they have - can you believe it - CLOSED THEIR DOORS FOR GOOD a few months ago. MOTHERF!!!!!! They probably reused the bolt, engine torque from belt with WOT probably killed it.
QUESTION:
My luck with life lately has been complete ****. While i wallow in self pity, what do i do? I'm assuming since belt broke and engine quite running, i need to pull heads to look for valve contact and to retime properly? there are a few guides out there for retiming but not much on pulling heads. where do i take the head if it is INDEED damaged? How do i release pressure in fuel line? Would this be same procedure of changing fuel filter or is it in the rail? Would full insurance cover any of this, or would i have better luck finding a train to do a meet and greet with my front end?
Thanks guys for reading my rambling. There's been a ton of other S that's gone on with this car, but this is it in a nutshell. I thought i was home free as i have been driving it finally.....my 2006 vw has 260k miles on it and transmission is going. i need options fairly quickly...
REPAIR:
THIS PART SUCKS:
QUESTION:
