dieselpower04
Do I really have to tear my whole door apart to fix this door switch problem?
The plastic rivets and the associated bracket were to aid in assembly from the factory. There was really no need to replace them. Broken solder joints in the door module are also a fairly common failure mode for the door module.Rollingcircle said:When they pulled the panel out they pushed out the two plastic rivets that holds the lock to the inner panel and never replaced them. Well I guess over the years the vibration on the wire broke the solder connection on the circuit board inside the door lock. I resoldered the connector and it's all set! I did put two screws in where the rivets were to steady the lock and keep this from happening again.
Food for thought.
Jim
Doesn't it have something to do with dirt buildup?NB_TDi said:I'm not really sure why everyone keeps saying disable the auto locks. The microswitch damage isn't from locking or unlocking the doors. It's from closing the doors.
I don't really slam mine much more than needed to make them latch. I don't even use the passenger door much. I'll know more when I get around to taking them apart to see what's up.NB_TDi said:It can, but if damage is the issue it's from closing the door. Some people slam, others ease. The locking action has nothing to do with the microswitch.
Mine was pretty gunked up. Dirt is not a friend to switches. The switch basically sits in such a way that the dirt accumulates around the plunger.darkhorse said:Doesn't it have something to do with dirt buildup?
aNUT, did you ever get that piece and was able to do the comparison to the front switch?aNUT said:The subpart of illustration 14 that's the switch in question is part number: 1j5962104B It's about $30; and looks close enough (both in ETKA and the Bentley) that I'm be willing to take the gamble; that is unless someone has had their Jetta hatch latch apart and wants to shoot me a pic and give me more verification one way or the other...
NOOOOOOOOOOOOOOOOOOOOOOOOOOOO.........All of Us said:ro.sniper:
Thats the problem I see with the glue method of window retention, how the heck do you get it apart the next time something happens! All I can think of is to take everything apart per instructions and when you go to unclamp the window hope/pray the epoxy releases from the window. If not, perhaps a little persuasion in the form of gentle tapping or prying to get it to release. You might even try twisting the clamp parts to get them loose, just don't shatter the window glass. That may turn out to be the tricky part. Go slow and VERY easy and you may not have to find a replacement window. Good luck!!
Dan
