Second Dealer Switch, still no worky
Bear with me if this is long, I would really appreciate any help someone might be able to give me with my 1999.5 TDI Jetta with the classic door switch problem. I've ready through every page on this fix and vwvortex, and I'm about to drop it off at the dealer or start it on fire.
Quick History, few years ago I had the door switch problem, somtimes it would lock all four doors from drivers door key, sometimes not. I replaced door switch, all worked perfect after door switch replacement.
One month ago, same problem, intermittent.... I can 'manually' unlock/lock drivers door via key but rest of car will not lock to where it finally stops working, no more cental locking/alarm arming anymore.
Inside car, on door panel, I can lock/unlock all doors electrically. Puddle lights will not light, I have no power there at the bulb (bulb is good). I think this is part of my problem, w/ no power @ this light somehow.
I didn't research enough here to see the radio shack fix, I bought a door switch AGAIN from dealer. I swapped it out, no change, no puddle light work, cannot lock/unlock all doors from outside of car. I cant believe I got a bad switch from dealer, I've checked fuses # F/G above relays, and all fuses on panel. I call dealer and ask for another one, they say it could be other things, but gave me another one. Just put that one in, still dead.
At a few points during the swap the alarm armed while doors were open, I could not disengage alarm via door switches and the alarm barked when I tried to start it.
What am I missing? So far I've replaced the door switch 2x w/ new VW part. I have found no frayed wires at door to body, I have checked fuses, I have checked the wiring connector behind hood latch, everything seems fine. I have cleaned up real well the grounds under the battery. It seems I don't have power at the door somewhere for my key activation, and I am about 8 hours into these swaps/investigations and I'm to the point where I am at a loss.
Tell me somehere/something to check, it seems its not the door switch but something else, somebody else hasn't encountered. Is there an alarm 'restart' I need to do???
Brad
