I'm extremely tired so hopefully this makes sense.
I'm doing this job tomorrow.
Two questions:
1. MyTurboDiesel.com has a how-to that precludes the entire window regulator unbolting/tape your window part of the Vortex write up:
See here:
http://www.myturbodiesel.com/1000q/multi/Door-Module-Removal-Jetta-Passat-Golf.htm
Apparently the door lock mechanism can be removed by just prying the carrier panel back. Should I try this, or is space so tight that it's easier to just follow the Vortex procedure? Are the rivnuts everyone talks about just the two plastic things that you can see when the door panel is removed? Just punch them out and forget 'em, right?
2. BURGESS V4NS-UL People (this is what I have ready to go in): What is the correct wiring? There is a big contradiction in this thread. Some people did blue to blue / red to red and said it worked great. Several pictures show the yellow wire cut from the replacement Burgess switch. Others said this is wrong, like this post, and indicate that yellow should be wired to existing blue:
Help!! T minus 12 hours to tearing into this thing.
