bigsexyTDI
This is really coming along nicely. I would kill for a Metallic green Limited with the gold wheels and a TDI swap... drooool
...and an endless "hagen das" type of company names.You are new here. That idiot is well known.
The "bad vendors" thread was started OVER A DECADE AGO largely due to him:
**Bad VW part vendor WARNING list**
In honor of "Prothe" also known as "Proethe" who seems to have single handedly destroyed more TDI's than anyone else - See the current threads http://forums.tdiclub.com/showthread.php?t=314980 http://forums.tdiclub.com/showthread.php?t=199567 and...forums.tdiclub.com
And he has a seemingly endless supply of websites to pawn off the garbage.
ok, so say i wanted to send in my pump for rebuild/rework or as a core against a new M-TDI pump for the ALH ... who's the go-to?
I wonder why the pump doesn't work well? I don't think you will ever be able to get ole Hans's pump to run right.still got some good time out there this long weekend and knocked a few things out.
crank to cam timing ... cherry.
Compression #1-4 ... 365/360/360/320
any weird running is officially a pump issue. however i'm also still having issues keeping the pump adjustable sprocket to stay put. i'm to the point that i'm going to drill the sprocket/hub for a dowel pin, or drill and tap more holes at the ends of the slots to really lock it down. any other thoughts on this? my only conclusion at this point is that the 12mm pump is just too much for the factory deal. some of the weird running might be the timing just jumping around all over the place while running.
reverse lights wired and working, the alternator is the only electrical thing left. was shockingly easy to get all the gauges to work.
head pipe painted and wrapped ... because race TDI ... and finished connecting it back to the old factory xj muffler/tailpipe. hopefully this muffler doesn't kill to many of those cool turbo noises.
in my new research he keeps having great MTDI comments and help. he is top of my list to call when i can!Matt Whitbread
.....the glow system's operation still seems to be a mystery to me (and the owner). He said they said it was tied to the door buzzer??? Seems strange.
These quotes are from a few posts back.i can't imagine how the door buzzer would help ...
that makes sense! i actually kinda like that too. easy enough to just open n close the door to re-run the timer.to initiate the glow plugs before the key was inserted as a means of reducing the driver's wait time.
BBAAHAAHAHahahahInteresting description for a butt dyno
