oh.. 10-niner-niner check. 8-4. backup burpod systems have been deployed![]()
seeing as how those axles sell for WAY too much money ... ditch em to the highest bidder and build your JY 9's for less money!@burpod i might you to tune for me as well! To all of you looking forward to an Auto swap I bought a TJ rubicon for an unreal price so my priorities have shifted!
I think they call that the good old Italian tune-upyou ever get to a point where something is just not right ... you just get pissed off at your junk and start beating it like a rental with the extra coverage?
so i was getting mad at the XJ for being a little jerk ... i couldn't get a decent datalog cuz it would go into limp mode on the highway occasionally, but never just around. well yesterday i got mad and started beating it like it owed me money up n down the freeway. got it hot, countless cycles of mid RPM coast to full boost back n forth, up and down gears. well something cleaned up or broke loose! could be i blew out some carbon buildup, broke in the new injectors, unstuck something from it sitting so long, who knows.
it runs noticeably smoother and i'll see about limp mode this afternoon when i go for a basic drive. cross your fingers for me we're on the up-n-up now!
I think they call that the good old Italian tune-up![]()
Interesting, how much bottom end did you lose?I maxed out the timing adaptation at +500, i was still seeing lower EGT and running better ... it needed more.
i didn't get a chance to load his most recent tune this weekend, worked on another truck.
the opposite, it was getting better. i feel like something weird was off in the base tune we started with and we should probably delete the earlier trials and just start fresh. a typo, something loaded wrong, something corrupted, but unexpected.Interesting, how much bottom end did you lose?
i've gone over it multiple, multiple times. there's always room for a typo, but this is beyond typo territory, and i haven't made any typo/glitch mistakes in quite a long time... aside from sometimes an initial mixup of which map sensor is being used, or forgetting to change the upper limit of the drver wish fuel request map, and i have enough well-running "base tunes" that to make a new, slightly different tune, the chance of that type of error has become very very small. like for your tune, since i hadn't done a BD ecu file tune for 11mm/.260s yet, but have done 11m/.230s (dieseldonato, my brothers alh), so i copy that tune over to a new file, and then plug in the fuel/timing related maps from my mk1 11mm/.260 tune + the vnt17 boost related maps . since dieseldonato/mybrother both have larger 18xx turbos. those maps are mostly the same except your top end fueling is limited to a lower amount, as well as the very top end of boost.the opposite, it was getting better. i feel like something weird was off in the base tune we started with and we should probably delete the earlier trials and just start fresh. a typo, something loaded wrong, something corrupted, but unexpected.
to clarify what i did here for others who might be reading - all i did to the malone tune was "hammer mod it in the software" to account for the new QA position. my tunes, i try to get the QA in a more correct position for the injectors. 11mm/.158 (stock auto fueling) idles with pump voltage ~1.54v to get ~4mg hot idle IQ. the larger nozzle you put in, that pump voltage would drop (like how you see if you install larger injectors you'll see your IQ drop). my estimation of .260s would be pumpV of around 1.25v or something like that. the malone tune uses the virtual same pump map for every fueling, which puts you at a pump voltage of ~1.7v for IQ of ~4mg (like a 10mm/.184 stock manual nozzle tune), which isn't correct at all. so i basically just subtracted ~400 (.4v) from the malone pump map so you can run it with where you've hammer modded (down) the pump to run on my tune.how does +500 to your tune compare to the malone stage-3? the fact that this "canned" tune (burpod modified it for the 260's) rips is what made me think some unexpected change happened. it wasn't a small change either, it was like going from NA to boost.
Pop pressure plays a role in timing as well, we're just assuming everything is right, or close and the spec does have some allowable variance. So of the pop pressure it at the high end of spec or just over the injection pump has to overcome that pressure to lift the needle and start the injecrion event. Thus throwing timing off. I would think with the lift sensor in the injector the ecuwould be able to compensate for wear and adjust, but idk if it's something it does.been thinking about this and it's really screwing with my head lol... i've done enough of these 11mm/.260s that run very well (several of these cars have EGT gauges too and all good there too), as well as 11mm/.230s (not quite as big, but still pretty comparable in size) that something has to be really off, because +500 to the timing maps i gave you initially (the near same tune i run daily in my mk1 for this fueling) is completely off the charts. that's running wayyyy more advance than any tune i've done for 10mm/small nozzles with the longest injection durations, wayyy more advance than a stock 11mm/auto nozzle (~.158) for lower/mid IQ amounts even. and i've messed around with all kinds of advance and tune versions on multiple cars, that amount of advance (especially given the crazy short injection times of 11mm/.260s) should be causing the car to run like total poo with all that pre-tdc combustion, it should be shuddering and have zero power and feel completely strained and undrivable. zero torque.
i'm leaning towards there must simply be a sensor/wiring issue and that the timing being reported by the ecu has to be off by a substantial amount. but oddly, i've seen a very similar issue on 2 other cars (both with .260s coincidentally, with injectors setup by someone different than almost all the others have used. *shrug* very very strange....
yes, i've been thinking of pop pressure too, but that also doesn't make sense, because the ecu adapts to that. the ACTUAL timing it's reporting *is* (or should be) the timing - it's using the crank sensor + needle lift sensor from 3rd injector. so in the tune, when you specify you want 1.0BTDC, if it's reporting ACTUAL timing of 1.0BTDC also, that's what it's doing, unless the sensors aren't reading correctly. i think the pop pressure could affect the pump voltage/duration to get the same amount of fueling tho. need to re-read the bosch pump doc and try and see if perhaps there's something i'm misunderstanding on that.Pop pressure plays a role in timing as well, we're just assuming everything is right, or close and the spec does have some allowable variance. So of the pop pressure it at the high end of spec or just over the injection pump has to overcome that pressure to lift the needle and start the injecrion event. Thus throwing timing off. I would think with the lift sensor in the injector the ecuwould be able to compensate for wear and adjust, but idk if it's something it does.
Higher pressure also leads to better fuel atomization, my guess is head trying to make up for bigger injectors haveing atomization issues. I'd be a bit worried about cam plate wear in the ve...may be it's not an issue.yes, i've been thinking of pop pressure too, but that also doesn't make sense, because the ecu adapts to that. the ACTUAL timing it's reporting *is* (or should be) the timing - it's using the crank sensor + needle lift sensor from 3rd injector. so in the tune, when you specify you want 1.0BTDC, if it's reporting ACTUAL timing of 1.0BTDC also, that's what it's doing, unless the sensors aren't reading correctly. i think the pop pressure could affect the pump voltage/duration to get the same amount of fueling tho. need to re-read the bosch pump doc and try and see if perhaps there's something i'm misunderstanding on that.
but supposedly (i asked the person who set up these nozzles) they are set to factory pop pressures. the other cars i've not had any problems with .260s are all injectors from xman/powertdi who set the pop pressures to factory, or very close. i think he does 230/310 if you specify 11mm pump. jarod march, i talked to him, i know he's set some large injectors to much higher pop pressures - 260/340 - now thats a pretty substantial difference that i wonder how that affects required pumpV to get the same amount of fuel flow...
bearing separators as used for the ax-15 rebuild? i have the HF 4" singleDo you remember what size bearing jaw clamp you used? There's a 4" one at harbor freight and then a kit with both a small 2" ish one and 3" one.
