I can demystify all the confusion about VW coolants. Start with this video. They talk about VW coolants around the 10 minute mark.
https://www.youtube.com/watch?reload=9&v=GUcTWzBZAdg
The take away from the video:
G11: Old school antifreeze/coolant. Contains silicates, borates, and nitrates.
G12: OAT antifreeze/coolant. No silicates, nitrate and borate free.
G12++: HOAT antifreeze/coolant. Contains some silicates. No nitrates or borates.
G13: HOAT antifreeze/coolant. Contains some silicates and glycerin made from renewable sources as a substitute to some of the ethylene glycol. No nitrates or borates.
I took this photo at a NAPA store a few months ago. This is the first time I saw all the Zerex products together. Not all NAPA stores stock all the varieties of Zerex coolant. A very brief description of each coolant starting from left to right.
Dex-Cool: Run away from anything that has Dex-Cool on the label. The first OAT (Organic Acid Technology) coolant This includes anything made by Prestone and Peak.
G40: VW G12++ and G13 compatible, HOAT (Hybrid Organic Acid technology). The hybrid means some silicates were added. Don't get all hung up on G13, it's not that special. All G13 is VW specifies a little bit of glycol derived from glycerine instead of 100% petrochemical based. The amount of glycerine based glycol is around 10% of the total glycol content.
G48: The old VW G11 formula, the green/blue stuff. Non-OAT formula, contains borates, phosphates, and silicates.
G05: a HOAT coolant that is basically the same formula as G12++. OAT technology with a small amount of silicates added.
Asian Blue & Asian red are the exact same coolants except for the color. My one son own a Toyota, Asian Red. Another son owns a Hyundai, Asian blue. Asian specification coolants are PHOSPHATED OAT coolants. An OAT coolant that contains phosphates is technically a HOAT coolant. The take away here is that not all HOAT coolants are created the same. That's why I included the Asian coolants. They also contain silicates but so do Euro spec HOAT coolants. Euro spec coolants DO NOT contain phosphates
. Never use a coolant for Asian cars in any VW product.
NAPA and several TDI vendors carry Pentosin coolants. Here's a link with a good description of Pentosin's coolants.
http://www.pentosin.net/f_antifreeze.asp
Pentosin/Pentofrost E is G13 coolant, light purple cap, HOAT coolant, contains silicates and some glycol derived from glycerine.
Pentosin/Pentofrost ++ is G12++ coolant, dark purple cap, contains silicates.
Pentosin/Pentofrost SF is G12 coolant, red cap, OAT coolant, no silicates
Pentosin/Pentofrost NF is G11 coolant, blue cap
Drive more and worry less.
