Chemboy
This outlines the modifications necessary to make the hybrid oil pan repair kit for the 2.0L gas engine (1JM198601T) fit onto a VE TDI engine. This isn't a direct fit because there is interference with the a/c compressor.
What you'll need:
This next picture shows where the interferences are. The circled one is the immediate problem. After taking care of it, the ones on the left and right show up.
Before I took the old pan off, I used my dremel and worked on the a/c compressor. Leaving the pan on protected the engine internals from the tiny splinters of aluminum. PLEASE WEAR SAFETY GLASSES WHEN DOING THIS!!!!
Here's what the compressor looked like afterwards-
Next, I worked on the oil pan (PLEASE WEAR SAFETY GLASSES WHEN DOING THIS!!!!)
After removing the old pan, I held the new one up and checked clearances (1/16"-1/8" should be fine). I deburred the compressor and oil pan and then applied some touchup primer and paint to the exposed steel.
Next, I applied the sealent as per the manufacturer's directions. I prefer "The Right Stuff" over VW's sealent because it's much easier to apply and it seems to work at least as well. Other members of this board recommend this too.
I bolted the pan to the engine as per the Bentley manual. A couple things to note:
Here are two pictures of the pan after installation. The first one shows the clearance from the a/c compressor.
One other thing to note, I did install the new oil sump pickup tube that came with the kit. It looked the same as the one I removed from the car.
Based on these pictures, can someone verify if this will work on a PD?
Good luck!
Andy
What you'll need:
- 10 mm socket
- Metalnerd wobble oil pan bit
- Dremel with a carbide tip for grinding/wire brush for deburring
- Sealent (I used Permatex "The Right Stuff")
- Magnetic pickup tool (to hold bolts in place/retrive bolts dropped between the oil pan and transmission
- The wobble oil pan bit MUST be used to install all the bolts behind the a/c compressor. If you don't, you'll end up with a stuck socket
- For two of the bolts behind the compressor, you'll need to bring them in from the side of the pan and then screw them in. I used a magnetic pickup tool for this (see below). This will become quite obvious during the installation.
Good luck!
Andy
