spleecho
I don't kill trees Vendor , w/Business number
I made a video on how to install a boostvalve step to step. Can this be posted on this 'How to' or where should I post?
This is super simple. No need for spring compressors to do this job!DoubleNickel said:How about this way to replace the upper strut bumpers:It worked for me great.
http://forums.vwvortex.com/zerothread?id=1381025
Very simple![]()
The link for the panzerplate video has changed: http://cincitdi.com/videos/panzerplate.html.paramedick said:Compliments of the folks from CinciTDI club and Dieselgeek. Starring yours truly!You need Apple quicktime 7 or newer to run this. Kudos to RichC for the excellent video work and editing.
http://cincitdi.com/richc/panzerplate.html
Apple quicktime installer link
http://www.apple.com/quicktime/player/win.html
Guys, I know this is not a how-to. Just stashing it here so it is easy to find.
Silicone hose sizes/lengths for the A3/A4/B4 cars. Viton tubing for the fuel return lines.
[FONT=Verdana,Arial,Helvetica][FONT=Verdana,Arial,Helvetica]mcmaster .com[/FONT][/FONT]
[FONT=Verdana,Arial,Helvetica][FONT=Verdana,Arial,Helvetica]Ft.[/FONT] [FONT=Verdana,Arial,Helvetica]5041K22[/FONT] [FONT=Verdana,Arial,Helvetica]Metric Silicone Rubber Tubing Firm, 3 mm Id, 8 mm Od, 2.5 mm Wall, Red (Same as 5041K52) [/FONT][FONT=Verdana,Arial,Helvetica]
[/FONT][/FONT][FONT=Verdana,Arial,Helvetica][FONT=Verdana,Arial,Helvetica]
Ft.[/FONT] [FONT=Verdana,Arial,Helvetica]5041K522[/FONT] [FONT=Verdana,Arial,Helvetica]Metric Silicone Rubber Tubing Firm, 3 mm Id, 8 mm Od, 2.5 mm Wall, Blue (Same as 5041K52) [/FONT][FONT=Verdana,Arial,Helvetica]
Ft.[/FONT] [FONT=Verdana,Arial,Helvetica]5041K521[/FONT] [FONT=Verdana,Arial,Helvetica]Metric Silicone Rubber Tubing Firm, 3 mm Id, 8 mm Od, 2.5 mm Wall, Black (Same as 5041K52) [/FONT]
Ft.[/FONT] [FONT=Verdana,Arial,Helvetica]5054K531[/FONT] [FONT=Verdana,Arial,Helvetica]Metric Silicone Rubber Tubing Soft, 4 mm Id, 8 mm Od, 2 mm Wall, Black (Same as 5054K53) [/FONT][FONT=Verdana,Arial,Helvetica]
Ft.[/FONT] [FONT=Verdana,Arial,Helvetica]5119K41[/FONT] [FONT=Verdana,Arial,Helvetica]High Temperature Viton Rubber Tubing Firm, 1/8" Id, 1/4" Od, 1/16" Wall, Black [/FONT]
A3 Jetta: 3 foot of blue/red. 12 foot black 3mm. 5 foot black 4mm
B4 Passat: 6 foot red/blue. 15 foot black 3mm. 5 foot black 4mm
A4 B/G/J: 10 foot of black 3 mm. 5 foot black 4mm.
With all these numbers, you will have some left over. Not a bad thing to have a little vacuum tube around.
Viton hose: 3 foot is more than you need. You will have some left over after replacing the interinjector lines and return line to the injection pump.
[/FONT]
Check with VW - pretty sure I got a service bulletin from them recently about that very issue - for what it's worth anyway...(They don't get to touch my car)I have a 1999 1/2 jetta and the sunroof leaks like a seive on the passenger side. I believe the drain tube that runs from the roof down to the outlet is ruptured. I base this on the fact that I ran a length of weedwacker wire through the tube and it didn't come out the other end AND some test water I poured in spilled onto the carpet from under the dash...I think. Anyway I think I need to remove the dash to get to the drain tube. How do I remove the dash or where can I look for reference?
Good video, however you changed a driveshaft (with CV joints) not just the joint. Perhaps a re-title to "how to change a drive shaft" would allow it to be more easily found when searched for.
