Old November 21st, 2009, 19:02   #1
Growler
Got Soot Vendor
Growler's Avatar
Default BRM Timing belt procedure Checklist.
This is a Checklist I created using chittychittybangbangs procedure at:
http://www.myturbodiesel.com/1000q_h...belt_part1.htm
it would be good to familiarize yourself with his procedure before you use my checklist.
I slightly modified the order of removing the fuel filter/housing to accommodate the pinning and removal of the serp belt tensioner.
I also listed all the steps from start to finish.
here is the link to my Checklist. prints on one page.
http://pics.tdiclub.com/data/517/Gro..._Checklist.pdf
let me know if you would change any steps, or wording and Ill keep it up to date.
Aaron
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old April 13th, 2012, 21:17   #2
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
I am in the midst of changing my 2006 BRM timing belt and just wanted you to know that I found both chittychittybangbang's procedures and your checklist to be very helpful. There were tips and procedures from others as well, most of which I read and tried to digest into something I could follow. Your checklist is great! Thank you much!
sptsailing is offline   Reply With Quote
Page generated in 0.13082 seconds with 9 queries
[Output: 49.69 Kb. compressed to 45.48 Kb. by saving 4.21 Kb. (8.48%)]
