Old March 12th, 2010, 10:08   #1
Gordon Peterson
Gordon Peterson's Avatar
Fuel Economy: 40mpg
Default HOW TO N75 barb repair
How many times have you seen an N75 valve or other vacuum device with a broken barb fitting. Instead of purchasing a $75 part how about 5 minutes and $1?
Or how can you get buy untill you get a new one ?
Always use a shop vac to pull chips and shavings away during the process...
1. Use a file to clear away the broken fitting and prepare a flat surface.
2. Tap the hole out to work with the fitting you have. Here I used a
10-32 tap for the brass fitting in the picture.
3. use a very small amount of teflon pipe dope/sealer on the threads.
(REALLY... a small amount only.)
4. Thread the fitting into the hole, tighten only lightly to prevent the
plastic from cracking. (This isn't holding the world together)
5. Plug it in and go.
I used this to repair an N75 valve that the fitting broke off of and it works great. Remember to keep shavings and crap out of the valve... Blow it out, vacuum it out... The system will not tolerate much crap.
This repair procedure should work on other parts also and different size fitting are also availiable for larger holes or tube.
You should be able to pick up the fitting at any local industrial supply location. The pic from McMastercarr is here for your reference.
03 Jetta TDI wagon "SMOKE" (mine)
trusted guru's: r90sKirk, JETaah, Franko6
Heads nozzles,TB kits, etc.: Franko6
Gordon Peterson is offline   Reply With Quote
Old March 12th, 2010, 10:13   #2
ToCheapforGas
ToCheapforGas's Avatar
TDI(s): 02 Jetta TDI
Great idea and a simple inexpensive fix
2002 Jetta TDI
399 857 km
248 459 miles
ToCheapforGas is offline   Reply With Quote
Old March 16th, 2010, 13:39   #3
PEPO
PEPO's Avatar
Can I do the same To fix the nipple on the anti shurdder valve? same size fitting?
PEPO is offline   Reply With Quote
Old March 18th, 2010, 14:43   #4
PEPO
PEPO's Avatar
I just replaced the nipple of the Anti shudder valve with one of those, came our really well!!!
Thanks for the Idea!!!
Old April 9th, 2010, 09:02   #5
Gordon Peterson
Fuel Economy: 40mpg
Glad to hear it worked for you. This simple cheap fix can be used in many places on our cars. Vacuum lines always get stuck on the fittings and it is really easy to break the plastic ones off when pulling.
Old April 9th, 2010, 15:35   #6
dieseljunkie
If you don't have a tap (but you still need a tap drill), you can heat up the fitting with a torch to about 300- 350 F (forming temperature of many plastics) and tap it with the fitting. Put a drop of crazy glue afterwards followed by some epoxy to insure a good seal & strength. I had to do that when I broke the nipple off the MAP sensor inside the ECU and had to make a custom fitting and a short tap drill bit and drilled and tapped it with a micro hand ratchet since there was no room to use an elec drill or swing a tap wrench.
Ps. I'd consider such a repair to be permanent / better than new because you now have a metal instead of a plastic nipple.
96 Passat TDI wagon ~145k SOLD!
92 Ecodiesel 205k
dieseljunkie is offline   Reply With Quote
Old April 9th, 2010, 15:38   #7
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
I just used plastic cement. Works great. Also used it on my glove box hinge. Over a year and no issues.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old April 9th, 2010, 15:43   #8
dieseljunkie
92 Ecodiesel 205k
Old August 5th, 2010, 23:33   #9
cfm56
Thanks for the idea Gordon, i might possibly attempt to accomplish this on my asv
cfm56 is offline   Reply With Quote
Page generated in 0.17037 seconds with 9 queries
[Output: 88.89 Kb. compressed to 75.13 Kb. by saving 13.75 Kb. (15.47%)]
