mamock116
Yes, this is my favorite mod. better mpg and got rid of the bog when easing off the clutch to get moving.
Just wanted to give an update. It has been a little over 10k miles since I pulled my flaps out. I went to the Tail of the Dragon over the weekend and had no issues what so ever. I beat the hell out of the car too. I got 48.4mpg on my 6.5 hour trip home. My average speed was 71mph. My previous best before the flaps was 10 hour trip to the keys in which I averaged 71mph and got 45.9 mpg.
I hooked up vcds today to my car and checked my ash load. I am at 60ml and I have 62k miles. I was at 48ml and about 52k miles when I pulled the flaps out. Removing the flaps does not seem to increase ash build up in the dpf. It seems I put about 1ml per 1k miles.
The new Passat TDIs with CKRA engine have same intake manifold as us... just no intake flaps. part # 03L129711AR $237.64 on parts.com.Well, I am looking into whether a 2014 intake is the same as the 2010 as far as shape and ability to fit...I thought I remember reading that it doesn't have the flaps and is not terribly expensive(I think it costs about the same as the engine cover) So if I can sell my intake to recover some of the cost, I may go that route.
But, probably going to wind up pulling them when the HP EGR is dealt with.
Off for another test run...Top off the fuel and meth and see what happens.
Update:
Yup...something with the methanol injection and the flapper valve doesn't jive or the flapper valve was malfunctioning. Not even remotely close to the same with valve plugged in...I'm having remapped to eliminate it as well as HP EGR.
But I don't think I can be a reliable example of whether unplugging it helps performance if the valve is functioning properly.
I think mine was stuck closed or partially closed and methanol is now cleaning the side effects of that. I had the traction control kick in on a rolling start in 3rd at about 1700rpm...Don't remember that happening before.
So tried unplugging flappers motors and leaving it unplugged for 30 min drive last night. CEL came up on the dash after about 15 min. I had to stop at the gas station and after restarting engine I got CEL. I did notice much more pull and less bog on the 2nd and 3rd otherwise nothing else. It could be easily a placebo effect. is there a way to remove CEL light for the time being with VCDS until I complete HW removal?
Just curious, what are the other good free mods?From what I gather this seems to be one of the best free mods you can do.![]()
Well... It may not be so free if your car throws a check engine light. Seems that some cars will and others won't.Just curious, what are the other good free mods?
I turned my horn off for locking/unlocking and enabled the turn signal flash instead. Better for me since i work nightsI just turned on the horn when unlocking. Really missed that from my beetle. Just like to know when I push the button that something is happening.
Malone stg1.5 was programmed by German Car specialists shop. I also have VAG-com cable.Who does your tune?
.So I tried this on my way home from work this morning, and I got no error code. I am tuned with Malone Stage2 with DPF delete. Then tonight when I started my car to go to work there is the error code. I haven't read the code yet but I am pretty sure its due to the flapper motor. So I just plugged it back in. I saw no improvement in mileage. I just need to clear the code tonight.
So if its supposed to be tuned out with the tune; why isn't mine?
After doing the afe stage 2 install i immediately noticed a drop in bottom end performance, after about 300 miles that drop starts to go away and the bottom end loss comes back. Saturday i had to pull it and reverse the tstat bypass for tue fuel return line off the rail and i could immediately tell the drop in performance while taking it for a spin to warm it up before the smog test.Interesting that you didn't notice an improvement in mileage. Maybe the car has to relearn. I am consistently getting 1.3 to 1.5 mpg improvement per tank in daily commute. Long road trips I seem to be getting 3mpg improvement. I also have a dpf which is another difference between mine and your car.
Yeah, I'll call them today see how long will it take them to get updated tune back from Mark.Go pay a visit and see if you can get runner flap deleted from Mark
I've noticed the motor does two cycles when I shut off the engine so I guess if ECU doesn't get the signal it throws a CEL.I guess mark didn't add this feature to your tune, so that's why it's causing the error code to pop up.
Mine doesn't throw error code because mark added this feature to my tune. The drive ability of the car is awesome and very easy to drive!
aFe stg2 as in air intake? I have their Pro Dry series that goes into the stock air box - haven't really noticed much gain with butt-dyno but it does make turbo sound louder.After doing the afe stage 2 install i immediately noticed a drop in bottom end performance, after about 300 miles that drop starts to go away and the bottom end loss comes back. Saturday i had to pull it and reverse the tstat bypass for tue fuel return line off the rail and i could immediately tell the drop in performance while taking it for a spin to warm it up before the smog test.
Yes it does take time to relearn and the test for mpg change the guy did on the way home ins not accurate. I saw a drop in mpg with the above install initially which makes sense with the loss in the bottom end. That loss went away as well and i actually saw an improvement when looking at commute averages over a 3000 mile period doing aba testing.
If your going to test for mpg give it at least 300 miles to adapt, 500 to be safe, then judge.
After it's had time to adjust, I notice it in the top end. Hence the reason for wanting another stock airbox... I want to cut the end of the box by the fender to be able to mount a longer filter. You might want to try the fuel line & canister insulation and bypass the tstat in the fuel canister for the returned fuel.aFe stg2 as in air intake? I have their Pro Dry series that goes into the stock air box - haven't really noticed much gain with butt-dyno but it does make turbo sound louder.![]()
mamock116, what is your impression so far with this mod?
Yes, and no. Simply unplug the motor and flaps default to open position, but will give fault. Remove the discs, and keep motor plugged in, and no tune needed.So is the only way to disable the duty cycle by retune of the ecu?
So if I don't have EGR delete yet and unplug the flapper actuator (with possibility of removing the actual flaps later) I might have intake runners being plugged up with soot faster than normal?The intake flaps are there for one reason, to speed up the air during low/part throttle so egr soot won't stick to surfaces if it is flowing by faster. EGR duty cycle goes away at big drivers request, as does the flap duty cycle.
Best running CR's have egr delete, and flap duty cycle turned off, that's it. No need to remove the flaps. This is a 3-4mpg FE benefit in all diesels, CRD's, MB's, BMW's and TDI's.
